| MINI2 Regular Join Date: Dec 2003 Location: Sydney NSW Blacktown Local Time: 07:18 PM
Offline | Guys, whats the best RPM to launch the manual MINI cooper from a standing start ? ... best RPM to shift from 1st to 2nd? ... 2nd to 3rd? ... 3rd to 4th? ... 4th to 5th? all for a drag strip , of course. ![]() Daniel ![]() |
| MUGEN POWER Join Date: Mar 2003 Location: s2ki.com Local Time: 10:18 AM
Offline | between 3000 and 3500 rpm is enuff for a decent start as for between gears whenever u feel that you will accelerate faster in the next gear around 6000 rpm ruffly hope that helped ![]() |
| | #10 (permalink) |
| MINI2 Regular Join Date: Jul 2003 Location: Glasgow Local Time: 09:18 AM
Offline | Hehehehe yea there is a fine line, but I always like a good munch of the tyres and clutch. Yea it will screw the clutch but just get a new one, you dont do 1/4's etc and expect that not to happen I dont understand how you would say change at 4000rpm in 2nd when the car basically doesnt kick in until 4000 revs, assuming you are talking about the Cooper S.... The thread was for a Cooper ![]() Pretty much standard Mini Cooper last 1/4 time was 15.8@90 but the car I was racing down the 1/4 happened to be a 500bhp Escort Cossie with an extra 100 shot of nos lol. |
| | #12 (permalink) |
| MINI2 Master | Redline at every gear for fastest times. I don't do big launches, just rev up a little to 2000 or thereabouts, so can't help you there. MINI Cooper Cabrio: now the car with go cart handling really feels like an open go cart! "... the only man that can come home at 3 am in the morning without getting into trouble with his spouse is the owner of a British sports car!" -- Phil Bailey |
| | #13 (permalink) |
Offline | If you are going for an out and out time you really are maybe going to have to put your clutch's life on the line. Just went out on my lunch break there and launched from 3-6000rpm and 4-4.5 was the fastest. And as for changing gears you need to really learn where the power starts to die off, and change just before it, if you want to be really smart, look at a power graph and you are wanting to change just where the peak is. |
| | #14 (permalink) |
| Hangin at the Krusty Krab | I'm not sure about that. After peak power, the acceleration of the car reduces, so reving to the redline would actually be slower than reving to peak power (about 6000 rpm methinks) and then shifting. If the engine / gearbox is correctly designed, the next gear should engage at peak torque hence result in max acceleration. IMHO. |
| | #15 (permalink) |
| MINI2 Master | Even though power reduces after the peak, the acceleration is still above where it'll be when you shift up into the next gear as it will be much lower in RPMs and more importantly, much lower in gearing. Harry MINI Cooper Cabrio: now the car with go cart handling really feels like an open go cart! "... the only man that can come home at 3 am in the morning without getting into trouble with his spouse is the owner of a British sports car!" -- Phil Bailey |
| | #16 (permalink) |
| Numb from Jäger | The best launch results I've personaly felt where around 4000 rpm. A quick drop of the clutch, a short tire squeal, and you swear something broke.... until you look at the time slip. I go through the other gears up to about 7000-ish. I think 2nd is good to about 50mph. You'll hit 80 mph easy in 3rd. 4th goes takes it well past 110mph. Wouldn't even bother with 5th at that point. When just putt'n 'round, I think I launch around 2000-2500, then shift easy about 2500-3k there after. I'm not usually in a hurry and really don't pay much attention to it to say for sure. I guess I just go. -goin440 IB/IB MC |
| | #17 (permalink) |
| Hangin at the Krusty Krab | True, but your rate of acceleration will reduce beacuse of the power drop off. Wheras if you shift, the higher torque pulling lower gearing will surely result in at a better rate of acceleration (assuming everything is designed and matched correctly). If you were right, then shift lights would always be set at the redline (they're not), and by upping your rev limit you'd increase your acceleration performance (you don't). ![]() |
| | #18 (permalink) |
| MINI2 Master | In some cases this is true but if you look around for accel graphs you'll see that the Cooper is geared too wide for what you say to be true. With shorter gearing it would probably work but with the Cooper at max torque the gearbox is too low, especially in 1st and 2nd. Harry MINI Cooper Cabrio: now the car with go cart handling really feels like an open go cart! "... the only man that can come home at 3 am in the morning without getting into trouble with his spouse is the owner of a British sports car!" -- Phil Bailey Last edited by HarryHBMCC : Jan 8th, 2004 at 07:31 PM. |
| | #20 (permalink) |
Offline | well I launched at 4-4.5 and got 1/4 mile in 15.8@90 ![]() hehehe (Standard mini cooper) But I screwed my clutch at the same time (can be replaced) whole day of serious launching just made it heat up far far too much and it warped, wouldn't select any gear. Anyone know if the AP clutch fits onto the standard mini cooper cover? Last edited by PW51CAR : Jan 9th, 2004 at 12:19 PM. |
| Slight stumble at 3k rpm - Cooper S, 6 spd | smallzilla | Faults & Fixes | 9 | Nov 4th, 2005 02:18 PM |
| will 6k rpm kill my cooper | alfi | MINI Cooper | 18 | Oct 1st, 2004 10:25 AM |
| Best RPM to launch MCS? | nulltty | MINI in Motorsport | 7 | Jan 9th, 2004 11:59 PM |
| Cooper MPG(CVT?)and(5 speed) and RPM levels | MiNi | MINI Cooper | 29 | Aug 30th, 2002 07:26 AM |
| RPM Guidelines for Cooper | ctownsend | General Discussion | 8 | Jun 29th, 2002 08:39 AM |
