Visit Mini Mania UK
Old Oct 28th, 2003, 11:01 AM   #1
Kiwiracer
Whakataetae ki toa
Kiwiracer's Avatar
Local Time: 05:22 PM
New Zealand Pilo Ignition
Should receive my Pilo ignition upgrade tomorrow. Wondering if there could be any compatiability issues with my EVOTech ECU ?
BRG/W MCS Alta Pulley, Alta Intake, EVOtech ECU, 22 ml rear sway bar , Pilo Ignition pack
New Zealand   Reply With Quote
Old Oct 28th, 2003, 12:49 PM   #2 (permalink)
LuckyRVA
1.6 Litres of fury!!!!
LuckyRVA's Avatar
Local Time: 06:22 PM
Send a message via AIM to LuckyRVA
I wasn't sure what you were refering to , so I had to look it up.
I assume your talking about this product right? I've never seen, or heard anything about it.
It shouldn't have any effect on your EvoTech. But, maybe you should email them to be sure... mini@thepilo.com
-Jason
2002 Dark Silver Cooper S w/ white roof. SOLD
Old Oct 28th, 2003, 05:39 PM   #3 (permalink)
Mugami
Mugami's Avatar
Dont think it will have any effect.. im also expecting Pilo to chime in since he visits the board quite often. he normally is in the racing forum under I did a little drag racing last night..
02 MCS DS/W (Totaled November 02 on Fall Folage Run)
03 MCS DS/W (See my MINI Profie for extensive list of mods)
United States View Mugami's Dark Silver & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Oct 28th, 2003, 11:00 PM   #4 (permalink)
obehave
Mini Mod
obehave's Avatar
Now I'm curious. Is the $139 for coil, plugs and wires? What if I want just the coil? Where's Pilo?
Guess that's enough ?s for now
Old Oct 28th, 2003, 11:05 PM   #5 (permalink)
MINIAC
MINI Profiler
MINIAC's Avatar
Local Time: 03:22 PM
Ignition Kit pieces can be bought individually ... coil pack is $75:
http://www.thepilo.com/ignition.htm
Old Oct 28th, 2003, 11:46 PM   #6 (permalink)
Mcooper
Mcooper's Avatar
I got the Pilo set uo for my cooper,
I'm pleased with it, car runs like a champ!
Glenn
Glenn M
http://www.alliesplace.com/MCO/mcooper.jpg
Black '02 Cooper
Green '03 S Mcooper's Home
United States View Mcooper's Solid Black & White 1st Gen MINI Cooper Profile   Reply With Quote
Old Oct 29th, 2003, 12:00 AM   #7 (permalink)
obehave
Mini Mod
obehave's Avatar
Guess I'm quite the lazya$$
Thanks. I might go for that.
Old Oct 29th, 2003, 09:06 AM   #8 (permalink)
erichui
Local Time: 09:22 AM
Send a message via ICQ to erichui Send a message via MSN to erichui
i also bought it and installed the ignition upgrade, my car does run smoother, however becuase it might be due to oil change that i did when i installed the system, so i have to drive a bit more and see if its due to the ignition upgrade, however so far im pretty happy with it
05 PW/B chilli. finally here.
Australia View erichui's Pepper White & Black 1st Gen MINI Cooper S Profile   Reply With Quote
Old Oct 29th, 2003, 09:50 AM   #9 (permalink)
scpaul
Local Time: 06:22 AM
any one get Nokogy wire + M7 Plasma Booster + Pilo set?
Taiwan   Reply With Quote
Old Oct 29th, 2003, 10:58 AM   #10 (permalink)
erichui
i think that some people does have nology wire and the pilo coil pack.
not sure about m7 plasma booster tho.
i think u can head over to www.minicooperonline.com for more information about the ignition system and also some user feedback from there since its been discussed quiet a lot there.
also dan hangs around there a lot as well
Old Oct 29th, 2003, 09:57 PM   #11 (permalink)
Andy@Ross-Tech.com
Andy@Ross-Tech.com's Avatar
Send a message via AIM to Andy@Ross-Tech.com
$150 + $250 + $75 = $475 That's a chunk of change to *hopefully* make the engine run *smoother*.
'03 MCS every option+Helix/P&D+One-Ball+HAI+Enkei+Falken
The Unofficial MINI 1/4 Mile Dragracing Database
Old Oct 29th, 2003, 10:23 PM   #12 (permalink)
motoring
Autox Monster
motoring's Avatar
I hope you car didn't run smoother with just an oil change.... unless you didn't have any oil in you engine.
IB/W MC with the really big checkered flag on top
2004 H Stock National Champion
United States View motoring's Indi Blue & White 1st Gen MINI Cooper Profile   Reply With Quote
Old Oct 31st, 2003, 06:31 AM   #13 (permalink)
erichui
well maybe i didnt mean it runs smoother excatly, just that after an oil change the car always feel faster, or what i call smoother.
and i did have oil in my engine, very dirty they are
Old Nov 1st, 2003, 04:23 PM   #14 (permalink)
Kiwiracer
Whakataetae ki toa
Kiwiracer's Avatar
Ok,Easy install,right down to indexing the Plugs.. ..And..........STUMBLE FREE !!!!!!!!!!
Noticing a slight hesitation in 2nd through 6th under moderate to heavy acceleration,not sure if it's just related to a quicker throttle response ?
Old Nov 1st, 2003, 10:00 PM   #15 (permalink)
thepilo
Local Time: 10:22 PM
Hey Guys,
I am around some times over here.. I try not to talk too much about my product here as I am a sponsor over at NAmotoring. I know that there is a person running M& Plasma booster and thePilo Ignition, and is very happy with his setup. Not sure about the M& + nology though. The Coil Pack, Plugs and wires are a great way to smooth out idle and acceleration. I get so many compliments on how mch smoother the car is with the Ignition upgrade. If you have any other questions, please let me know. and I will be sure to check in and answer them.
Dan
Pilo Racing
Pilo Racing www.piloracing.com Intakes, Ignitions, Heads, Superchargers and more... stop on in
Old Nov 2nd, 2003, 01:26 AM   #16 (permalink)
obehave
Mini Mod
obehave's Avatar
Quote: Originally Posted by thepilo
Hey Guys,
Dan
Pilo Racing
What gap would you recommend with your coil, my Magnecor wires and Denso Iridiums?
Old Nov 2nd, 2003, 08:59 PM   #17 (permalink)
thepilo
I would recomend about a .60 to .65 Depending on how much GAP the Denso's can take. I recomend a Pliers type gap tool to make the precise gaps. It works really well, and will give you the best performance.
Dan
Old Nov 14th, 2003, 04:43 AM   #18 (permalink)
scpaul
Andy, it's not "hopefully", it does make a difference, I mean, each of them. I have actually installed all of them and can share my personal experience here. Three of them have some similarities : make your engine run smoother, reduce emmision, save gas, etc. But each one of them has its strong emphasis.
M7 PB : smooth out the whole rev range, and DOES improve gas consumption.
Pilo : Give better gain at low rev range, feel much stronger than M7, I saw blue fire from exhaust pipe when down shifting....
Nology : relative smaller gain compare to previous two, but LOOK is important, isn't it.
Rgd to $, or C/P value, don't want to discuss here, it's too difficult.
Old Jun 8th, 2005, 05:54 AM   #19 (permalink)
leon1982
Local Time: 08:22 AM
Send a message via MSN to leon1982
Australia
Where did u buy the kit from?
How much is it?
Australia View leon1982's Solid Black & Body Color 1st Gen MINI Cooper Profile   Reply With Quote
pilo wide arch kit nomonstersinme Exterior 1 Jul 22nd, 2005 05:14 AM
PILO Ignition upgrade with 98 octane fuel leon1982 Engine & Drivetrain Tuning 5 Jun 13th, 2005 11:09 AM
PILO Ignition upgrade leon1982 Engine & Drivetrain Tuning 11 Apr 28th, 2005 11:40 PM
Alta vs. Pilo Intake 408_Grasshopper Engine & Drivetrain Tuning 23 Mar 17th, 2004 02:33 PM
what's y'alls take on the Pilo Ignition upgrade? ABTsportsline Engine & Drivetrain Tuning 12 Feb 18th, 2004 01:07 AM
