| Toon Toon.. <div><a href= Join Date: Aug 2001 Location: Up North Local Time: 02:08 PM
Offline | Is the exhaust on the conversion just the Cat back or does it include the manfold? Anyone have ideas bhp gains of just fitting the exhaust? Thanks ![]() Global Moderator ![]() |
| 003 On a Mission Join Date: Jan 2003 Location: Cabbage County Local Time: 02:08 PM
Offline | Re: JCW S Exhaust The exhaust is from the front pipe back ie does not include the header pipe. If you look on the JCW Works web site under Tuning it shows you the system. No idea about HP gains, but you cannot just by the exhaust system on its own. Looks like you will have to bite the bullet LMB and buy the JCW Works conversion. Ypu know thats what you want. Managed to sell your S yet? |
| MINI2 Newbie Join Date: Aug 2002 Local Time: 01:08 PM
Offline | I was told by my local parts department that the exhaust was not available on its own, have you been told otherwise? If so do you have a part number. As for performance/power increase I'd go with the surefire answer of none or very little but it looks a hell of a lot better than the double peashooter. Plus its not much louder. |
| Trained Monkey Join Date: Jan 2001 Location: Bedfordshire Local Time: 02:08 PM
Offline | It's only about 1/3 or 1/4 of the system. It doesn't really offer much in the way of HP gain. Here's where it clamps on: There aint no party like my nana's tea party |
| | #7 (permalink) |
| MINI2 Master Join Date: Apr 2002 Location: rotterdam Local Time: 02:08 PM
Offline | Can only be caused by the weight of the runflats and their consequently higher rotation mass. Obviously the BHP at the crank will be the same regardless of tire choice, the runflats could however cause a higher BHP loss from crank to wheels, although 15 bhp seems a bit on the high side to me, maybe the dyno needs to be calibrated ![]() |
| | #8 (permalink) |
| MINI2 Senior Derelict | I know this started as an exhausst thread but couldn't help quash a rumour. Everyone seems to suggest that the 17" Pirelli run-flats are heavy beasts. According to this post by Dan from the tirerack over at MCO the tire is 22lbs which compares to 21.5 for the Yokohama AVS ES100 or the Dunlop SP9000 Run Flats at 21.8lbs. So as you can see, the Eufori@ aren't any heavier that other tires. IN fact it's lighter than the Bridgestone S0-3 Pole Position that weighs 24lbs. That being said they do suck, the rubber isn't that great, it's got a pretty poor wear rating and it's not that great in the wet. The link can be found Here Paul |
| | #12 (permalink) |
Offline | Re: Re: Re: Re: JCW S Exhaust Sadly no. I thought long and hard about it and decided to get a nicely specced S instead. I just didn't want to compromise on my options. I might get a Hartge instead ![]() Global Moderator ![]() |
| | #15 (permalink) |
| MINI2 Regular Join Date: Apr 2003 Location: West Midlands UK Local Time: 02:08 PM
Offline | Cheers for the thread LMB, I must admit I wondered about this too. If the JCW kit only includes a cat back exhaust, a manifold with sports cat should take it to the region of 210hp then? (whilst screwing up your warranty if something exhausty goes wrong...) |
| | #16 (permalink) |
| MINI2 Regular Join Date: Jul 2002 Location: NJ Local Time: 09:08 AM
Offline | [QUOTEThat being said they do suck, the rubber isn't that great, it's got a pretty poor wear rating and it's not that great in the wet. [/b][/quote] The GOodyear ALL-SEASON runflats are absolutely phenomenal in the wet. It's not just the runflats that are heavy. It's the 17" wheels. The combo is almost 50 lbs! DS/W MCS |
| | #17 (permalink) |
Offline | I agree on the looks and probably the sound (from what I hear - no pun intended!) but I don't think it even gives 5HP! According to the numbers JCW gives, it looks like the pulley, polished head and increased redline would give those numbers. I think the exhaust is purely aesthetics (not that there's anything wrong with that!) DS/W MCS |
| Retro fitting JCW exhaust tips to MCS Exhaust | Cooooooperslad | Exterior | 13 | Jul 3rd, 2007 01:33 PM |
| JCW GP Exhaust on Mini One(dyno inside without\exhaust) | Innuendo | MINI One | 13 | Feb 25th, 2007 10:15 PM |
| JCW exhaust ??? | lemurfart | Engine & Drivetrain Tuning | 7 | Aug 27th, 2005 05:27 AM |
| 05 stock MCS exhaust sound vs. JCW exhaust - pops or no?? | MiniMelSF | Engine & Drivetrain Tuning | 7 | Jul 1st, 2005 07:10 AM |
| JCW Exhaust | Fabio | Engine & Drivetrain Tuning | 8 | Jul 1st, 2005 02:09 AM |
