Mini Pirate
Old May 18th, 2008, 07:11 PM   #1
Mighty mini!!
Mighty mini!!'s Avatar
Local Time: 09:11 PM
should i change ?
Im currently running the JCW air filter which is good but i feel there is better out there. In 06 i had a cooper s with an Alta Induction Kit. would this be better for beathing and noise?
Also as far as im aware the pulley is smaller on the JCW models could i change this for a smaller one or better ?
One more thing are the Blufin maps any good,seems a bit too easy to map the car with one of those raher than do a diagnostics test?
Many thanx
Martin
dark blue JCW cooper S aero kit,spots.18"Alpina's c/c arches,sat,nav,dvd, Alta induction-pully,bluefin remap
Old May 19th, 2008, 10:47 PM   #2 (permalink)
Mighty mini!!
sure is full of helpful people on here,,, nevamind
Old May 20th, 2008, 07:50 AM   #3 (permalink)
DaFlake
Lovin' every MINI of it!
DaFlake's Avatar
Local Time: 04:11 PM
I'll toss in my .02 as I missed this thread.
To be honest, most CAI are the same when it comes to hp. It is mainly the users choice on what you want. On the JCW pulley you could probably go to a 15%. The JCW pulley is about 11.5% so you will gain a little.
Map wise, you have the JCW re-map if you have a JCW. Going to a Bluefin will probably not gain you a thing and might actually cause a loss. A custom tune is the way to go. If you are interested in a tune I would talk to 1320 or Performance Torque to see what they can do for you.
Lastly, if you do a search you will see that all of this has been covered before.
Global Moderator
United States Male View DaFlake's Pure Silver & Black 1st Gen MINI Cooper S Profile   Reply With Quote
Old May 20th, 2008, 10:19 AM   #4 (permalink)
Mighty mini!!
ok thanku i know p. torque from the TT forum so il give them a bell.
Either way i think il change that JCW air box, not sure its the best
thanks again
Old May 20th, 2008, 11:25 AM   #5 (permalink)
DaFlake
DaFlake's Avatar
JCW is a pretty good box especially if you cut the flap out. There are others (I use the MINI-Madness CAI) but they all perform about the same. It really is down to the looks of it rather than performance. Good luck...
Global Moderator
Old May 20th, 2008, 01:25 PM   #6 (permalink)
Morri7
Morri7's Avatar
GTT do a different filter for the JCW box that is supposed to give better air flow. If your selling the JCW box give me a shout!
Scotland Male View Morri7's Indi Blue & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old May 20th, 2008, 01:50 PM   #7 (permalink)
batou
Turbo Schmurbo...
batou's Avatar
Local Time: 10:11 PM
CAI & Cat-back = Sound.
Pulley, Intercooler , Big valve head, 4-1 Manifold & Custom tune = HP.
Do a search for more detail
235+ BHP "Works" Eater
United Kingdom Male View batou's Dark Silver & Black 1st Gen MINI Cooper S Profile   Reply With Quote
Old May 20th, 2008, 04:36 PM   #8 (permalink)
Mighty mini!!
well i used Alta B4 and thought it was the nuts. so i think il change then have a look at some pulleys and re-map etc. the JCW airbox will prob go up for sale if anyone wants to buy it, in a week or so.
Old May 20th, 2008, 06:31 PM   #9 (permalink)
DaFlake
DaFlake's Avatar
Sounds like a plan!
Global Moderator
Old May 20th, 2008, 07:24 PM   #10 (permalink)
MINI-Morgan
MINI Obsessed...
MINI-Morgan's Avatar
Old May 20th, 2008, 10:30 PM   #11 (permalink)
sam_a156
Flying Finn
sam_a156's Avatar
Send a message via Skype™ to sam_a156
Many of the recent 230+whp conversions in the US have been with the JCW box, so don't know how you define "best". But it if is about sound effects, deflapping the JCW box and removing the lower plug does help...but there probably are more noisy CAIs out there fore sure if that's what you are after...and probably more flashy ones.
I have the JCW box with the Madness filter kit with all the mechanical parts removed.
Sam
Ps. U had too many questions in your post
Poland Male View sam_a156's Dark Silver & Black 1st Gen MINI Cooper S Profile   Reply With Quote
Old May 20th, 2008, 11:42 PM   #12 (permalink)
Mighty mini!!
how do i go about removing the flap etc.
jus want the performnce and noise at minimal cost at the end of the day.
thanx
Old May 21st, 2008, 05:43 AM   #13 (permalink)
sam_a156
Flying Finn
sam_a156's Avatar
Go here:
Mini-Madness.com LINKS
Then click "JCW INTAKE FILTER UPGRADE KIT" for instructions how to do the "flap mod". Once you have the box open, you will notice that there is a lower opening in the box which usually comes with a plug. Remove that too for some more noise.
Modding does not come much cheaper than that
This is the filter kit itself:
JCW Intake High Flow Filter Replacement - JCW Intake High Flow Filter Replacement
As has been posted elsewhere, with open CAIs you may even end up loosing power
Ps. I you would ask me, my answer to your initial question would thus be a 'no' (don't change) - I'd just change the filter if I were you.
Old May 21st, 2008, 08:08 AM   #14 (permalink)
batou
Turbo Schmurbo...
batou's Avatar
Just stick in an ITG filter (£40) and pull out all the electric flap and you have a JCM or equivalent of an Alta with a box top! Like I said a CAI will really get you nowhere in terms of hp/trq when compared to a pulley. E.g. Alta V2 CAI what is it approx. £250? You get 1-2 maybe 5hp. -15% pulley max of £300 fitted and you get 20,30 or 40hp!! Do the math.
Old May 21st, 2008, 08:57 AM   #15 (permalink)
MiniPetrolHead
263bhp / 284.55Nm Torque
MiniPetrolHead's Avatar
Send a message via MSN to MiniPetrolHead Send a message via Skype™ to MiniPetrolHead
Im making 232bhp before i got my JanSpeed cat back and the cat had melted and was rattleing around in the cat chamber (so potentially a loss from the faulty cat and now a gain from the cat back and de-cat), the car was rolling roaded using the standard air box with just an alta pannel filter!!!
I dare say that i may be running something slighly closer to the 240bhp mark now!
Only the surry rolling road day will tell!!!!
Alex
United Kingdom Male View MiniPetrolHead's Solid Black & Body Color 1st Gen MINI Cooper S Profile   Reply With Quote
Wheels, to change or not to change? NFCooperS Engine & Drivetrain Tuning 5 Apr 9th, 2006 03:00 AM
A change for the better? dipstic&dinnerlady General Discussion 31 Mar 15th, 2005 07:02 PM
Does the wheel offset change if you change the width of your wheels? Root Ginger Wheels, Tyres & Brakes 6 Feb 23rd, 2005 11:22 AM
My change from ONE to MC S GeoffMM MINI Cooper S 41 Jan 1st, 2004 07:53 PM
