Performance Torque
Tags: , , , ,
Old Jun 15th, 2008, 09:12 PM   #41
Bhozar
Overly excited!!
Bhozar's Avatar
Local Time: 09:06 PM
Quote: Originally Posted by jhiggs26 (original)
From my NAM reply:
"Thanks for the pic Bhozar. Yeah there's 31 teeth on the 1/2/5/6 mainshaft pinion in your photo(just like my gearbox). The 3/4/R pinion is obstructed in the pic from getting a count. I think you're right though; it seems like it's just the crown wheel gear that's different between these gearboxes.
Simple math tells me that pre-facelift FD ratios are 2.74:1 for 1/2/5/6 and 4.05:1 for 3/4/Reverse.
Facelift FD ratios are 2.87:1 for 1/2/5/6 and 4.24:1 for 3/4/Reverse.
Anybody know if that is right?
Jeremy"
Ratios for both boxes are listed here: http://www.mini2.com/forum/faq.php?d...l&titlesonly=0
United Kingdom Male View Bhozar's Electric Blue & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Jun 20th, 2008, 01:53 AM   #42 (permalink)
jhiggs26
jhiggs26's Avatar
Local Time: 01:06 PM
Ok so for all years if the input shaft, plus all gears and pinion gears are the same then that chart seems off for 3 gears. I only quickly calculated for just the swap of crownwheel gear from 85 teeth(pre facelift) to 89 teeth(post facelift).
I'm calculating facelift gearbox overall ratios for:
1st gear I come to 11.96:1 not 12.789:1(based on my 12 tooth input to 50 tooth 1st gear).
2nd gear I come to 7.52:1 not 7.793:1.
Reverse I come to 11.65:1 not 11.944:1(based on my 33 tooth reverse and 50 tooth 1st gear).
Bhozar do you have any more top down pics of your facelift gearbox? Then we could easily figure out 1st and Reverse ratios.
Jeremy
2004 MCS 15% Alta SC Pulley, Alta Intake, Alta Diverter, Ultrik Cam, CM FW/FX200, OBX Diff, 1 Ball, A Few Powerflex Bushings, Alta Springs, Alta Rear LCA, Rear Seat Deleted, 17 by 7 O.Z. Ultraleggeras, Boost/Vacuum and Oil Pressure Gauges
Canada   Reply With Quote
Old Jun 20th, 2008, 09:12 AM   #43 (permalink)
Bhozar
Overly excited!!
Bhozar's Avatar
Sorry Jeremy, thats the only pictures I have of the gearbox.
Old Jun 21st, 2008, 01:23 AM   #44 (permalink)
jhiggs26
jhiggs26's Avatar
Ok thanks Bhozar.
Your MINI's looking good BTW!
Jeremy
Old Jun 21st, 2008, 11:08 AM   #45 (permalink)
Bhozar
Overly excited!!
Bhozar's Avatar
Ok thanks Bhozar.
Jeremy
Thanks Jeremy!
Contact Tel & Address for MINI UK Customer Services? skyhigh_71 Faults & Fixes 7 Jan 19th, 2005 10:43 AM
5/6 speed boxes ButtonIt General Discussion 1 Sep 22nd, 2003 01:00 PM
Sub Boxes Paul Simonds Interior & Ice 22 Jul 24th, 2002 04:06 PM
