Visit Lohen!
Old Dec 27th, 2003, 05:39 PM   #1
MarkW19
Grinning
MarkW19's Avatar
Local Time: 11:34 PM
Cool Eibachs vs SS+
Just wondering,
I'm getting my Cooper lowered in about a week, with Eibach lowering springs. I've also replaced the runflats with 17" Toyo T1S Proxes tyres. I have SS, not SS+.
After lowering, in real-world terms, how will my Cooper compare to an identical Cooper that hasn't been lowered, but has SS+? How will the handling and ride-comfort compare? ie., which would be the better?
Mark
United Kingdom Male View MarkW19's Astro Black & Body Color 1st Gen MINI Cooper S Profile   Reply With Quote
Old Dec 27th, 2003, 07:36 PM   #2 (permalink)
rasp
The Mini Family Sponsers
rasp's Avatar
I give you one guess....
England View rasp's Dark Silver & Black 1st Gen MINI Cooper S Profile   Reply With Quote
Old Dec 27th, 2003, 08:30 PM   #3 (permalink)
MarkW19
Grinning
MarkW19's Avatar
Helping!
Eibachs, seeing as they also lower the centre of gravity, angle the rear wheels in slightly, and judging from my test drive (and also test drive of a Cooper S) handle FANTASTICALLY well!
Old Dec 27th, 2003, 09:03 PM   #4 (permalink)
rasp
rasp's Avatar
Yeh! I am more than happy with the Eibachs theres a few of us on mini2 with them and not heard of any neg coments, the ride is a bit more harsh but nothing ott, performance is greatly increased and the look of the car greatly increased too, If my memory is correct the Eibachs lower the cooper 30mm all round 10mm more than the S.
Rasp
Old Dec 27th, 2003, 09:21 PM   #5 (permalink)
MarkW19
Grinning
MarkW19's Avatar
And they also get rid of the rake (slant) don't they, as they lower the back by a bit more than the front?
Bring on the Eibachs then. Now where's that Christmas money...
BTW. Any excessive tyre wear over stock?
Old Dec 27th, 2003, 10:01 PM   #6 (permalink)
rasp
rasp's Avatar
Too early to tell on tyre wear at the moment apparently theres a posability of inner tyre wear over the outer of the tyre on the rear, time will tell have not noticed anything yet..
The car sits great on the road not to sure on the rake though...
Old Dec 27th, 2003, 11:47 PM   #7 (permalink)
FWD-MX5
Local Time: 03:34 PM
What are the spring rates of the Eibachs? If they are too much higher than stock you may need better shocks. If you go too low you will induce too much negative camber and can effect tire wear, then you may have to get adjustable control arms.
As for out handling a SS+ car, the suspension was designed as a system (same for the non SS+) so if you start changing componets of the system, you may upset the balance that was engineered into the system. For example on a Miata, lowering the car takes away the ability of the suspension to create dynamic camber, forcing an owner to run higher static camber.
United States View FWD-MX5's Indi Blue & White 1st Gen MINI Cooper Profile   Reply With Quote
Eibachs ben__allen 2nd Gen Suspension 1 Jun 17th, 2007 08:46 PM
Eibachs with Runflats pikersteve Suspension 4 Oct 5th, 2006 07:11 PM
Eibachs on new suspension MarkW19 Suspension 13 Aug 2nd, 2006 01:00 PM
Dare X4 and eibachs? danb Wheels, Tyres & Brakes 10 Jul 28th, 2006 08:44 AM
Eibachs Blaise12 Suspension 0 Jun 6th, 2005 06:51 PM
