| MINI2 Regular | Upgraded Brakes instead of Big Brake System Just installed front Brembo cross drilled and slotted rotors, rear Zimmerman cross drilled and slotted rotors, ebc greenstuff pads in front and back, and stainless steel braided lines all around with ATE super blue fluid. Install wasn't too bad and I think the whole job including installation ($140 to a local shop) was $600. Here are some pics...... The problem is that I think that there is something wrong as I seem to see some scoring on the fronts.... and it only seems like it's at the outer edge of the rotor...but it's not exactly scoring since I ran my finger along the "line" and did not feel a groove.....I bedded them in as best as I could have (living in Brooklyn) along Shore Road as there aren't too many people there....But I wonder if I did something wrong. The rears seem to be fine. I did not notice these lines after installation (and rotating the disc around a few times). Only after I bedded them in and drove about 75 miles on 'em. Could it be that the piston was not pushed back far enough? Another thing is that when I roll down the windows and am going about 15 mph and hit the brakes and release a few times I can actually hear the pads against the rotor...but not a grinding sound...just a LOUD kind of braking sound. Can anyone give me any input on what you see in the pics? Also it seems like the pad is touching the rotor while at a standstill. Is this right?? Thanks in advance..I'm utterly confused. "Do or do not. There is no try." - Master Yoda Last edited by LordOfTheFlies : Jul 16th, 2004 at 04:45 PM. |
| MINI2 Regular Join Date: May 2003 Local Time: 05:35 AM
Offline | Nice setup u got there..just an observation.. but correct me if I am wrong, but the slots on teh rotors seem to be in the opposite direction (against) the driection of rotation? shldn't it be pointing /// for the LHS rotors and \\\ for the RHS rotors? ![]() |
| AWOL | how did you bed them in ?... it sounds from your post like you did some hard braking to do this ?... (sorry if i'm reading that wrong)... I was always told to avoid havy braking for the first 200 miles, otherwise you get glazing of the pads which reduces efficiency for a while.... the pads should not touch the disk when not applied, that could be causing the lines/marks.... however i'm no expert ! |
| | #6 (permalink) |
| MINI2 Senior Join Date: Nov 2003 Location: Jacksonville, FL Local Time: 05:35 PM
Offline | There are many different bedding in procedures. As he installed EBC green stuff ( a slightly high performance pad), hard braking probably was his best bet. The idea is to warm up the brakes then do some near lock-up stops from about 70 to 10 (not completely stopping). Very high performance setups actually require this be done a few times to completely bed them in. Here's a link on bedding in brakes: http://www.zeckhausen.com/bedding_in_brakes.htm |
| | #8 (permalink) |
| MINI2 Regular | Here's a link to Stoptech's site showing the direction of the slots. http://www.stoptek.com/productphotos/mini/mini.htm Look at the third pic down. I installed them correctly ![]() "Do or do not. There is no try." - Master Yoda |
| | #10 (permalink) |
| MINI2 Regular | Actually I forgot to mention that I think that when he put on the rotors that he did not put them on straight. He only tightened the rotor using the one torx screw. On the backs we used 3 bolts as well. When he spun the front rotors to see if they were straight there was a definitive grinding sound. However, he didn't spin them ALL the way around - obviously stopped when it started to grind....which then leads to the question why is there a rin ALL the way around the rotor? Another interesting thing is that there are no grooves on the inner side of the rotor.....So what up with that? Should I tell him to pay for replacement front rotors? Should be $130 or so shipped. "Do or do not. There is no try." - Master Yoda |
| | #12 (permalink) |
| AWOL | I'd give it the 200-300 miles before doing anything else.... if the disks werent on straight you have really bad vibration under braking... doenst sound like you have that... Give it some time and miles then if they are no better get them replaced.... time will tell with this one ! ![]() |
| | #14 (permalink) |
| Track Junkie Join Date: Sep 2003 Location: Hong Kong Local Time: 05:35 AM
Offline | According to Brembo or AP (can't remember which website), the direction of the slots don't matter. It's the design of the cooling vents between the steel plates that determine whether the rotors are directional. Road: 2002 MCS with KW V2 and other bolt-ons Track: Lotus Elise race car |
| | #15 (permalink) |
| Mini Mod Join Date: Sep 2002 Local Time: 05:35 PM
Offline | The slots are on one side only because that is the only side the pad is on. If you had a big a** Brembo kit with pistons on both sides then you'd need slots on both sides. Hope this works out for you. Keep us informed. BTW nice looking stuff. I'll go the same route once the OEM stuff wears out. |
| | #16 (permalink) |
| MINI2 Regular | Thanks.....but wha "slots" are you talking about exactly? Both sides of each rotor has slots on them. And each rotor has pads on both sides so I'm really confused now! Here's the same original pic but I've highlighted the exact area of concern. "Do or do not. There is no try." - Master Yoda |
| | #17 (permalink) |
| AWOL | I had another look at the pictures... that groove is very deep, I doubt it will disappear for a long long time !.... I doubt that incorrect fitting could cause that, but some rogue material in the pad could well do that !.... maybe worth seeing if your mechanic will take the pads off again and have a good look at them..... i'd be surprised as EBC are great quality, but never say never, often we rule out thngs without checking them only to find later they were the cause.... |
| Big Brakes | MNIMGK | Wheels, Tyres & Brakes | 6 | May 8th, 2006 09:18 AM |
| Upgraded Brakes - Brake Warning Light Solution | MINIALEX | Wheels, Tyres & Brakes | 4 | Jan 4th, 2006 07:09 PM |
| Upgraded brakes?? APs? | Intrepid | Engine & Drivetrain Tuning | 23 | Apr 11th, 2004 02:54 AM |
| Big Brakes | jon.od | Engine & Drivetrain Tuning | 0 | Apr 25th, 2003 07:59 PM |
| Big Brakes!!!! | Greenwood | Engine & Drivetrain Tuning | 0 | Jul 16th, 2002 04:57 PM |
