Visit Lohen!
Old Oct 29th, 2003, 11:29 PM   #1
vdubdoug
Local Time: 04:33 PM
Send a message via AIM to vdubdoug
17% Pulley Users?
Well I spent the day down in Philly, I went to Geno's and had a cheese steak and the headed over here for some desert
This was the desert tray Yummy
Now since I have already tasted the first 2 (stock & 15%) for 24k miles I thought the third one (17%) was the way to go
Here it is installed:
And yes anything fits with a hammer :P
Thanks again ERIC.
The car has been runniing great and I can feel a difference, First gear requires 2 hands on the wheel if I really get on it. I am only running a 17% pulley, wires and K&N typhoon intake. 6th gear acceleration from 3k is very nice. More road testing and some drag race testing to come.
Here is the Test vehicle:
Am I the first to run 17%?????
Doug
2002 Cooper S eb/w, "Mini Cooper Look" 17% pulley.
"When in Doubt Choose the burrito"...Tom Kosh
Old Oct 30th, 2003, 02:57 AM   #2 (permalink)
blackdogmini
Local Time: 10:33 PM
Doug:
Cool shots of your mini and the Helix shop. So how much front tire do you have left?
Old Oct 30th, 2003, 05:12 AM   #3 (permalink)
mrhollio
road trip time
mrhollio's Avatar
Local Time: 03:33 PM
nice ride... keep us posted on the rest of the testing. How was the cheese steak?
Trust not the heart of a man for whom old clothes, and the Mini, are not venerable!
United States View mrhollio's Solid Black & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Oct 30th, 2003, 12:45 PM   #4 (permalink)
vdubdoug
I have plenty of front tire left. It has been raining the past couple of days so i have not had allot of good weather to get on it. I have a 2 hour drive to work this morning so that should be fun
And the Cheese steak was great as usual
Doug
Old Oct 30th, 2003, 09:41 PM   #5 (permalink)
Minimalistix
as it sez im a newbee
hmmm i wanna learn... is there any smaller pulleys then 17s ???
Old Oct 30th, 2003, 09:57 PM   #6 (permalink)
MiniMan7
Let's Motor.
MiniMan7's Avatar
Local Time: 07:33 PM
Send a message via MSN to MiniMan7
Yup, people usually use 15% reduction pulley's. This is the first I've seen or heard of a 17% reduction pulley, but then again, I'm no professional.
-Adam
Canada View MiniMan7's Electric Blue & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Oct 30th, 2003, 10:00 PM   #7 (permalink)
Minimalistix
hihi you understand by the wrong way
i mean smaller sized for example 17% smaller than 15%s )
so is there 18s or 20s ??
Old Oct 30th, 2003, 10:02 PM   #8 (permalink)
MiniMan7
Let's Motor.
MiniMan7's Avatar
Opps!! Guess I'm the newbie when it comes to this!
Sorry!
-Adam
Old Oct 30th, 2003, 10:10 PM   #9 (permalink)
obehave
Mini Mod
obehave's Avatar
Local Time: 06:33 PM
If I remember right jlm and Helix did most of the original testing on reduction pulleys over a year ago. I'm pretty sure they did a 20% and saw no real performance gains over the 15. (They did a 10% as well).
Everybody is pretty much working on the foundation they laid in my opinion. Probably the single reason I'll go to Helix to get mine done.
Too small a pulley will also have less grip surface and would start to slip under load easier as well. I'm sure there's more.
Old Oct 30th, 2003, 11:30 PM   #10 (permalink)
greatgro
No, not true. About the 20% not providing better gains, that is. Eric has been doing a lot of testing. in fact, even though vdubdoug just got his 17% installed, Eric just installed a 19% pulley!!!! And talk about gains....it dynoed 19HP and 15lbs of torque higher than an MCS with a similar setup with a 15% pulley!!! The gains are supposedly unbelieveable! It's just whether it proves to be reliable over the long haul. There are several issues to consider such as the water pump and the supercharger rev limit. But if the redline on the MCS was moved down a few hundred RPM, I think 19% might be the ideal size. Even MORE power and most important - MORE power down low!
DS/W MCS all packages, 19% pulley, larger injectors, GIAC ECU, Madness intake, UUC exhaust, Milltek Header
United States View greatgro's Dark Silver & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Oct 30th, 2003, 11:52 PM   #11 (permalink)
vdubdoug
The reason 15% was done was becuase people fealt it was a safe limit for most drivers. I am testing the 17% to see how it works for some one who drives there car about 500 miles a week or more. I was given the oppurtunity to run a 19% but thought that might be a little much for my daily driving and stuff. The overspinning (Cavatation) of the waterpump seems to be more myth than fact. Now as for the charger One could over rev it most likely with a chip installed but I do not have a chip yet and still have the stock revlimiter in there. My car spends most of its time below 6k but I will get on it from Time to time.
The 17% pulley is working out Nicely. Plenty of usable torque in every gear and no downshifting to pass when cruising at 2500 to 3000 rpm in 6th .
I plan on running the car at Englishtown tomorrow night. I want to see what i run with it. My previous best was a 15.2 with a 60ft time of 2.7 (which sucks). If I can run a smiliar 60ft time and make up more time down the track then I know the 17% pulley is doing what i wanted it to do.
Doug
Old Oct 31st, 2003, 12:54 AM   #12 (permalink)
obehave
Mini Mod
obehave's Avatar
Ooooo Kaaaay so I was wrong on one point. Rack that up to crappy memory.
Anyway what about belt slippage? It takes the same mechanical effort to spin the SC so at some point, especially without changing belt tension, you're going to lose decent belt/pulley friction. Loss of HP and belt life would then become a problem.
Any info on that would be nice.
Personally I'd gladly give up some upper RPM for more bottom end grunt.
Old Oct 31st, 2003, 01:21 AM   #13 (permalink)
vdubdoug
We will find out how soon a belt wears out with a 17% since I drive allot. That is part of the reason why Helix let me test this pulley out. Plus I badgered Eric for weeks and made him do it when I stopped by the shop. . I will keep everyone aware of any belt issues that occur.
Doug
Old Oct 31st, 2003, 01:28 AM   #14 (permalink)
jlm
Local Time: 05:33 PM
we tested the 15% and 10% last january and realized the 10% was a waste of time. Eric was so excited with the first pulley he worked up a frenzy (15%, and no-one had put one on yet "How to's" were yet to come)
john
Old Oct 31st, 2003, 01:38 AM   #15 (permalink)
obehave
Mini Mod
obehave's Avatar
Excellent, thanks.
There you go then, the final answer.
Old Oct 31st, 2003, 01:39 AM   #16 (permalink)
bluesmini
bluesmini's Avatar
trey the guy from cat and dog racing has been using a 17-19% pulley from the get go. i can't remember which. he has a website but you'll have to go to MCO to find it. he has about every performance option that's out there on his car. i'm sure he'll have some good input on this subject.
Old Oct 31st, 2003, 02:16 AM   #17 (permalink)
blackdogmini
Cool Stuff. I'm waiting (im)patiently for resulsts.
Old Oct 31st, 2003, 12:39 PM   #18 (permalink)
jlm
I might add an important feature of the 2 pc pulley is that you can change-out pulley ratios without re-doing the full install. This was the intent from the start. Therefore, you can go back to stock size, and/or use any ratio that fits. 15% has had a lot of testing with absolutely no problems which tells me it is not pushing the limit. 19% has had considerable testing on at least 4 rigs I know of and been hammered at the drags and track with no problems. Not as wide a database, but the point is...no problems.
found on another forum (by Bisch):
"I called Mini Mania to ask about getting a smaller size pulley for their 3-piece set-up, as I have. When I ordered the pulley, they said other diameters were available. Their website says they are interchangable. ~~~"This unique 3-piece design allows installation of the pulley onto the shaft without a press, and enables easy removal to change the pulley size." ~~~ But, THEY DON'T MAKE THEM! nor do they have plans to.
I bought their set up because it was "interchangable"! Not only did it take me 6 freaking hours to install because of their "pulley removal (not) tool", but the product I bought will not do as it was represented."
hope that helps
john
Old Oct 31st, 2003, 03:15 PM   #19 (permalink)
obehave
Mini Mod
obehave's Avatar
hope that helps
I was going to get yours any way John
Old Oct 31st, 2003, 05:37 PM   #20 (permalink)
Mugami
Mugami's Avatar
JLM with the 17% and/or the 19% is it necessary to change to the smaller Belt Like the one Mini madness sells with there 15% pulley? Currently like most im running the 15% I got from helix, and been thinking of the 17 and or the 19% pulleys . I was wondering of an est. price that just replacement Pulleys may cost. I couldnt find a price on helixs sight as of yet.
02 MCS DS/W (Totaled November 02 on Fall Folage Run)
03 MCS DS/W (See my MINI Profie for extensive list of mods)
United States View Mugami's Dark Silver & White 1st Gen MINI Cooper S Profile   Reply With Quote
Any Dinan users out there? Threat Engine & Drivetrain Tuning 3 Nov 15th, 2005 11:57 PM
