Tags: , , , ,
Old Jun 19th, 2008, 01:50 PM   #61
batou
Turbo Schmurbo...
batou's Avatar
Local Time: 10:10 PM
Quote: Originally Posted by sayanthan (original)
what about the exedy clutch/flywheel combinations - how have people found that - i realise this is more expensive-do they get chatter too?
I would imagine this is the case with most solid mass flywheels, can't comment on the exedy all I can say is this one is coming along nicely and the car is more nicer drive for it
235+ BHP "Works" Eater
United Kingdom Male View batou's Dark Silver & Black 1st Gen MINI Cooper S Profile   Reply With Quote
Old Jun 19th, 2008, 02:05 PM   #62 (permalink)
batou
Turbo Schmurbo...
batou's Avatar
Quote: Originally Posted by jhiggs26 (original)
Yes that chatter is there too but I don't like to lug the motor often.
At least 50 more stop and go miles and you're there Batou!
Jeremy
When you say lug? Do you mean letting the engine "bog down" like its pulling from a too low RPM that it would want? (Sorry language barrier lol).
If so thats not something I'm letting it do, its usually at the lowest revs before the engine starts "bog down" or "lug" if it is what I think when it chatters, only really with light throttle.
Old Jun 19th, 2008, 03:10 PM   #63 (permalink)
blaze6
blaze6's Avatar
re:
i'm sure it is - i've ordered the fx300 from jan. the main factor for me was cost, they seem to be the best value for money.
if you compare clutchmasters to exedy, i think exedy is slightly better quality:-
exedy (£900-1000) clutchmasters (£550 delivered incl vat)
flywheel: chrome-moly (5.8kg) vs. aluminium (6kg)
pressure plate: forged aluminium casting - ?firmer pedal feel? vs. ductile iron casting
i understand forged aluminium is stronger than iron/steel pressure plates, ?higher clamping pressures?
drive plate ceramic/metallic vs. kevlar/metallic up to stage3,ceramic from stage4
fidanza flywheel - aluminium - weight 5kg (cooper s) 3.6kg (one/cooper)
interestingly everyone seems to report lighter pedal feel with clutchmasters when on the clutchmasters website they state you should expect a slightly firmer pedal feel. similarly, they state you should only expect chatter with the stage 4 kits, not the other kits.
Clutchmasters.com - High Performance Clutches and Flywheels
can't find much on mini2 about the hyperexedy, i have pm'd someone that's got it. i think roland mentioned in one of the threads that it's quieter, little or no chatter. but i guess you're paying for it! and the pedal is v.v.firm!
dr. blaze
Old Jun 20th, 2008, 12:08 AM   #64 (permalink)
jhiggs26
jhiggs26's Avatar
Local Time: 01:10 PM
Yeah that's what I meant. Rolling and staying in 2nd(not D clutching down to 1st gear). At low speed(1st gear) tight turns you can hear the worm gears in the OBX doing there thing.
Jeremy
2004 MCS 15% Alta SC Pulley, Alta Intake, Alta Diverter, Ultrik Cam, CM FW/FX200, OBX Diff, 1 Ball, A Few Powerflex Bushings, Alta Springs, Alta Rear LCA, Rear Seat Deleted, 17 by 7 O.Z. Ultraleggeras, Boost/Vacuum and Oil Pressure Gauges
Canada   Reply With Quote
Old Jun 20th, 2008, 09:21 AM   #65 (permalink)
Bhozar
Overly excited!!
Bhozar's Avatar
Local Time: 09:10 PM
You have to really listen to hear the chatter in mine. I was told that when replacing a worn clutch, the pedal will be lighter. As I had everything else replaced in the gearbox with new parts, and everything has been greased, then that wouldnt surprise me.
United Kingdom Male View Bhozar's Electric Blue & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Jun 20th, 2008, 11:05 AM   #66 (permalink)
batou
Turbo Schmurbo...
batou's Avatar
Gave a bit of stick yesterday (now i'm over 500 miles on it) and there might be little a bit of slip in 1st but then again my tyres are worn so more than likely wheel-spin (max revs on launch were 3000).
Also I was stuck in stop start traffic on an exit ramp yesterday (failed lights) and made a habit of putting it in neutral and clutch out at every stop, however as I got further up the hill the clutch was feeling slightly shorter and slipping a little. Once I got moving on the next bypass there were no problems at all... weird.
Bhozar, my crankshaft vibration damper is worn and made some noise previously. Maybe this is amplifying the chatter somewhat, you can hear the flywheel rattle when the engine slows down on overrun too.
Old Jun 20th, 2008, 12:27 PM   #67 (permalink)
Bhozar
Overly excited!!
Bhozar's Avatar
I wonder if a worn crankshaft damper would cause more damage than no crankshaft damper? If its not 100% true and balanced, I would be worried about it.
Old Jun 20th, 2008, 01:27 PM   #68 (permalink)
batou
Turbo Schmurbo...
batou's Avatar
Hmm certainly is food for thought, Chris didn't think it was bad enough to warrant immediate attention but more likely to get done when I next get some work done.
Old Jun 20th, 2008, 01:56 PM   #69 (permalink)
Bhozar
Overly excited!!
Bhozar's Avatar
Personally, I would be more worried about a balanced crank pulley, than an undamped crank pulley.
Old Sep 23rd, 2008, 01:09 PM   #70 (permalink)
r1_kde
JCW 210 apparently not!
r1_kde's Avatar
My clutch finally gave up today, I am going to ring Jan today (when its not 5:35am his time) I am although slightly concerned about the lightened fly wheel, is the chatter loud? or is it just there?
Am I worrying about nothing? also is there any idea of the life of the FX200 clutch?
Old Sep 23rd, 2008, 01:18 PM   #71 (permalink)
Bhozar
Overly excited!!
Bhozar's Avatar
The flywheel does chatter, but only when in neutral. Personally, I rarely notice it these days, and if I do I usualy hum the Airwolf theme tune (Sounds a bit like a distant helicopter)
I'm still very happy with my FX300 and love how free-reving the flywheel is. I dont have a problem with RPM dropping when changing gear, but I am a fairly quick changer.
when I had mine done, I decided it was a good time to get think mini to also fit a Quaife ATB (LSD) as the gearbox was out. Which might be worth considering. Just make sure whoever fits it uses quality diff bearings like TM.
14.438 @ 98.53
Old Sep 23rd, 2008, 02:06 PM   #72 (permalink)
Revolution Mini Works
Mini2 Sponsor & Tuner
I'm ususally up at 5:30am
Manufacturer and Custom Mini Tuning
1320 Steering Bushes TRISTO Engine & Drivetrain Tuning 17 Apr 9th, 2008 09:16 PM
New found HP thanks to 1320 Autos Ruskins JCW Engine & Drivetrain Tuning 7 Mar 31st, 2008 06:56 PM
Big thanks to 1320! Edenalig Engine & Drivetrain Tuning 9 Dec 10th, 2007 07:49 PM
Congrats 1320! BigShow Engine & Drivetrain Tuning 6 Nov 15th, 2007 09:27 AM
