Performance Torque
Old Feb 21st, 2004, 04:50 PM   #1
S33BBY
Local Time: 11:55 PM
Panel Filters (Yet Again!)
I've read through many many posts about replacement air filters and have found it difficult to come to a conclusion as to which is better out of the K&N and the Pipercross. Just to clarify, I'm talking about panel filters, not induction kits. Hopefully this post can eventually act as the definitive answer to which panel filter is the best
At first, I thought I'd understood that the Pipercross is better at filtering, whereas the K&N would last longer, but then that theory was crushed when I read that foam-based filters get clogged more easily. However, the fact that the cotton-based K&N filter wil last longer still remained.
So, am I right in thinking that the K&N is generally the better replacement filter? To make things even more complicated though, I've been reading good things about Green Cotton air filters, and can get one here in the UK for my MINI One at around £40, which seems reasonable to me. Any thoughts on these filters?
So, what should I do? Many thanks in advance.
JCW Sound Kit | H/K | Sat Nav | SS+ | Xenons | 17" Anthracite R90s | Goodyear Eagle F1 GS-D3s | ...
United Kingdom Male View S33BBY's Hyper Blue & Black 1st Gen MINI Cooper Profile   Reply With Quote
Old Feb 21st, 2004, 05:18 PM   #2 (permalink)
obehave
Mini Mod
obehave's Avatar
Local Time: 06:55 PM
Foam based filters do not get clogged more easily.
From what I remember a lot of off road filters actually use a foam pre filter with the primary filter (of whatever design) underneath.
The resy of your info seems OK.
There's really no "bad" decision here. I've used K&N filters off and on for almost 30 years. Never had a problem and never had to replace one. That said I also ran an Accel foam filter for years on my wifes Mitsu pickup and really liked it. Worked great until she wrecked the truck dodging a frigggin' cat Bad choice.
I'm sure this hasn't helped your decision at all
Old Feb 21st, 2004, 05:22 PM   #3 (permalink)
condition
Mini One Black 'n Chrome
condition's Avatar
Local Time: 12:55 AM
Hi,
I use the K&N drop in panel filter on my Mini One. It seems it has more power now and a little more sound. I'm very happy with the choice. I have no experience with the orther brands.
Ralf
Netherlands View condition's Solid Black & Body Color 1st Gen MINI One Profile   Reply With Quote
Old Feb 21st, 2004, 05:42 PM   #4 (permalink)
S33BBY
Thanks to the both of you for the replies. So it probably seems that the cotton filter is certainly a more safe if not a better choice than a foam filter.
All that really remains is a comparison between the K&N and the Green...
Old Feb 22nd, 2004, 06:01 PM   #5 (permalink)
DJC
DJC's Avatar
Hi, i fitted a K&N panel filter to my 2002 Cooper. Sounds good, not too loud and i think it feels better. One thing to check, if you get a K&N make sure the gasket referred to in the fitting instructions is in the box, mine was not. Hope this helps Damian.
United Kingdom Male View DJC's Chili Red & White 1st Gen MINI Cooper Profile   Reply With Quote
Old Feb 23rd, 2004, 12:18 AM   #6 (permalink)
S33BBY
Thanks for that Damian.
The K&N does seem to be the most popular, if not preferred choice. I'd still like to hear some opinions on the Green cotton filter. It looks fairly similar to the K&N...
Old Feb 23rd, 2004, 08:07 PM   #7 (permalink)
wow
I got a BMC pannel filter on my Cooper. I love it and can feel more torque. For more sound I did not close the airbox completly SOUNDS GREAT NOW. But i guess there is a power loss. Can anyone confirm that?
MINI, it is a way of life.
South Africa   Reply With Quote
Old Feb 24th, 2004, 12:53 PM   #8 (permalink)
David Woods
I fitted a K & N about a month ago, it does make a difference and at low revs the engine is noticably more responsive. When you put your foot down you can certainly hear the difference but it is not too obtrusive- when you are either cruising on light throttle on on the over-run you would not know that you had a different filter fitted.
One final observation is that fuel economy seem to improve if you do not feel the urgency to use the extra power- a useful bonus!
Old Mar 17th, 2004, 04:40 AM   #9 (permalink)
minitoo
Local Time: 02:55 PM
Don't know about a power loss with your air box open but aren't you sucking dirt now? I just swapped out my filter and if I remember right I thought my cooper sucks in the dirty air from under the filter and the top side with the lid is the clean side going into the engine. At least all the bugs were underneath my filter so if I left my box unsealed I think I would be sucking crud into my engine. Might want to check...fun noise would'nt be worth wearing out the engine.
United States Male View minitoo's Velvet Red & Body Color 1st Gen MINI Cooper Profile   Reply With Quote
Old Mar 17th, 2004, 07:41 AM   #10 (permalink)
SCB
StevieB
SCB's Avatar
Cooper S drop-in replacement?
Quote: Originally Posted by David Woods
I fitted a K & N about a month ago, it does make a difference and at low revs the engine is noticably more responsive. ...etc.
Do you know if they do a drop-in replacement filter for the new 2004 Cooper S...
If so who should I contact to get one?
Old Mar 17th, 2004, 08:01 AM   #11 (permalink)
JTT
Mini B'atch
JTT's Avatar
Local Time: 10:55 PM
Are there any drop in panel filters available that DO NOT increase the noise in the cabin, but do increase power/fuel economy?
England View JTT's Chili Red & Black 1st Gen MINI Cooper Profile   Reply With Quote
Old Mar 17th, 2004, 08:20 AM   #12 (permalink)
Hat
cook pass babtridge
Hat's Avatar
what about when you take the car in for service - those that have them, do you just tell the service dept not to remove your filter & replace it?
Old Mar 17th, 2004, 11:45 AM   #13 (permalink)
S33BBY
They sure do, take a look here: http://www.newminisport.com/SearchRe...yID=76&sub=POW.
Old Mar 17th, 2004, 12:07 PM   #14 (permalink)
bards
Clio 197 R27
bards's Avatar
Send a message via MSN to bards
I heard a rumour that a panel filter on an s will increase the noise of the super charger whine! Does anyone know if this is true? If so I will get one as soon as I get my car.
Old Mar 17th, 2004, 12:14 PM   #15 (permalink)
S33BBY
That's correct
Old Mar 17th, 2004, 12:34 PM   #16 (permalink)
J1JPE
New Job = $£€ +STRESS :o{
J1JPE's Avatar
Seb, have had a Pipercross Panel on my One for a few months now; as above, more torque etc ...
only thing I know about the Green Un is that a car with one fitted had less power on AmDs rolling road Mini2 day than a std car - cud just be variation in cars but it put me off ... and its an ugly green IMHO
Pipercross looks great ... is used in the JCW conversion I believe
K&N are a well respected brand - u pays your money etc
NB - when u fit the new panel read the DIY instructions on here if u've not done it before as u need to undo the retaining clip on the air feed pipe or else are likely to break theretaining clips when you lift the lid
air does come from the bottom through the filter a v.small gap between lid and filter shud be OK but there is a risk of sucking dirty air into the engine ....
havent taken mine in for service yet, are replacement filter, fluids etc included in tlc cover ???
if so, may swap back the std paper job and get a nice clean new one - suspect they aint so will leave the PX filter in and just say it was there when I got the car; might even be cheeky enough ask 'em to clean / spray treat it for me :}??
United Kingdom Male View J1JPE's Sparkling Silver & Black 2nd Gen MINI Cooper Profile   Reply With Quote
Old Mar 17th, 2004, 12:41 PM   #17 (permalink)
S33BBY
Thanks, that's very helpful
Old Mar 17th, 2004, 12:45 PM   #18 (permalink)
SCB
StevieB
SCB's Avatar
DIY instructions, where are they please...
Quote: Originally Posted by J1JPE
NB - when u fit the new panel read the DIY instructions on here if u've not done it before as u need to undo the retaining clip on the air feed pipe or else are likely to break theretaining clips when you lift the lid etc...
The DIY instructions your refer to, where are they please...can you provide a link?
Thanks,
StevieB
Old Mar 17th, 2004, 12:50 PM   #19 (permalink)
S33BBY
Thanks,
StevieB
I assume he means the ones that come with the filter.
Old Mar 17th, 2004, 12:57 PM   #20 (permalink)
SCB
StevieB
SCB's Avatar
Doh...
Silly me, oh and thanks for the link the filter looks good, I will think about it and get one when I have done the 1250 mile run-in period and that should put some dirt on the stand filter for when I swap them for the TLC services.
StevieB
K&N vs Pipercross Panel Filters MarkA Engine & Drivetrain Tuning 6 Mar 19th, 2007 05:43 PM
Any difference in perfomance panel filters Jah mini Engine & Drivetrain Tuning 12 Jun 8th, 2006 08:51 AM
MCS Panel Filters; Recomendations? SalemMINIDriver Engine & Drivetrain Tuning 5 Nov 17th, 2005 02:47 PM
performance panel filters Leigh Engine & Drivetrain Tuning 8 Mar 12th, 2005 12:45 AM
Panel filters iancoates Engine & Drivetrain Tuning 2 Oct 28th, 2004 03:34 PM
