Visit Lohen!
Old Dec 22nd, 2002, 05:40 PM   #1
m1les
Mulberry Red Mini 40
m1les's Avatar
Local Time: 10:23 PM
Air Filter Question
Recently spoke to my dealer about a different type of air filter and asked his opinion.
His comments were the existing filter and housing due to the length of the system provides for additional torque at low revs whereas if you replace it with a cone type filter, you gain torque at the higher end but loose it at the lower end.
Driving a ONE it is probably not a good idea to loose low end torque, gearbox ratio's etc.
Comments anybody.
Also How does the Pipercross Viper compare to the cone type filters? I understand about the cold air system, but wondered about the overall length compared to the original.
Was a 1, now 1 of 150 in a 40
England   Reply With Quote
Old Dec 22nd, 2002, 09:42 PM   #2 (permalink)
tsprayfhs
Air Filter Question
I have only looked at info for the S but it should be the same for all MINIs. All dyno print outs I have seen show a shift in torque of about 500rpm below 3000 to 3500rpm. By that I mean you get the same torque you had to begin with only 500rpm sooner (a good thing). Some where around 3500rpm you begin to seen torque above your original max. I have never seen a drop in low end torque. What I have also seen is increase in max. hp/kw; however, if you look closely this power increase is as high as 7500rpm in some that I have seen. Street engines do not spend a lot of time at those revs. Many blow before getting there. Before you by demand dyno sheets. If they don't have them for you ... save you money. If they have them, read them carefully. But what do I know? I'm an old man.
Motor on
Old Dec 24th, 2002, 04:21 AM   #3 (permalink)
m1les
m1les's Avatar
Thanks for the reply tsprayfhs. So if I understand your answer correctly, the torque I would expect at say 3000 revs can now be expected at 2500 revs?
I think i will drop Pipercross a line for their dyno sheets.
Dont let them young un's get to you. Us old un's have been there, done that
Old Dec 24th, 2002, 08:56 PM   #4 (permalink)
tsprayfhs
Yes sir that one of the things. Mini-madness also has so dyno sheets for viewing/downloading as does Graham try http://www.mini-madness.com/Catalog_...ntake_dyno.jpg OR http://www.grahamgoode.com/mini/prod...hp?partno=S200
Motor on
Old Dec 24th, 2002, 09:21 PM   #5 (permalink)
Bilbo Baggins
Bilbo Baggins's Avatar
Local Time: 06:23 PM
Re: Air Filter Question
Originally posted by tsprayfhs
..... What I have also seen is increase in max. hp/kw; however, if you look closely this power increase is as high as 7500rpm in some that I have seen. ........... But what do I know? I'm an old man.
Motor on
I have always questioned the dyno charts that show power increases out to 7500rpm. Afterall there is a fuel cut off at approx 6900rpm. If all they are claiming is that changing the air filter adds Hp, how do they explain how they got the engine to rev past the fuel shut-off? If they re-chipped the engine then the test is bogus.
In answer to your question. You know plenty. You've seen plenty. And, in seeing plenty you are skeptical. Nothing the matter with that. Being a bit of a skeptic helps to keep you out of trouble and saves you money in the long run.
'06 MCS SB/S R84s(Dunlop 5000, summer), R81s(Nokian Haakapiilatta 2, winter)
'02 MCS DS/W (retired)
United States Male View Bilbo Baggins's Space Blue & Silver 1st Gen MINI Cooper S Profile   Reply With Quote
Old Dec 25th, 2002, 12:34 PM   #6 (permalink)
Silver "S"
Cool
Bilbo Baggins and the rest of the GANG here, the so called DYNO runs that are in Mini-Madness are from MY vehicle, and YES I was there to see ALL DYNO runs and the car did not have a fuel cut off at 6500. I know MOST of you are skeptical but trust me I have the DYNO runs on hand and are published in Mini-Madness Call George at madness
Puerto Rico   Reply With Quote
help stupid air filter question yellowtwinkie Engine & Drivetrain Tuning 5 Jul 12th, 2007 02:52 PM
a big hello with an air filter question Milwan MINI Cooper 4 Jul 14th, 2006 01:07 PM
Air Filter Question mattshea50 MINI Cooper S 0 Jul 16th, 2005 11:07 PM
Air Filter question Tracie Engine & Drivetrain Tuning 4 Jul 14th, 2005 07:08 PM
Air filter question racemier Engine & Drivetrain Tuning 12 Aug 28th, 2004 05:40 AM
