Visit Derek Woodman MINI
Old Feb 18th, 2003, 01:41 AM   #21
alta2
Local Time: 09:17 PM
911ETR,
Since water is such a good heat sucker upper, it makes the intercooler much more effeciant. Remember, all the intercooler does is exhange heat, so any thing like a water sprayer, bigger intercooler, or water injection will help this.
So the HP gained is from the colder denser air, that will enter the engine.
Old Feb 18th, 2003, 01:50 AM   #22 (permalink)
paulmon
MINI2 Senior Derelict
paulmon's Avatar
Local Time: 05:17 PM
Send a message via MSN to paulmon
"heat sucker upper" I love it! Even if this doesn't make huge gains it is just too cool!
How hard are the silicone hose couplers to put in?
Paul
Canada View paulmon's Dark Silver & Black 1st Gen MINI Cooper S Profile View paulmon's MINI Profile Images   Reply With Quote
Old Feb 18th, 2003, 06:39 AM   #23 (permalink)
911ETR
911ETR's Avatar
Local Time: 01:17 PM
Originally posted by alta2
911ETR,
Yes I agree that this will help in the heat soaked days no doubt but again this is not going to give you any more power over when the car is cold in the morning. You are not going to flick a switch and get 20hp unless you already lost the 20hp from heat.
The only reason for larger intercoolers is to keep the heat away so you can run more boost. The more boost is where you are actually getting your power.
Anyway I am eagerly awaiting your kit since I have ordered it. Whats the ETA to my door?
Old Feb 18th, 2003, 01:14 PM   #24 (permalink)
paulmon
paulmon's Avatar
Bryan, let us know when you get it. Won't do me much in the Winter but when it's 32c outside this summer it can't hurt, and it just looks too cool!
How much of a bad thing would it be if you sprayed windshield washer fluid on the intercooler? (assuming you forgot to put water)
Paul
Old Feb 18th, 2003, 01:50 PM   #25 (permalink)
paulmon
paulmon's Avatar
obehave, good point. I can also see a windshield washer fluid with a high alcohol content turning your car into a ball of fire. Granted you wouldn't have to worry about deposits on your intercooler fins in this case. HAha
Paul
Old Feb 18th, 2003, 06:07 PM   #26 (permalink)
alta2
911ETR, you are right, you will not all of a sudden get a 20hp boost when the water is spraying. But on a hot day you should definately see a drop in intake temp with the water running. Which does increse HP, by how much, that is hard to say with out running it on the dyno.
Your splitter should be to you by the end of the week! please let call at let me know what you think!
Old Feb 18th, 2003, 10:35 PM   #27 (permalink)
911ETR
911ETR's Avatar
Thanks Jeff, I am excited to test it.
Old Feb 18th, 2003, 10:40 PM   #28 (permalink)
paulmon
paulmon's Avatar
Keep us posted 911ETR.
Paul
Old Apr 9th, 2003, 04:02 AM   #29 (permalink)
TonyB
Don MINIo
TonyB's Avatar
Local Time: 02:17 PM
Summer = Resurrection
Ok 911ETR, with the hot days not so far off, what's up???
I've been having dreams about finally rigging that open toggle for something trick like this
I think you've had this product for almost 2 months... Maybe it is a secret weapon you want to keep to yourself Share with your MINI brethren!
'03 (9.6.02) MCS IB/W Lapis Blue Leather
Mission = 10:1 (Weight:HP)
United States View TonyB's Indi Blue & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Apr 9th, 2003, 10:08 AM   #30 (permalink)
L8 Apex
Posts: n/a
would it be possible to design the Alta spray kit to wire up to the empty toggel switch? That would be seriously cool.
-Andrew
Old Apr 9th, 2003, 10:51 AM   #31 (permalink)
TonyB
Don MINIo
TonyB's Avatar
Sure, at least I don't forsee any problems with doing so
And with that, the up position is a manual blast, and the down position is simply on - with some type of control/relay that spits out water every 30 seconds, or so...
First need to find-out what the dyno is saying...
Old Apr 9th, 2003, 04:40 PM   #32 (permalink)
911ETR
911ETR's Avatar
Re: Summer = Resurrection
Well guys to be honest the diverter looks cool but is very heavy compared to the stock ABS plastic. It’s a well made piece but No offense Alta but the water spray is a joke. Not in general but in this kit. I would like to see a real intelligent water spray system. This seems to be a hack job. Directing more air to the intercooler helps but only when you’re moving. How much air you’re actually seeing vs. stock is hard to tell since temps change faster than I can install it back to stock. Let’s just say with out the water spray it’s not really noticeable.
I have not even tried the water spray because I refuse to get rid of my rear windshield wiper. I gotta see out of it If there is a revision to the product then I might try the water spray but I have actually talked to several other manufactures that are coming out with intercoolers that won’t need it. I can’t really comment on it more until they are released.
Alta,
I think you’re on the right track, complete this kit, make the diverter a bit lighter and you will have the market for a low cost solution.
Giddy up
Old Apr 9th, 2003, 04:44 PM   #33 (permalink)
911ETR
911ETR's Avatar
No use in doing this fella's, just need an intelligent system like the one MRT sells that gives water when the intercooler needs it at certain RPM's.. Something programable would be nice.
I have seen the insides of that switch and its not real nice looking Save the switch for your ejector seat.
Old Apr 10th, 2003, 01:59 AM   #34 (permalink)
TonyB
Don MINIo
TonyB's Avatar
Ok, I'll leave open that open toggle for now...
MRT? I will do some research...
At certain RPMs would be nice, but also with a defeat option, or a separate manual option I think would be nice. And if not, the ability for the end user to set the desired RPM trigger...
That is what I envision...
Thanks!
Old Apr 11th, 2003, 02:09 PM   #35 (permalink)
lotoole3
MINI2 Irregular
lotoole3's Avatar
Send a message via AIM to lotoole3 Send a message via Yahoo to lotoole3
Here's some info on an intelligent intercooler spray system, installed on an S4...
http://www.autospeed.com/cms/article.html?&A=0578&P=1
lotoole3
2005 JB/B MCS :: Motoring since 8.22.04
2002 DS/B MCS :: RIP due to flood 8.1.04
United States View lotoole3's Dark Silver & Black 1st Gen MINI Cooper S Profile   Reply With Quote
Old Apr 11th, 2003, 11:15 PM   #36 (permalink)
TonyB
Don MINIo
TonyB's Avatar
Maybe it is just my home pc this morn, but I can't see that link... I'll try at work though. Thanks!
Old Apr 12th, 2003, 12:53 AM   #37 (permalink)
TonyB
Don MINIo
TonyB's Avatar
The link does work, and that is indeed something MCS owners would ponder... Not in time for this summer though
Old Apr 19th, 2003, 02:58 AM   #38 (permalink)
alta2
911ETR,
I am sorry that you don't like the diverter, or at least the water sprayer part. Maybe you didn't see how our kit comes with the tee so you can use both the rear washer and water sprayer at the same time. In the instructions we give 2 options to hook it up, one using a tee so there is no disconnection of the rear wiper and a second which disconnects the rear wiper.
As for the weight, our part is steel vs. plastic so yes it is heavier. But assuming that the plastic hood trim was removed per the instructions then the total increase in weight is less than 1/4 pound! I am truly convinced this won't affect the handling of the car. The plastic diverter wieghts .875 lbs, and the plastic part that is bolted to the hood wieghts 1.875 lbs. Together both weight 2.75 lbs. Our diverter weights 3.0lbs so the difference is .25lbs.
Our diverter will not come with the electronic trigger system like MRT sells and for one simple reason......cost! (On a side note we have several of the MRT units here if any one is interested in trying it out on the MINI.)Our diverter with the electronic sprayer would retail for more than $600! This would definatly put off many customers that can get nearly equal benefit from an investment of only $179.99. Offering each part seperately may attract some customers because they could buy the basic kit for $179.99 then upgrade to the "electronic trigger system" for somewhere around $400. Add a seperate water tank and the cost soars to over $600! While not on the top of our list of priorities a sub-system is in development and may released as early as December of this year.
Everyone should keep in mind that the water spray is a great addition to the diverter itself. The diverter without any type of water spray will still improve airflow over the intercooler tremendously. In warmer climates the difference is more significant but, for prolonged higher boost situations (canyon carving, drag racing, track time etc.)the diverter will help maintain reasonable inlet temperatures. At the same time it is a great dress up item for your next MINI meet. The water spray is truly beneficial and should be used whenever situations dictate an added blast of cold air! The results are instantaneous and great for the next stop light competition, drag race, or for that added edge when passing on a mountain twisty! The water tank in the vehicle supplies water to the rear and front washer squirters. There is a low tank warning lamp on your MINI from the factory to prevent usage when water supplies are low.
Also, one additional side note. Our large top mount intercooler that 911ETR refers to above does come with a different diverter and sprayer. It is different only because it has to be larger and different shaped to clear the larger intercooler. Pics can be found on the intake comparo thread elsewhere on this website. MSRP is $999.99 for the intercooler, diverter, sprayer etc. They will be shippable in about 2-3 weeks. See us or your local ALTA MINI Dealer for more info (Mini-Motorsport, Vivid Racing etc.)
If anyone has any other questions regarding this or any other ALTA MINI Performance part please let me or our staff know. We aim to help!
Jeff Perrin
www.altaminiperformance.com
Old Apr 19th, 2003, 10:20 AM   #39 (permalink)
macncheese
Send a message via AIM to macncheese Send a message via Yahoo to macncheese
What sort of gains would my $1,000USD net me?
Cheese
United States View macncheese's Dark Silver & White 1st Gen MINI Cooper S Profile   Reply With Quote
Home made intercooler water spray Rigsey Engine & Drivetrain Tuning 22 Aug 6th, 2007 07:50 AM
BBR Twin high flow Intercooler kit G-Man Engine & Drivetrain Tuning 2 Feb 23rd, 2007 12:15 AM
New GTT Intercooler Spray System +pics roland2003 GT Tuning 17 Jan 6th, 2006 12:45 PM
Large Intercooler / Closed Intercooler GTT 280 Engine & Drivetrain Tuning 7 Aug 22nd, 2005 11:06 PM
Intercooler Spray TimboK Engine & Drivetrain Tuning 6 Sep 21st, 2003 10:58 AM
