Visit Out Motoring!
Old May 20th, 2008, 06:51 PM   #1
Peewee12
Local Time: 10:10 PM
Bypass Valve ?
Hi
I am new to the world of mini's and superchargers having just bought a mcs, I am just wanting to know what the bypass valve does and how up rated units help.
Peewee
Old May 20th, 2008, 07:21 PM   #2 (permalink)
MINI-Morgan
MINI Obsessed...
MINI-Morgan's Avatar
Local Time: 09:10 PM
It bypasses the Supercharger otherwise you'd be on boost all the time. Uprated? maybe a stronger spring but that would just make it come on all of a sudden.
Just make sure yours closes properly and thats about the best you can hope for
Old May 20th, 2008, 07:33 PM   #3 (permalink)
dukesantos
Moderator
dukesantos's Avatar
Local Time: 01:10 PM
There may be a bit of confusion here, the 2002-2006 MCS has a belt driven, geared supercharger. You can increase the power by changing the pulley to increase the rpm it turns at. It is always on. The new MCS is turbocharged and probably has a bypass valve, I'm not as familiar with that engine.
United States Male View dukesantos's Pure Silver & Body Color 1st Gen MINI Cooper S Profile   Reply With Quote
Old May 20th, 2008, 08:26 PM   #4 (permalink)
toydestroy
02/06 Mini does have a bypass valve.
Basically helps keep the boost levels up when your at low revs and other bits and bobs to do with vacuum pressures either side of the turbines.
England   Reply With Quote
Old May 20th, 2008, 09:00 PM   #5 (permalink)
DaFlake
Lovin' every MINI of it!
DaFlake's Avatar
Local Time: 04:10 PM
They are correct Duke, there is a bypass valve in the 02 - 06. You are thinking of a blow off valve.
An uprated BPV will have a stronger spring for faster response and fully close. I uprated mine and it does provide for better throttle response and faster delivery of boost. I like it but many others do not It is more of a preference thing.
Global Moderator
United States Male View DaFlake's Pure Silver & Black 1st Gen MINI Cooper S Profile   Reply With Quote
Old May 21st, 2008, 03:43 AM   #6 (permalink)
brainycheddar
a.k.a. BrainRush
brainycheddar's Avatar
when you're buying an uprated bypass valve, usually the manufacturer will check to see if the valve closes completely, thus providing the maximum available boost when it's supposed to. the second thing that will often be done is to add a stiffer spring to make maximum boost more of the time. I'd say 90% of the time, you are being overcharged for the amount of modification being done, and the only real gain in performance is if the valve didn't close completely beforehand.
Mods: MiniMania CAI and 15% pulley, Racing Brake front rotors, EBC Green Stuff front pads, ALTA 19mm anti-roll bar
Old May 21st, 2008, 07:08 AM   #7 (permalink)
dukesantos
Moderator
dukesantos's Avatar
Thanks for the info, I was thinking of the blow off valve on the turbo.
Old May 21st, 2008, 07:17 AM   #8 (permalink)
DaFlake
DaFlake's Avatar
No worries.... I used to get the two confused myself.
Global Moderator
Old May 21st, 2008, 07:59 AM   #9 (permalink)
Paul Webster
Paul Webster's Avatar
Dont forget that you could have a 07 /08 cab and still be supercharged
It's not how much you spend but how well you spend it
Old May 28th, 2008, 12:52 PM   #10 (permalink)
Peewee12
does anyone have one of these
New Mini Product | Alta Tuned By-Pass Valve
Old May 28th, 2008, 01:00 PM   #11 (permalink)
DaFlake
DaFlake's Avatar
I don't have the Alta, but I do have the Detroit Tuned one.
Detroit Tuned // Detroit Tuned Bypass Valve
It was a nice addition to the MINI but at first it was a bit jerky in response. Now that the spring has settled in, it is very smooth. Also, the one you posted looks rather expensive. A bypass valve from the dealer was 60 Euro here in Germany.
Global Moderator
Old May 28th, 2008, 02:23 PM   #12 (permalink)
MINIMANIAUK
MINI2 Sponsor
Just for a bit of clarification;
The supercharger is a pump ,at one end it pumps into the engine and at the other it sucks air in
The air is sucked in through the throttle plate and pumped into the engine intake,if it pumps more air in than the engine can take it produces a pressure (boost pressure).
If the throttle is open all is well except you would not be able top slow down! so the throttle is closed -the charger is still turning and still pumping ,but the pump cannot suck as much as the throttle is closed.
the charger now has to work harder trying to suck air in -it creates a vacuum it is sucking so hard! and the extra work the pump/charger is doing creates heat-lots of it This heat is added to the air coming in and there is a lot less volume of that air (the throttle is closed)
To offset this the Bypass valve is fitted ,it is a recirculation valve -it connects the output air to the intake air and reduces the suction losses by satisfying the charger input air demand.
there is still some heat added to the boost air but it is minimised.
the valve opens/closes when it senses the throttle closed -by vacuum pressure and if it does not full close(Spring pressure) then boost pressure is lost as it is being recirculated.
due to the heating of air when the valve is opened -on throttle opening again a small amount of extra fuel is commanded to prevent lean conditions (yet another thing to take on board with very small pully fitment)
dont know if this helps any?
Old May 28th, 2008, 02:25 PM   #13 (permalink)
DaFlake
DaFlake's Avatar
So basically it just sucks... Sorry, I couldn't resist.
Global Moderator
Old May 28th, 2008, 02:36 PM   #14 (permalink)
MINIMANIAUK
MINI2 Sponsor
Like a 2 dollar wh....
Its always easier to explain in laymans terms,and clear up misconceptions like boost pressure is constant -its not
Old May 28th, 2008, 06:15 PM   #15 (permalink)
M4 CUS
M4 CUS's Avatar
so is there a big benefit in fitting one? performance gains?
Old May 28th, 2008, 06:26 PM   #16 (permalink)
ScottyBoy
Obsessive Car Cleaner OCC
ScottyBoy's Avatar
Online
Nope not big, there is minor benefits mate, i adjusted mine and it was slightly better nothing to scream about in the performance department.
Not that my car is were it should be anyway hey
Old May 28th, 2008, 06:34 PM   #17 (permalink)
DaFlake
DaFlake's Avatar
A little quicker throttle response. That was about it.... I don't really recommend it.
Global Moderator
Old May 28th, 2008, 07:10 PM   #18 (permalink)
M4 CUS
M4 CUS's Avatar
Didn't realise you had one scotty. yep think there is some big time up with urs. are u goin to 1320's on friday to sort it?
Old May 28th, 2008, 07:15 PM   #19 (permalink)
ScottyBoy
ScottyBoy's Avatar
Online
I dont have an uprated one but i have adjusted it so its fully closed when should be.
Ive been, i took the day off work yesterday and went down, All is fine with the car so it must be the mods that i have.
When i get chance the M7 AGS is coming off and stock filter is going back on, and im going for a Milltek and De-Cat.
Old May 28th, 2008, 07:45 PM   #20 (permalink)
GARY GP
GP-1528
GARY GP's Avatar
And a large box of aspirin!!..
Bypass valve s33gav Engine & Drivetrain Tuning 17 Apr 14th, 2008 02:39 PM
bypass valve question Babes Engine & Drivetrain Tuning 25 Jan 31st, 2008 05:32 PM
modified bypass valve Jaw_F430 Engine & Drivetrain Tuning 4 Sep 15th, 2007 09:28 PM
Bypass valve modification BlueMax Engine & Drivetrain Tuning 18 Sep 4th, 2007 04:01 PM
Bypass valve recalibration THE ITCH Engine & Drivetrain Tuning 33 Feb 16th, 2006 09:58 PM
