Visit Mini Mania UK
Old Oct 1st, 2002, 08:36 AM   #1
coops41
Local Time: 07:14 AM
Adjustable Camber ?
Is any one aware of a camber kit available for the mcs? IF so where from and how much.
There is no provision std and i do the odd track day the outside edges of my tyres look very second hand not to mention lost time .I'm in australia but happy to import kit from anywhere?
THANKS IN ADVANCE
Australia   Reply With Quote
Old Oct 1st, 2002, 08:47 AM   #2 (permalink)
Racer
Sponsor,Moderator & Racer
Racer's Avatar
Local Time: 10:14 PM
Send a message via ICQ to Racer
Mini spares have them
http://new.minispares.com/NewMiniSuspension.cfm
Also check LizzieB's signature for link to New Mini Sport which also does them in the UK
JCW Club Sport Kawasaki Green / White
Unofficial John Cooper Challenge Site
View Racer's Kawasaki Green & White 1st Gen MINI Cooper Profile   Reply With Quote
Old Oct 1st, 2002, 08:49 AM   #3 (permalink)
Racer
Racer's Avatar
Re: Adjustable Camber ?
I'd check your tyres pressures before anything else since the JCW cars run std camber as std for racing and we don't have 'that' much of an issue with uneven wear or needing more neg camber (emphasis on that)
I've done temp test on the tyres after hard sessions and with the right settings you can get a fairly even distribuition (5degrees max difference) which would suggest camber change is not neccessary
Old Oct 2nd, 2002, 06:23 AM   #4 (permalink)
coops41
Thanks RACER
will contact minispares.
I assume you are racing one of the jcw cars?
I ran my tyres at about 38/40 cold this increased to the high 40's after 4 laps i was told to try and keep the hot psi to no more than 45 so i adjusted them through out the day PS the tyres were yokahama ao32r semi race.
What pressures have you found to work best? have done a lot of asking but every one just seems to be guessing. Left front tyre was very scolloped by end of day.
Look forward to your response.
Old Oct 2nd, 2002, 07:11 AM   #5 (permalink)
Racer
Racer's Avatar
Thanks RACER
This is WAY too high even for yoko a032's - You should be looking at hot pressure of mid to late 30's at the most ie the pressure the tyres are designed to work at best on the MINI -
INvest in a pyrometer (you can get cheap ones) and keep checking the inside mid and outside temp of the tyres with different pressures
If the mid temp is much higher than outsides then pressure is too high if the mid is much lower than outside pressure is too low etc. Only if the outside temp is much higher than the mid and inside should you need to alter the camber
Regards
Racer
Old Oct 2nd, 2002, 04:28 PM   #6 (permalink)
chigh
Local Time: 04:14 PM
camber adjustment
I've done three lapping days and one autocross with almost no wear outside normal tread. National champ Garfield suggested using 38f, 38r. Club racer from Chicago says the same, no camber change needed.
Old Oct 4th, 2002, 07:43 AM   #7 (permalink)
Keith
Keith's Avatar
Local Time: 09:14 PM
Rogue engineering (http://www.rogueengineering.com/Merc...egory_Code=SUS) has adjustable rear control bars in production for tweaking the camber on the S. I am waiting for these to be ready before I lower my car.
2007 DS/W MCS LSD, sport suspension, Enkei RPM2 wheels
2002 EB/W MCS Sport package, Rogue intake, Borla exhaust, 15% pulley & Madness sway bar
Old Oct 7th, 2002, 06:06 AM   #8 (permalink)
coops41
chigh 38/38 are theese cold inflations? as this is very simular to what i was running.
The other thing is in auto cross you dont get the sustained high g's and there for wear rates would be better.
Other cars ive owned have always benifited from neg camber on the front wheels i still think there are definate gains to be made.
Old Oct 7th, 2002, 10:30 AM   #9 (permalink)
chigh
coops41 question
Yes, cold pressures. The tracks I drove were Blackhawk and Road America. Very different, but still a lot of right turning. I am using stock Dunlop Sp SPort 9000 runflats. These will make some noise near their limit of traction, the car will push a bit - if you add throttle the tires will scrub as the car understeers. Total miles probably around 300+. No problems with wear. I did rotate the left side as the left front had more wear than the left rear, but I'd have to say it's minimal. Softer tires will show the wear sooner. I'm happy with this set up.
Old Oct 16th, 2002, 03:38 PM   #10 (permalink)
marc.c
marc.c's Avatar
adjustable camber
h&r are doing camber adjusters.not sure if they do mini fitments yet as they have just been released.as far as i know they replace the top bolts on the damper-mounting base and each bolt has a lobe,this allows a +/-3 degree adjustment by rotating the bolt through 180 degrees pushing the wheel and hub assembly in or out.they cost £29 for the pair through motorsport wheels [uk].i really dont know how effective these would be. but i know someone on this forum will soon tell you. good luck.
Scotland   Reply With Quote
Perfect Camber GTT 280 Suspension 15 Jun 14th, 2005 10:22 AM
adjustable front camber coops41 Engine & Drivetrain Tuning 6 Jun 19th, 2004 03:22 AM
Camber plates? ibsen MINI in Motorsport 44 May 27th, 2004 03:29 PM
Camber Plates TheBlackKnight MINI Cooper 0 Mar 24th, 2004 11:16 AM
adjustable front camber/caster jlm Engine & Drivetrain Tuning 82 May 7th, 2003 10:16 AM
