| Tags: clutch, clutchmasters, flywheel, fx200, rmw |
| | #41 |
| Mini2 Sponsor & Tuner Join Date: Jun 2005 Local Time: 01:06 PM
Offline | they have held up to numerous track days and LA traffic... don't know what could be worse on them ![]() Manufacturer and Custom Mini Tuning |
| | #42 (permalink) |
| MINI2 Regular | re: i mean smoothness and durability in terms of comparing the stage 2 kit to the stage 3 kit, trying to decide which to go for. you said the stage 3 was more aggressive and engaging. how do you take payment btw? - paypal? i want the clutch&flywheel. dr. blaze |
| | #44 (permalink) |
| JCW 210 apparently not! Join Date: Feb 2007 Local Time: 09:06 PM
Offline | Have you checked the tracking code on parcel force website? they pick up all USA post normally and managed to hold onto my stuff for ages, just try the tracking code here http://www.parcelforce.com/portal/pw Hope you find it, If you do I will buy it if is over here... |
| | #48 (permalink) |
| MINI2 Regular | re: send it by fedex. from experience, parcelforce tend to "adopt" their packages. fedex even contact you as your item is shipped to organise payment of vat, before it hits the uk, so no time spent in customs. dr. blaze |
| | #49 (permalink) |
| Turbo Schmurbo... Join Date: Nov 2007 Location: Maidenhead Local Time: 10:06 PM
Offline | Just to keep you updated here, haven't noticed anymore issues with slip and break in period is taking slightly longer (due to me having to conserve fuel, most of the maidenhead shell garages are drying up). While were waiting could we discuss good and bad clutch behavior and what some of do day to day to preserve clutch longetivity? ![]() |
| | #50 (permalink) |
| MINI Obsessed... Join Date: Nov 2003 Location: Southampton, Hants Local Time: 09:06 PM
Offline | Less revs, less high torque pull aways. Once you master that you will be use to people beeping you for being so slow. To be serious.... just dont do really harsh pull away and accelerate hard when the clutch is up and not during gearchanges. Match revs both up and down changes. But most of all..... have fun!! Its a waste of money if you are going to cruise around, you should have just left it stock otherwise. |
| | #51 (permalink) |
Offline | I uprated this one because the stock clearly couldn't cope, I open it up on the right roads but in day to day traffic cruising is the way to go ![]() I was thinking on a basic level, for example... is sitting at the lights with your foot on the clutch, in gear while waiting or stick it neutral. I ask this as when in neutral the flywheel chatters on idle but when the clutch is depressed it goes away... |
| | #55 (permalink) |
| MINI2 Newbie Join Date: Jun 2008 Local Time: 01:06 PM
Offline | It's our sprung clutch discs slapping back and forth-that's all. So yes I have clutch chatter. At rest manual cars should be in neutral with the driver at the ready(left foot and right arm for us guys across the pond). There's no need to wear out your clutch release bearing or put extra time logging thrust on the crank thrust surfaces with the clutch depressed. You should only select a gear when you want to move or are moving! ![]() Jeremy 2004 MCS |
| | #56 (permalink) |
| Overly excited!! Join Date: Aug 2006 Location: Worcestershire Local Time: 09:06 PM
Offline | I have the chatter too with my FX300, but I was expecting that. The clutch pedal is a lot lighter than it was before, but I have only driven the car for 5 minutes so far. |
| | #57 (permalink) |
Offline | Thats news im hoping for on mine too! If the 400 is going to be really aggressive then I need to the pedel to be much lighter as mines like doing leg weights! |
| 1320 Steering Bushes | TRISTO | Engine & Drivetrain Tuning | 17 | Apr 9th, 2008 09:16 PM |
| New found HP thanks to 1320 Autos | Ruskins JCW | Engine & Drivetrain Tuning | 7 | Mar 31st, 2008 06:56 PM |
| Big thanks to 1320! | Edenalig | Engine & Drivetrain Tuning | 9 | Dec 10th, 2007 07:49 PM |
