Visit Derek Woodman MINI
Old Feb 1st, 2003, 11:46 PM   #1
thepilo
Local Time: 03:58 PM
Intake Clips
how do you take the clip that holds the tubing to the intake filter box?
Old Feb 2nd, 2003, 03:49 PM   #2 (permalink)
chiph
Spectator
chiph's Avatar
Local Time: 11:58 AM
You can also use a flat-bladed screwdriver and slip it in there to separate the joint. If you're lucky you can reuse the band. Otherwise you'll need to buy a new one (no idea on cost).
From what Dan the mechanic at Flow MINI was saying, you need a special set of pliers to get it back together.
Chip H.
ex-MINI Cooper S owner and all around good-guy
United States View chiph's Electric Blue & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Feb 2nd, 2003, 11:23 PM   #3 (permalink)
Andy@Ross-Tech.com
Andy@Ross-Tech.com's Avatar
Send a message via AIM to Andy@Ross-Tech.com
As Obehave mentioned, these (Otiker) clamps are destroyed in the removal process. Replacing with reusable high-quality stainless hose clamps works very nicely.
'03 MCS every option+Helix/P&D+One-Ball+HAI+Enkei+Falken
The Unofficial MINI 1/4 Mile Dragracing Database
Old Feb 3rd, 2003, 02:11 PM   #4 (permalink)
thepilo
I have spent some time with it, and have found a way to both take off, and reclamp with out breaking the clips, using a flat head screw driver, and a pair of pliers.. To take off, Just pry up in the little gap under the locking portion and it wall snap up, and didn't break for me..
now to put back up, take the flat head ,and put it under the locking clip, to hold it away from the lower band, then squeeze the to parts of the band togetherm and slowly pull the screwdriver out, and it should snap into place..
Old Feb 3rd, 2003, 02:45 PM   #5 (permalink)
Andy@Ross-Tech.com
I wouldn't trust a re-attached Otiker clamp. Just buy some nice stainless screw-type hose clamps.
Old Feb 3rd, 2003, 03:05 PM   #6 (permalink)
macncheese
Send a message via AIM to macncheese Send a message via Yahoo to macncheese
The clamp i bought was too wide to fit in the stock tubing's groove so I used a nice high temp zip tie. There is a ghetto solution to everything!
Cheese
United States View macncheese's Dark Silver & White 1st Gen MINI Cooper S Profile   Reply With Quote
Anyone got sound clips for..... futureal33 Engine & Drivetrain Tuning 2 Oct 15th, 2006 10:28 PM
Spotlight Clips coded2112 Exterior 1 Mar 21st, 2006 12:33 AM
Mini Clips chosta MINI in the Media 6 Oct 28th, 2004 10:46 PM
Clips GTT 280 Faults & Fixes 1 Sep 14th, 2003 11:16 PM
plastic clips veg1515 Interior & Ice 7 Aug 22nd, 2003 12:28 PM
