| MINI2 Master Join Date: Aug 2002 Location: ny,ny Local Time: 07:07 AM
Offline | engine measurements I've compiled some info from my spare engine and since questions arise, thought I would put them in one place: (maybe this should be a sticky?) Block: bore: 77mm (3.03"), piston area: 46.5 sq cm, stroke: 85.8mm (3.380") (from the Mullet link to Tridec; not personally measured) displacement per cylinder: 399 cc (1600cc total) bore-to-bore centerline: 85.34mm (3.36"), web between bores: .330" rod length: 130mm (5.11") (eye-center to eye-center) Rod/Stroke ratio: 1.53 deck height: -3.6mm (-.145") piston is below deck surface; head gasket: .025"( compressed) piston: flat with .020 depression to 1/2" of perimeter (comment: a 1mm ovebore gives 1640cc, about 40cc increase and recuces the web to about .290".) Head: intake ports: 1.675" x .85" exhaust ports: 1.348" x .8" intake valve: 30.2mm (1.189"), throat below seat: 25.9mm (1.02") exhaust valve: 23.3mm (.918"), throat below seat: 18.8mm (.74") rocker ratio: intake 1.65:1; exhaust 1.43:1 cam: base circle 1.185" dia lobe lift: intake .202", exhaust: .217" valve lift: intake .333" exhaust: .310" (PROMINI cam: base circle 1.145" dia intake, 1.132 dia exhaust) lobe lift: intake .228", exhaust: .240" valve lift: intake .378" exhaust: .343") valve adjusters are hydraulic piston, located in the rocker, dia .47" cam followers are rollers header ports: 1.366" x .975" (Supersprint is 1.60" x 1.05") header primaries: 1.36" (Supersprint is 1.63") header secondaries, Supersprint is 1-3/4" header collector: 2.3" (Supersprint is 2.5"") intake runners: -valve back to flange: 3.5"/4.6" (bottom of port/top of port); -intake flange to manifold interior plenum: 4.0"/4.5" total, plenum to valve: 7.5" along port bottom, 9.1" along port roof. exhaust runners: -valve back to flange: 2.6"/3.45" john Last edited by jlm : Dec 29th, 2003 at 08:08 PM. |
| Sponsor/Moderator/Other Join Date: Jul 2002 Location: Cleveland Local Time: 07:07 AM
Offline | Interesting stuff, I'm not really inclined to make it a sticky, because stickies tend to clutter up the view and more people complain that there's too many stickies then something isn't a sticky.. On the other hand, maybe it could get compiled into the technical info or an FAQ, I'll check on that happening. Magic 8-ball was correct. All be in awe of Magic 8 ball. |
| | #8 (permalink) |
Offline | I assembled the cam and rockers, held the valve against the rocker with finger pressure (but not compressing the lifter), rotated the cam and measured the valve travel with a dial indicator. that generated the rocker ratio and the total lift. lobe lift you can get by measurig directly on the cam. duration is hard because the rise rate is so slow on the ramps (so .050" lifter clearance is usually used, hard to get without mechanical lash adjusters), but lobe center spacing would be useful. all of the measurements were directly measured at my secret lab. john |
| | #10 (permalink) |
| Trained Monkey Join Date: Jan 2001 Location: Bedfordshire Local Time: 01:07 PM
Offline | Some basic engine specs from Tritec, for all the Tritec engines (3 of them): http://www.tritecmotors.com.br/engli...ors/tabela.htm |
| | #12 (permalink) |
| MINI2 Regular Join Date: Jun 2003 Location: CO Local Time: 06:07 AM
Offline | From the tech paper on the MINI powertrain that was published by five BMW engine group leaders back in July 2002: Duration intake/exhaust: 236/243º (zero lash) Valve Overlap: 20.4º Intake centerline: 111º Lobe separation angle: 110º (cam degrees) Valve angle intake/exhaust: 22º/20º For comparison the Promini cam has duration 262/262º. |
| | #13 (permalink) |
| MINI2 Regular Join Date: Oct 2003 Local Time: 05:07 AM
Offline | I see a lot of things in this engine that suggest toughness: relatively long stroke limiting RPM and giving a relatively flat torque curve, cast iron block, hydraulic lifters, and roller rockers. And there have been no bottom end changes for the JCW. This suggests we may have an engine, while not as refined as a Honda 4-banger, that will be very long-lived. Has anyone heard of any major "hard parts" failures in one of these engines (pistons, crank, etc.). With perhaps half-a-million of these engines in the field, the lack of any issues here is impressive. - Mark |
| | #15 (permalink) |
Offline | I don't know for sure; Larry is changing out the rods and will be using his special pistons that will deck .100 higher, and probably have a higher pin location, so it seems likely the R/S ratio can be improved. john |
| | #18 (permalink) |
| MINI2 Senior Join Date: Apr 2002 Location: Yreka, CA Local Time: 05:07 AM
Offline | Doesn't sound like good news for the stock pistons and the pulley reductions. TOO is saying ANY boost increase requires better pistons unless there is perfect mapping. Maybe there has not been enough miles put on these cars to see how the long before the pulleys kill them. Cooper S Red/White/White, Air, Computer, Cloth, DSC, Cold Weather. August build. |
| Mini Seat Measurements ??, | MarkeyG | Interior & Ice | 0 | Sep 7th, 2007 08:07 PM |
| Technical Measurements for engine ? | Gordz | MINI Cooper | 1 | Feb 6th, 2007 08:17 AM |
| Viper Stripe Measurements Please!!!! | LouieCoop | Exterior | 0 | Mar 30th, 2006 05:00 PM |
| Measurements | DIOJCW | Engine & Drivetrain Tuning | 0 | Aug 1st, 2005 11:18 AM |
| Can someone provide me measurements of your stripes? | Der Blue Potato | General Discussion | 2 | Jul 17th, 2002 01:40 PM |
