| MINI2 Regular Join Date: Jan 2002 Location: Perth Local Time: 09:44 AM
Offline | Gearbox The MINI coopers gearbox can't handle much more power than the standard cooper has. (torque is limited electronically in first and second in the JCW works cooper to prevent damage). How easy will it be to replace the gearbox with a 6speed Getrag 'box like the cooperS. I'm starting to feel that modifying the Cooper may be more hassle than it's worth considering the amount of extra torque handling mod's the Cooper S has been given. (extra drive shaft bearing, stronger gearbox) TRADE IN IMMINENT Cooper, Silver with Black Roof. Full Black Leather, Chilli, ASC+T Fully Run-in and Fast as Hell!(for a 1600) Track Days rule...... Speed Camera's Don't!!! |
| MINI2 Regular Join Date: Feb 2002 Location: Edinburgh Local Time: 09:44 AM
Offline | sounds sweet a 6speed box in a copper would be very expensive is it possible hmmmmmmm![]() S12COT, Cooper 'S' arrives 14th April after 3 years without a Mini i could not help myself! |
| MINI2 Regular Join Date: Feb 2002 Location: colorado Local Time: 09:44 AM
Offline | I think it will probably be feaseable it replace a 5-sp with a 6-sp since most of the time gearboxes have the same mounting flange and body mounting points within the same car line. However I see several obstacles. The first would be the cost of obtaining and the labor of replacing the gearbox and shift linkage. In the case where you can find a salvage car and do the labor yourself, it could make sense. The second is the current availability of the gearbox, there are few cars on the road with it installed. Both the Focus ST-170 (Focus SVT in the US) and the MINI Cooper "S" use the same gearbox, with the Ford model having 5% shorter (numerically higher) final ratios. So it will be in short supply for some time to come, I would imagine. The final hurdle is how you intend to drive your Cooper. If you do mostly 1st-3rd gear driving, the 6-sp. could be detrimental for its taller gearing compared to the 5-sp. If, however, you do mostly high speed motoring, then the taller 5th plus 6th gear would be an advantage. Jerry |
| How much is a new gearbox | Richard22b | Faults & Fixes | 4 | Jan 27th, 2007 12:42 AM |
| The new gearbox | Bayliner | 2nd Gen Engine & Drivetrain Tuning | 14 | Nov 24th, 2006 12:33 AM |
| gearbox??? | Richy777 | General Discussion | 25 | Jan 16th, 2006 09:42 PM |
| Gearbox?? | Mini-beast | Engine & Drivetrain Tuning | 2 | Oct 28th, 2004 07:13 AM |
| Gearbox.. (Another..) | foxtrotxray | Faults & Fixes | 1 | Sep 2nd, 2004 08:16 PM |
