Performance Torque
Old Nov 18th, 2003, 06:35 PM   #61
M3NTAL Kev
M3NTAL Kev's Avatar
Local Time: 05:15 PM
Send a message via MSN to M3NTAL Kev
Quote: Originally Posted by PYUGALA
I emailed Quaife Engineering yesterday and here is the answer:
Dear Sir,
Thank you for your enquiry.
A/A+ Series Mini - QDF14K4 @ ฃ450 GBP + Delivery
or
6 Speed Getrag (BMW Mini) - QDF38Z1M @ ฃ495 GBP + Delivery
Neither of the above Quaife ATB Differentials require any modifications to the housing before fitting. It is worth replacing the bearings when replacing the diff, but we do not supply those, as it is easier (and cheaper) for you to buy them locally.
Should you have any further questions, please contact us
Kind Regards
Sales@Quaife
So is this for sure? Does part number, QDF38Z1M, fit into the transmission casing without any modifications?
Canada View M3NTAL Kev's Electric Blue & Body Color 1st Gen MINI Cooper S Profile View M3NTAL Kev's MINI Profile Images   Reply With Quote
Old Nov 20th, 2003, 02:47 AM   #62 (permalink)
yuwei
Local Time: 05:15 AM
Send a message via ICQ to yuwei
Hi,
I just have my Quaife LSD fitted, but there is a kind of bearing noise.
Is there anybody having the same problem and how you sorted out?
Please help!!!
That noise really drive me crazy.......
Thanks everyone!!
Taiwan   Reply With Quote
Old Nov 20th, 2003, 05:15 AM   #63 (permalink)
TonyB
Don MINIo
TonyB's Avatar
Local Time: 02:15 PM
You are not alone. A few others have expressed the same. Right or wrong, it appears to be not uncommon... With that said, if it is driving you crazy, maybe what you are hearing is different. If you haven't already done so, ask the guys at the shop where you had the work done. Good luck.
'03 (9.6.02) MCS IB/W Lapis Blue Leather
Mission = 10:1 (Weight:HP)
United States View TonyB's Indi Blue & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Jan 31st, 2004, 04:36 AM   #64 (permalink)
Bilbo Baggins
Bilbo Baggins's Avatar
Quote: Originally Posted by yuwei
Hi,
Please help!!!
Thanks everyone!!
Are you sure that the spacing/shimming of the ring & pinnion gear is correct? If that is off it will be noisey. Did the installer use "Plastic-gauge" to check the mesh of the ring & pinnion?
'06 MCS SB/S R84s(Dunlop 5000, summer), R81s(Nokian Haakapiilatta 2, winter)
'02 MCS DS/W (retired)
United States Male View Bilbo Baggins's Space Blue & Silver 1st Gen MINI Cooper S Profile   Reply With Quote
Old Feb 1st, 2004, 03:12 PM   #65 (permalink)
PMello
PMello's Avatar
Local Time: 04:15 PM
Any recommended installers in the North East (US)?? I'm doing some more autoXing this year and this seems like a mod that will pay off. It also will help with next winter's driving. I live in the RI area. Driving down to Pennsilvania would not be a problem.
United States View PMello's Pure Silver & Black 1st Gen MINI Cooper S Profile   Reply With Quote
Old Feb 1st, 2004, 03:57 PM   #66 (permalink)
jlm
Helix in Philly did mine and several others
john
Old Feb 1st, 2004, 04:17 PM   #67 (permalink)
agiduda
work, work, work...
In the past I've heard of some quality inconsistencies and some people ending up with a noisy unit (on RX-7s). How are all the existing MCS/Quaife users doing in this regard? I'm willing to have it done but don't want a noisy diff.
United States View agiduda's Dark Silver & Black 1st Gen MINI Cooper S Profile   Reply With Quote
Old Feb 1st, 2004, 09:59 PM   #68 (permalink)
gowest
gowest's Avatar
There is a slightly different noise to mine, I don't know that I'd even call it louder, just different and not bad. Get a good instal, go to Helix!
2001 & 2002 SCCA, STS Pro Solo National Champion. 2003 SCCA, Solo2 Nationals 8th, co-driver (Courtney) 2nd in 03 & 04
2003 JCW 210, London Stainless Headers, custom cat back with 5" SuperTrapp, 15x7.5 SSR's and 16x8 ce28n's, Quaife, KW Comp 2 Ways
Old Feb 1st, 2004, 10:16 PM   #69 (permalink)
sadales
Send a message via AIM to sadales
Helix did mine as well, on a 2003 MCS. No noise, and the folks at Helix were great. For the record, I also drove to Philly from Indianapolis to have the work done. I'm not the least bit sorry I did it.
Scott
90SM
Old Oct 6th, 2004, 12:15 PM   #70 (permalink)
Penguinracer
Local Time: 11:15 PM
United-Kingdom Quaife Fitment
I had the Quaife fitted to my car here in the UK in June '04 (I live in the same town as the Quaife factory so I bought it direct) and NO MACHINING was required - it went straight in. No noise, no vibration - no problems! I bought my Quaife in December '03, so it may be a little different to some of the earlier versions - I don't know.
It may be that the earlier versions of the Quaife were identical to that used in the Focus RS and that later Quaife made some changes for the Mini because of the fitment problems. It's interesting to note that the Quaife part numbers for the Mini & the Focus are the same except that the Mini version has an "M" suffix - QDF38Z1 vs QDF38Z1M.
There's no doubt that it's an expensive and time consuming job. I'd bet on 20 - 24 hours labour to remove the engine, transmission, install the diff (you might as well do the flywheel while you're in there!) and get the whole kit & caboodle together again. May be a mechanic with a lot of mini engine removal experience would be quicker, but my guys hadn't done one before and being used to working on racing Aston Martins and other '60's stuff, they found things fairly fiddly!
Old Oct 6th, 2004, 12:55 PM   #71 (permalink)
ModoMini
ModoMini's Avatar
Whoa (20 hrs)? Shop I used to work for charged a standard rate of 13 hrs for the Quaiffe install and usually had it done sooner.
If your doing it yourself, then yes 20+ hrs would be appropriate.
Mark -'04 Cooper S MC40
United States View ModoMini's Chili Red & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Oct 6th, 2004, 08:04 PM   #72 (permalink)
S2000&CooperS
S2000&CooperS's Avatar
Local Time: 09:15 PM
For those who had it done at Helix, how long did it take?
United States View S2000&CooperS's Pure Silver & Black 1st Gen MINI Cooper S Profile   Reply With Quote
Old Oct 8th, 2004, 08:58 AM   #73 (permalink)
Penguinracer
New Zealand Quaife Install Time
You guys in the States have to realise that we're having to contend with the British tradesman's work ethic here. What is a 20 hour job in the UK is probably a 12 hour job Stateside. By the time our mechanics have made a cup of tea, realised some parts are missing, told no one about it, figured out that they have the wrong tools, chatted to their co-worker about the football, had another cup of tea, told their boss some parts are missing, had another cup of tea, whinged about the weather etc... get the picture! I'm a Kiwi who's been living here many years, but I have never found a mechanic like those back home - guys with a "can do" attitude. Guys who can improvise, fabricate and manufacture parts in their workshop in no time flat! This all comes from New Zealand's remoteness and the need to make parts to avoid the long delays and high prices of imported parts.Everytime I get a car back from mechanics here it is late, over budget and the work of a poor standard. When questioned the mechanics open their big book of excuses - it is truly unbelieveable! My Mini has been off the road for five months due to the incompetence of the guys working on it! And that's two differnet shops - so it's not just an isolated problem! Don't get me going on franchised dealers - they're just fitters! Bottom line - 12-16 man hours is probably nearer the mark.
Old Oct 8th, 2004, 12:54 PM   #74 (permalink)
supercoopers
supercoopers's Avatar
The above is sooo true penguinracer. I LOVED the high standards of workmanship and overt enthusiasm of people in America when I lived there a few years back. This is one of the reasons why I shall be returning to the states again in about 2 years time
Henry (British born and bred before anyone asks)
Old Oct 8th, 2004, 01:06 PM   #75 (permalink)
obehave
Mini Mod
obehave's Avatar
You obviously didn't go to my dealership
We're lucky to get 2 weeks a year of vacation though And we're pretty good at bi'chin at work too.
Old Oct 8th, 2004, 02:36 PM   #76 (permalink)
S2000&CooperS
LOL Yeah, some of the dealerships here can take a long time too and/or not get it right the first time.
My company added a 3rd week of vacation this year which has been nice .
08 Smart ForTwo Passion Silver/Black/Red (Going on Ebay!)
07 Honda Accord V6 6-speed Taffeta White/Tan (wife's)
06 MINI Cooper S JCW Checkmate Astro Black/Silver
Old Oct 8th, 2004, 02:56 PM   #77 (permalink)
obehave
Mini Mod
obehave's Avatar
After 14 years and my 4th Gov't contract job I finally got my 3rd week.
Now if I could only get to use it
Old Oct 8th, 2004, 03:10 PM   #78 (permalink)
Bisch
Nut Job
Bisch's Avatar
I took an 8 day vacation in January of 1995! That was my last vacation. Since then, I have worked 6 days a week (sometimes 7). The last time I took even two days off in a row was October 11-12, 2002. My son was born on Oct.11.
I'm freakin' exhausted.
Old Jan 26th, 2006, 08:02 PM   #79 (permalink)
GARY GP
GP-1528
GARY GP's Avatar
Quote: Originally Posted by HI-MINI
For those who already got the quaife, please post update if you blew a gear or if you've got excellent results.
hello i v got 270bhp but with no quaife it will stand still smoking!!!! (wheel spinn) thanks.
Old Jan 26th, 2006, 08:11 PM   #80 (permalink)
GARY GP
GP-1528
GARY GP's Avatar
[quote=yuwei]Hi,
Please help!!!
Thanks everyone!![/QUOTE ]hi, have you had a race fly wheel fitted (or h duty
clutch.thanks,
Quaife LSD GTT 280 Engine & Drivetrain Tuning 28 Jan 6th, 2008 04:43 PM
Mini LSD versus Quaife mobergy 2nd Gen MINI Cooper S 7 May 17th, 2007 06:25 PM
LSD Phantom vs. Quaife cause warranty issues? MattMan Engine & Drivetrain Tuning 2 Jun 3rd, 2005 04:33 AM
JCW and Quaife LSD ALee Engine & Drivetrain Tuning 3 May 18th, 2005 02:06 PM
