Old Dec 6th, 2002, 06:52 PM   #1
DerekR
Local Time: 04:13 PM
OBD-II Software
I've come across several OBD-II software/interface/scan tool offerings on the 'net - do any of them have significant advantages over the others? In particular, are any of them able to reset the Restraint System light if I disconnect the airbags for competition use and subsequently reconnect them after the event?
I'd appreciate hearing from anyone who owns these tools as to their pros and cons so as to make a decision on whether to get one and which one to get.
Barbados   Reply With Quote
Old Dec 6th, 2002, 11:56 PM   #2 (permalink)
BobFischer
Local Time: 02:13 PM
I haven't used any of the OBDII programs yet. I am A little partial though due to the responses from another car club. I also know the developer since he is local and is a very meticulous person.
So checkout The Pocketlogger
It is a Palm OS program so you don't need to haul your laptop around.
Bob
'03 DS/DS MCS
Old Dec 7th, 2002, 12:55 AM   #3 (permalink)
macncheese
Local Time: 05:13 PM
Send a message via AIM to macncheese Send a message via Yahoo to macncheese
I use pocketlogger. Its a pretty neat setup.
Cheese
United States View macncheese's Dark Silver & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Dec 7th, 2002, 08:48 AM   #4 (permalink)
DerekR
Thanks - I've had a look at the site. Seems like a good product. Mac - any limitations on transferring data to a PC?
Derek
Old Dec 7th, 2002, 09:12 AM   #5 (permalink)
Racer
Sponsor,Moderator & Racer
Racer's Avatar
Local Time: 10:13 PM
Send a message via ICQ to Racer
Cheese
macncheese
Whats the full extent of the information this can capture is there a list of capture data or do you have some raw(csv) data I could look at - It seems a great tool but what info can it collect?
JCW Club Sport Kawasaki Green / White
Unofficial John Cooper Challenge Site
View Racer's Kawasaki Green & White 1st Gen MINI Cooper Profile   Reply With Quote
Old Dec 7th, 2002, 09:18 AM   #6 (permalink)
BobFischer
I just email Mike @ Pocketlogger to let him know about this thread. Hopefully he'll have time to pop in and help with some answers.
Bob
'03 DS/DS MCS
Old Dec 7th, 2002, 09:23 AM   #7 (permalink)
jlm
here is another one I'm just trying out: www.obd-2.com
oops! i fuggot dat d in der! thanx bob
john
Old Dec 7th, 2002, 10:36 AM   #8 (permalink)
macncheese
The nice thing about pocketlogger is that it tests the interface and makes adjustments to maximize your sampling rate. I can sample 20 readings per second with mine, as opposed to 6-8 which is standard. Pocketlogger only reads the standard OBD stuff.
Calculated Load Value
Engine Coolant Temperature
Short Term Fuel Trim - Bank 1
Long Term Fuel Trim - Bank 1
Short Term Fuel Trim - Bank 2
Long Term Fuel Trim - Bank 2
Fuel Pressure (Gage)
Intake Manifold Absolute Pressure
Engine RPM
Vehicle Speed
Ignition Timing Advance
Intake Air Temperature
Air Flow Rate from MAF
Absolute Throttle #1 Position
Oxygen Sensor - BANK 1 - Sensor 1
Oxygen Sensor - BANK 1 - Sensor 2
Oxygen Sensor - BANK 1 - Sensor 3
Oxygen Sensor - BANK 1 - Sensor 4
Oxygen Sensor - BANK 2 - Sensor 1
Oxygen Sensor - BANK 2 - Sensor 2
Oxygen Sensor - BANK 2 - Sensor 3
Oxygen Sensor - BANK 2 - Sensor 4
Dave
æ
Old Dec 7th, 2002, 10:47 AM   #9 (permalink)
BobFischer
If anyone has any insight into the vehicle specific OBDII parameters, I can work with Mike at Pocketlogger to try to implement these.
Bob '03 DS/DS MCS
Old Dec 7th, 2002, 12:08 PM   #10 (permalink)
DerekR
Bob -could you ask Mike what specifically he'd need to implement MCS- specific parameters or add-ons to Pocketlogger?
Derek
Old Dec 7th, 2002, 12:40 PM   #11 (permalink)
BobFischer
Originally posted by obehave
Is it just me or is there a lot of dead links on their page?
Couldn't get the cabling guide or the quick guide links to work.
Just went to the site and the 'Quick Guide' works for me. Don't where you are talking about for the 'Cabling Guide' I didn't see one.
Bob
'03 DS/DS MCS
Old Dec 7th, 2002, 12:59 PM   #12 (permalink)
Racer
Racer's Avatar
macncheese - Thanks
Anyone an idea if pocketlogger will continue to enhance - I want to buy a logger that I know will continue to be developed and take feedback from customers - from the sound of it pocket logger do this
Old Dec 7th, 2002, 01:04 PM   #13 (permalink)
BobFischer
Originally posted by Racer
macncheese - Thanks
Mike at Pocketlogger is really good about product support, I think it is his sole source of income. He is always looking into ways to improve it and takes heed to requests for features.
Bob
Old Dec 7th, 2002, 01:12 PM   #14 (permalink)
BobFischer
Derek
Here is Mike's response:
It would really be the whole exact data stream. There are high level
protocols in the OBDII standard to send proprietary data through the OBDII
port, but what data is sent using these protocols is entirely up to the
manufacturer.
-Mike
He said that you'ld pretty much have to tap into the data stream, send a request, log the protocol request, and log the reply. You probably have to do this for each available response.
Bob
'03 DS/DS MCS
Old Dec 7th, 2002, 02:46 PM   #15 (permalink)
Andy@Ross-Tech.com
Andy@Ross-Tech.com's Avatar
Send a message via AIM to Andy@Ross-Tech.com
There is a huge difference between generic OBD-II and manufacturer-specific diagnostics. One of the most notable differences is in the variety of different control modules supported for diagnostics. Typically, OBD-II is merely concerned with engine and transmission, and only those items that affect emissions.
In my MINI, there are approximately 20 different control modules (computers) for various systems in the car, like engine, abs, airbags, instruments, dsc, bc1, etc. OBD-II barely scratches the surface on the engine modules and does nothing with the rest of the modules.
It is a VERY daunting task to emulate the factory diagnostic tools due to the incredibly huge range of possible functions and responses. Additionally, controller timing is critical and must be carefully maintained.
The company I work for has done approximately 3,000 man-hours of development on a VW/Audi diagnostic tool and is currently developing a similar system for BMW/MINI. Here's a real-world comparison between OBD-II testers and a manufacturer-specific scan tool:
http://www.ross-tech.com/vag-com/dtc-comparison.html
We don't yet have a timeframe or pricing information available for BiM-COM, but feel free to check in on our Yahoo discussion group:
http://autos.groups.yahoo.com/group/BiM-COM/
The group is new, so hardly any discussion yet. For our VW/Audi product, we have a very active discussion group with over 2,000 participants:
http://autos.groups.yahoo.com/group/VAG-COM/
'03 MCS every option+Helix/P&D+One-Ball+HAI+Enkei+Falken
The Unofficial MINI 1/4 Mile Dragracing Database
Old Dec 7th, 2002, 04:24 PM   #16 (permalink)
DerekR
Andy - what are your objectives with the BMW/MINI tool? Are you aiming to offer owners an alternative to the R50 software? And, if so, how much scope for changing parameters - like fuel and ignition maps?
Is it PC or Palm?
Derek
Old Dec 7th, 2002, 04:56 PM   #17 (permalink)
Andy@Ross-Tech.com
Derek,
It will almost certainly be PC-based. Despite the fact that I am a Palm-junkie, PC's are WAY more powerful and standardized than any handheld platform. Real Windows (ie, Win95 and newer, NOT any PocketPC/WinCE stuff) is the standard for software around the world. A good laptop for diagnostics use only costs a couple hundred dollars these days.
I believe the first objectives are to provide the ability to read, interpret and clear error codes. Following that, data logging of measuring groups will be added. The more advanced stuff will come later.
Take a look at the revision history for VAG-COM to see how that product progressed over time:
http://www.ross-tech.com/vag-com/revisions.html
In the VW/Audi world, the top-gun factory tools are the VAS-5051 and VAS-5051. They cost about $15,000 and $5,000, respectively. VAG-COM is highly competitive with those systems at a fraction of the price:
http://www.ross-tech.com/vag-com/vag-functions.html
In the BMW/MINI world, the top-gun factory tool is the MoDiC 4 GT1 scanner, which is basically unobtainium. Each one is owned by BMW and is leased to dealers. The ealier MoDiC's had far less functionality and are not too useful with MINI's.
Old Dec 8th, 2002, 07:23 AM   #18 (permalink)
DerekR
Andy - thanks for the information. Do you have ANY idea of time frame for the initial release - like 3 months, six months? Of all the OBDII offerings I've looked at so far yours seems the most MINI-specific. Now if you could lean towards features (like graphing) that are slanted at performace in subsequent upgrades..... you'd have a winner, I think.
Is there a GT3 computer available from BMW?
Derek
Old Dec 8th, 2002, 07:44 AM   #19 (permalink)
Racer
Racer's Avatar
I've gone for pocketlogger short term until Andy gets things moving - Keep us all informed please Andy and I concur with Derek need performance related and graphing to make life easy for us guys on the track!
Old Dec 8th, 2002, 09:58 AM   #20 (permalink)
Andy@Ross-Tech.com
Data logging and graphing should be part of the system. We've had logging capabilities in VAG-COM for a long time, but haven't implemented graphing for a rather non-technical reason. Our users seem to all have different ideas about the appearance of the graphs/gauges. We'll be releasing an addition to VAG-COM that will allow the user to tailor the appearance (scaling, etc.) to his/her needs.
It should be noted that what we make for VW/Audi and what we will be making for BMW/MINI are completely different from OBD-II. OBD-II systems certainly have their place, and I own two of them, but only for use with cars like my brother's Accord or my friend's Cherokee. Manufacturer-specific diagnostic tools provide a MUCH larger and diverese amount of information. BMW has traditionally kept their diagnostics and the OBD-II diagnostics completely separate. In fact, from 1996-2001, they retained their proprietary round diagnostic port under the hood as well as the standardized 16-pin OBD-II port inside the car. The OBD-II port couldn't access any of the BMW-specific stuff. Only in 2002 did the round port finally go away, allowing the 16-pin port to handle both OBD-II and BMW functions.
how do i get at the OBD port! give me more Engine & Drivetrain Tuning 3 Jul 10th, 2007 10:08 AM
OBD II in Australia AndrewH Australia 10 Mar 18th, 2004 02:43 AM
OBD 2 adapter? nulltty Engine & Drivetrain Tuning 1 Jan 12th, 2004 05:01 AM
OBD interface and protocol Ratty General Discussion 3 Nov 6th, 2003 01:10 PM
OBD-II Software NEMINI Engine & Drivetrain Tuning 7 Oct 28th, 2002 03:32 PM
