| | #21 |
| MINI2 Regular Join Date: Jan 2002 Location: philadelphia area Local Time: 05:12 PM
Offline | otherwise I'm taking my dyno and going home! |
| | #24 (permalink) |
| MINI2 Master Join Date: Aug 2002 Location: ny,ny Local Time: 04:12 PM
Offline | cheese: do show up, you may be the only engineer among a bunch of Yunicks! it will be interesting, I can assure you of that. Helix is advertising it as an open house, with the option of dyno runs. john |
| | #28 (permalink) |
| MINI2 Master Join Date: Jun 2001 Location: Philadelphia, PA, US Local Time: 09:12 PM
Offline | Good time Nice seeing you folks at the dyno day. Could have been a bit warmer out but you can't have everything I guess. I departed early so I did not see other cars up on the dyno. Any interesting results? You can see pics and AVIs from the day at my web site. See ya Jason Jason Livingood | personal web site 2002 DS/W MINI Cooper S Thank you for signing my rear fog light petition. Now we have rear fogs! :-) |
| | #32 (permalink) |
Offline | Re: re: Dyno Day Shouldn't be too hard, should it? I mean it is just a differential right? I know when I had a Quaife installed on my VW Corrado VR6, it was not a terrible operation. I happened to need a new clutch at that time and chose to have a new one installed. In addition, I had my transmission rebuilt at that time as well but then I had 100,000 miles on the motor at that time. Since the MCS is nearly factory fresh I'd think you could keep the stock clutch and not touch the tranny (wrt rebuilding it). Depending upon the power the clutch is ultimately rated for you may want an upgraded one. The only other thing some people seem to do when they are in there is to pull the flywheel and lighten that. A Quaife is a wonderful, wonderful thing! Jason Jason Livingood | personal web site 2002 DS/W MINI Cooper S Thank you for signing my rear fog light petition. Now we have rear fogs! :-) |
| | #34 (permalink) |
Offline | here is a repeat posting of my readings for 11/14 and 12/14: Evotech chip, rogue intake and exhaust, 16" OZ Superleggera, Toyo T1. car has sunroof, nav, stereo with 25 lbs of dynamat!. Weight was with 165 lb driver, 1/4 tank gas and measured on a scale, not estimated. The tires and exhaust lose about 75 lbs from stock. john Last edited by jlm : Dec 17th, 2002 at 08:00 AM. |
| | #36 (permalink) |
| MINI2 Senior Join Date: Jun 2002 Location: Sunnyvale, Ca. Local Time: 01:12 PM
Offline | Not a good Dyno showing JLM, Did your results go down from the baseline test or am I reading the chart wrong? retroom 2003 MC,LY/W, sport package, wht wheels, cruise, chrome, Kaleido cloth/black, OB computer |
| | #37 (permalink) |
Offline | the results on 12/14 were lower in value than on 11/14, however, you must bear in mind that ambient conditions were considerably different. The relevant information is that the curves are so similar and the numbers for 12/14 were very close to the numbers other cars measured the same day. since my car had considerable mods and it is making virtually the same hp as the two stock cars, the conclusion seems to be that the mods are doing nothing. It is also possible that the dyno is somehow producing the notch and maybe skewing all the results, however the curve similarity between 11/14 1nd 12/14 and the similarity of the stock runs seems to indicate the numbers are valuable for comparison. john |
| ECU Tune Dyno Graphs - S. Fla dyno day | ignote | Engine & Drivetrain Tuning | 1 | Aug 7th, 2007 06:03 PM |
| ECU Tune Dyno Graphs - S. Fla dyno day | ignote | MINI Cooper S | 0 | Aug 7th, 2007 02:07 PM |
| Bristol Dyno Day £30 on 2nd April. Bristol MEET. Will be a good day just to say hi | Richard22b | Engine & Drivetrain Tuning | 4 | Mar 23rd, 2006 03:27 PM |
| Latest Dyno Testing - Helix/P&D, Magnaflow, ALTA | Andy@Ross-Tech.com | Engine & Drivetrain Tuning | 17 | May 17th, 2003 02:50 AM |
| Helix Dyno Day 12.14.02 | macncheese | USA | 0 | Dec 13th, 2002 12:46 AM |
