Performance Torque
Old May 31st, 2003, 03:56 PM   #1
gt40guy
Local Time: 09:28 PM
Cool MCS Crank Pulley
Hi there quick question does anyone know what the stock pulley diameter is of the MCS thanks , I know that the charger pulley is 2.6 inch but want to know the dia of the crank pulley, Thanks Andy
Old May 31st, 2003, 04:41 PM   #2 (permalink)
911ETR
911ETR's Avatar
Local Time: 01:28 PM
hope its going to be a harmonic ballancer.
Old May 31st, 2003, 04:51 PM   #3 (permalink)
gt40guy
lol would be if i was using it on a MCS but ive got 2 of the chargers and are using them on my gt40 replica......
so i need to know the pulley dia, so i can work out the ratio's to get the 11.6 psi of boost that the charger makes as standard..
Andy
Old Jan 18th, 2004, 05:13 PM   #4 (permalink)
alfa145
Local Time: 10:28 PM
Still looking for this info as trying to use the MCS charger on another project.. asked the question about 1 month ago What is the standard crank pulley diameter measured across the tops of the VVV pattern - only for someone to give me the standard charger pulley diameter..... didnt help me as i could have measured that myself!
So.. the stock MCS crank pulley diam, anyone?
Thanks in advance,
AJ
Old Jan 18th, 2004, 05:24 PM   #5 (permalink)
jlm
Local Time: 04:28 PM
5.4" dia.
go to the faults formum, thread on idler pulley failures. andi it is a rubber mounted harmonic balancer.
john
Old Jan 18th, 2004, 05:32 PM   #6 (permalink)
alfa145
Quote: Originally Posted by jlm
5.4" dia.
Sport on, cheers Jim, you're better than the search engine which failed to pick it up
19% + 3% crank pulley james l Engine & Drivetrain Tuning 31 May 24th, 2007 04:58 PM
17% S/C Pulley + 2% Crank futureal33 Engine & Drivetrain Tuning 6 Feb 8th, 2007 08:23 PM
MCS boost and crank pulley size??? car_fan900 Engine & Drivetrain Tuning 10 Mar 31st, 2006 11:24 AM
2% crank pulley ?? brady Engine & Drivetrain Tuning 10 Dec 3rd, 2005 04:37 PM
stock MCS crank pulley the same as stock MC pulley? mini_macky Engine & Drivetrain Tuning 5 Aug 24th, 2005 04:35 PM
