Adam's Polishes
Old Dec 22nd, 2003, 09:58 PM   #1
PW51CAR
Local Time: 10:41 PM
Map Sensor
Can anyone tell me if the Cooper S has a 2 or a 3 bar map sensor?
United Kingdom View PW51CAR's Cosmos Black & Body Color 1st Gen MINI Cooper Profile   Reply With Quote
Old Dec 24th, 2003, 07:26 PM   #2 (permalink)
Andy@Ross-Tech.com
Andy@Ross-Tech.com's Avatar
Local Time: 06:41 PM
Send a message via AIM to Andy@Ross-Tech.com
I've seen over 2000 mbar absolute, so I'm gonna say 2.5 or 3.0 bar.
'03 MCS every option+Helix/P&D+One-Ball+HAI+Enkei+Falken
The Unofficial MINI 1/4 Mile Dragracing Database
Old Dec 30th, 2003, 09:27 AM   #3 (permalink)
PW51CAR
Ah good stuff, means I wont need a sigcon then thanks Andy
Old Dec 30th, 2003, 02:24 PM   #4 (permalink)
Andy@Ross-Tech.com
I just took a look at the raw voltage at ambient (~1000 mbar absolute) and at idle (~15.5 in. Hg).
Ambient (1030 mbar absolute): 1.92 V
Idle (500 mbar absolute): 0.84V
If that relationship is pretty linear, I'd expect the MAP sensor to be a 2.5 bar sensor that will only max out when boost gets to about 22 psi of gauge pressure.
Old Dec 30th, 2003, 09:09 PM   #5 (permalink)
bluemcs
bluemcs's Avatar
Local Time: 05:41 PM
That should be just about where a 22% pulley puts it.
R U going to be the first Andy?
Old Dec 30th, 2003, 09:18 PM   #6 (permalink)
Dom
Test thread infiltrator
Dom's Avatar
Local Time: 11:41 PM
Send a message via MSN to Dom
is that 22psi of intake pressure or am i being dumb?
England View Dom's British Racing Green & White 1st Gen MINI Cooper Profile   Reply With Quote
Old Dec 30th, 2003, 09:35 PM   #7 (permalink)
Andy@Ross-Tech.com
Not dumb at all, that's exactly what I mean. The MAP sensor is the black rectangle in the center bottom of this pic:
It is mounted right on the intake manifold.
Old Dec 30th, 2003, 09:50 PM   #8 (permalink)
Dom
Dom's Avatar
there's a first time for everything
what's the standard pressure then? I always thought it was quite low
Old Dec 31st, 2003, 03:30 AM   #9 (permalink)
Andy@Ross-Tech.com
Here's the stock boost for my MCS (compared to the stock boost for a 150-hp VW 1.8T):
Old Dec 31st, 2003, 08:36 AM   #10 (permalink)
PW51CAR
Nice, you have alot of info on the mcs andy.. Looks like I will be needing a sigcon after all if its cut off is 22psi....
Old Dec 31st, 2003, 10:38 AM   #11 (permalink)
jlm
there is a second pressure sensor hidden between the fuse box and the head under a bracket. It has a tube connected to the intake connector between the throttle body and the blower intake, this zone would read ambient-vacuum, but never >0psi.
john
Old Dec 31st, 2003, 04:21 PM   #12 (permalink)
Andy@Ross-Tech.com
What are you planning to do to get 7 more psi?
Old Jan 1st, 2004, 01:48 AM   #13 (permalink)
PW51CAR
Planning on fitting a Rotrex supercharger quite soon
Old Jan 1st, 2004, 05:32 AM   #14 (permalink)
Andy@Ross-Tech.com
Cool.
I look forward to reading all about it. Twin-screw superchargers are supposed to deliver much better efficiency than Roots-type blowers.
Brake Light Sensor & Sensor replacement help needed wrxtomini Faults & Fixes 7 Apr 20th, 2006 07:55 AM
Anyone Replaced their BBR map with a MTH map ? Perm Engine & Drivetrain Tuning 0 Aug 26th, 2005 10:47 AM
MAP Sensor Details parkerea Engine & Drivetrain Tuning 0 Dec 30th, 2004 02:24 AM
Oxygen Sensor or Coolant sensor???? maximusrp Engine & Drivetrain Tuning 5 May 30th, 2004 06:33 PM
Supercharger MAP Sensor aphix Engine & Drivetrain Tuning 7 Jun 25th, 2003 05:08 AM
