Mini Pirate
Old May 18th, 2008, 10:09 PM   #1
MINI-Morgan
MINI Obsessed...
MINI-Morgan's Avatar
Local Time: 09:05 PM
Cylinder Heads
Does anyone know if there is more than one type of MCS cylinder head?? Just noticed that the new head im in the process of fitting has no threaded studs on the inlet manifold like the stock one does. Has it been changed at some point? JCW maybe?
Old May 18th, 2008, 10:59 PM   #2 (permalink)
Jaw_F430
Jaw_F430's Avatar
I think I know what your on about, are there threaded holes? If so you just need to use two nuts back to back and extract the studs and then put them on your new head
Otherwise lol
United Kingdom Male View Jaw_F430's Solid Black & Body Color 1st Gen MINI Cooper S Profile   Reply With Quote
Old May 19th, 2008, 08:30 AM   #3 (permalink)
supercoopers
supercoopers's Avatar
Otherwise lol
As Jaw_430 has alluded to, the difference could be that the threads were left in the head for the one you're now fitting whereas usually they're removed before transit and to reuse in another application (although this isn't ideal because the studs can damage the soft aluminium threads in the head if removed and installed numerous times and in just one instance if mishandled!).
The only difference that I know of is that between the cooper and cooper S cylinder heads - the latter has hardened exhaust valves.
H
Old May 19th, 2008, 12:29 PM   #4 (permalink)
MINI-Morgan
MINI Obsessed...
Thanks Guys. Spot on what I meant!
The head was on the floor and I dont think I looked close enough to guage if they were removable or not! Opppps!
cooper heads tons888 Engine & Drivetrain Tuning 6 Jan 13th, 2008 03:00 PM
Ported heads, we might have a new option soon. My Mama's Cooper Engine & Drivetrain Tuning 56 Jan 7th, 2004 03:23 PM
mad heads from manchester madferrit UK & Ireland Discussion & Event Planning 41 Nov 5th, 2003 03:27 PM
