| MINI2 Newbie Join Date: Sep 2004 Local Time: 04:37 PM
Offline | Has anyone had any problems with their 19% pulleys? I have had one about 8 months but have not installed it because people keep telling me it's going to mess up the car. I would rather not kill my mini. http://www.cardomain.com/memberpage/602546 |
| The Silverado Join Date: Apr 2003 Location: Sydney, Australia Local Time: 07:37 AM
Offline | im no pro... from what ive read though.. a 19% pulley is strictly for street use! no tracking.. i think there is a thread going around about someone using a 19% pulley that blew something in his car... check the performance/tuning thread.. Benefit of using a 19% is you dont need to run any ECU upgrades.. and you get more power and lover revs.. I have heard (dont know how true this is) that the MCS supercharger is said to have a 100% life span even if a 16% pulley is used... so 15% is the safest bet.. with the 19% you aren't meant to rev the engine too high for long time periods.. overall... if you are a street driver that isn't too aggressive then the 19% should work.. thats just my opinion though ![]() good luck! benno |
| MINI2 Senior | If your this worried about putting in a 19, then don't do it. I don't feel that the long term effects are in yet on this mod. There are now questions of possible head gasket failure with the 19, but I'm thinking that there is no connection. There are several here that love there 19 and will tell you to go for it, but IMHO, I would only do so with caution. Street? Track? Not that much difference in how one drives a MCS as far as I’m concerned. If it proves bad for the track then why would I want it in my car. ![]() |
| MINI2 Master Join Date: May 2002 Local Time: 05:37 PM
Offline | The difference between track and Street use.. At the track you are at sustained High RPMs 5k+. That is measure in Miles and not feet. Where in doing so you are running the SC at near its Mechanical limit without proper cooling for SC its self cause it to overheat and some excess belt wear. As for the Headgaskets blowing. Yes its happen to someone that was using it on the Track, But im not going to say the 19% pulley was the reason behind it. Granted it helpped but IMHO there were something more going on. I've been running the 19% for about a year now with no problems. I've been known to drive the MINI very agressivly on the street as well as do several Drag racing events. At the moment i've currently worn out the Stock rubber bushings on the front end and have to address that issue. There are also rumors of 21% and 25% pulleys out on the market. From what i've gathered on those. You must have some wear on the SC before its considered to put them on. Again this is only a rumor i havent seen any facts to this as of yet Hope this helps some 02 MCS DS/W (Totaled November 02 on Fall Folage Run) 03 MCS DS/W (See my MINI Profie for extensive list of mods) |
| | #6 (permalink) |
| Mini Mod Join Date: Sep 2002 Local Time: 05:37 PM
Offline | I think that comes from the earlier calculations that running over 6100 RPM will spin the SC faster than it's stated engineered rating. You'll also generate more heat than a 15% will at the same engine RPM. You may see more boost but I don't know if there's much net gain due to the heat losses. A bigger IC helps I'm sure but I haven't seen any real test data on it. Our resident data logger doesn't come here much any more. |
| | #7 (permalink) |
| the DASH LIGHT king ? ;) | not sure if the eaton super chargers are in the same league as my old polo supercharged (g-lader scroll type) but if u ran a smaller than usual pulley then if puts more load and wear on ya charger which aint gud !!!! i used to have to keep getting my charger overhauled every 30,000 miles and that was 500quid a time but i dont wanna be scaring anyone if thats not the case with eaton chargers ![]() ![]() THE Legend who helps ALL MINI owners |
| | #8 (permalink) |
Offline | Well thanks for the help guys. I will be on the street most of the time and as far as track use I will only be on the drag strip. I'm currently working on building a front mount intercooler based off the Webb motor sport front mount. That should take care of some of the SC overheating. Is there anyone out running a Webb motor sport front Mount?? The Webb motor sport system looks extremely mean! Here is the link for the Webb page, go check it out. http://www.webbmotorsports.com/performance.php The price is steep though. http://www.cardomain.com/memberpage/602546 |
| | #10 (permalink) |
Offline | Is there any other performance SC on the market built to take the extra heat from the 19% pulley? About the Intercooler, now that I looked at my post your right the intercooler has nothing to do with the SC over heating, at work right now reading and typing posts and dealing with customers screws me up some times. The head gasket may become a problem with the 19%'s extra boost your right. I'm sure there is someone out there working on that problem as we talk. http://www.cardomain.com/memberpage/602546 Last edited by racer714 : Nov 17th, 2004 at 06:55 PM. |
| | #11 (permalink) |
| Nut Job Join Date: Jun 2003 Location: In a van, down by th Local Time: 04:37 PM
Offline | A) I think you are asking if there is another SC that could take the place of the Eaton?? Yes, the Autorotor. It is not a simple swap, nor would you use the 19%. B)Tell your "costumers" that Halloween is long over.... C)I am the someone with the head gasket/ head bolt issue. If you want more info, PM me. |
| | #12 (permalink) |
Offline | Didnt know it was you BISCH. Sorry to hear you had the problem. Yes pls pm him if you want more info since he's the one with first hand knowledge. 02 MCS DS/W (Totaled November 02 on Fall Folage Run) 03 MCS DS/W (See my MINI Profie for extensive list of mods) |
| | #13 (permalink) |
| saving the world Join Date: Jul 2002 Location: Singapore Local Time: 07:37 AM
Offline | huh? Where did you get that idea?! I agree with Mugami has said in this thread. For street use, unless you're a maniac, it will be fine, but for track use, probably not a good idea. |
| | #14 (permalink) |
| MINI2 Regular Join Date: Jul 2004 Location: Harpswell, ME Local Time: 05:37 PM
Offline | Head gasket failure should not come as a surprise at all as a consequence of increasing supercharger speed, as the same pulley also drives the water pump. Higher water pump speeds=greater pressurization of cooling system. Failure at the head gasket, or eslewhere in the cooling system would seem to be a more likely outcome than supercharger failure. |
| | #15 (permalink) |
Offline | I don't see how the water pump is being spun faster, because the reduction is with the SC pulley only. The crank pulley is still spinning at the same speed, and when you do the SC pulley you reduce the belt size so your belt is not loose. This is just what I have been told in the past by other tuners. http://www.cardomain.com/memberpage/602546 |
| | #16 (permalink) |
Offline | Would have thought of the same thing Racer.. But in the case of the Mini the Water pump is spun off the back side of the SC instead of the Drive belt. Therefor if the SC is spining faster then so is the waterpump. If it was spun from the Drive belt indepent of the SC then there would be no change. Main concern i had isnt the pressure but Cavatation from the pump being over spun causing airpockets and no water flow. 02 MCS DS/W (Totaled November 02 on Fall Folage Run) 03 MCS DS/W (See my MINI Profie for extensive list of mods) |
| 15% SC + 2% crank pulley or 17% SC pulley? | mobile23 | Engine & Drivetrain Tuning | 49 | Jul 7th, 2007 05:19 AM |
| How much more HP/TQ does the 19% pulley give over a 15% pulley? | 05MCSConvertible | Engine & Drivetrain Tuning | 1 | Sep 27th, 2005 10:06 PM |
| stock MCS crank pulley the same as stock MC pulley? | mini_macky | Engine & Drivetrain Tuning | 5 | Aug 24th, 2005 04:35 PM |
| Pulley? | Fisher | Engine & Drivetrain Tuning | 2 | Apr 7th, 2005 01:23 PM |
