| MINI2 Newbie Join Date: May 2005 Local Time: 08:06 AM
Offline | A cheap performance mod worth doing... I removed the throttle body on my Cooper and found that the throttle plate is pretty thick. The thickness is not an issue, but the edges are. When the throttle is wide open, the sharp edges of the plate cause an aerodynamic disturbance, both at the leading edge, and trailing edge. So, I filed the edges off, to form more rounded, blunt edges. Obviously, you shouldn't remove any of the diameter, or the idle speed will be affected. After re-installing the throttle body, I replaced the stock air intake and filter box with a cone-shaped filter like they sell at Moss Mini. Passing was noticeably improved. So, the performance gains come at high RPM's, but you need it in the U.S., because high performance engines are common in just about any kind of vehicle on the road, and sometimes you have to out-run them just to pass (people don't like being passed for some reason.). Plus, you can hear an angry growl as you wind it up, instead of almost no noise. Personally, I like a performance sound to go with my performance car. It's cheap and it works. -love, Jeffy. |
| Trained Monkey Join Date: Jan 2001 Location: Bedfordshire Local Time: 02:06 PM
Offline | Did you try it just with the filter change first, as that makes the engine purr/growl nicely on it's own, quite dramatic for such a small mod really! There aint no party like my nana's tea party |
Offline | Yes... That's where the growl came from. I don't know how much the rounded edged throttle plate is worth in horse power, but its easy to do, and it corrects a flaw that shouldn't have been, anyway. -Jeffy. |
![]() What's this button do? Join Date: Jul 2004 Location: Our Own Little World Local Time: 08:06 AM
Offline | Smoothing the plate out probably doesn't help all that much (though I'm sure it looks better). If you've ever had one of those balsa gliders when you were a kid, the leading edges are always squared-off and never rounded or really aerodynamically shaped at all. The difference in performance between the flat plate and something with a rounded edge is so small that it's not worth doing. I'd guess that pretty much all of your performance/sound improvement came from the filter. -Eric |
| cheap, easy mod. (more power?) | tuscan_thunder | Engine & Drivetrain Tuning | 11 | May 29th, 2005 04:56 AM |
| simple cheap mod help needed for a 2003 cooper | matt21 | Engine & Drivetrain Tuning | 14 | May 8th, 2005 01:39 AM |
| Anyone tried a EBay cheap MOD Chip Tuning ? | uwsearch | MINI One Diesel | 5 | Mar 25th, 2005 12:47 PM |
| Cheap Effective Mod | thesupermario69 | Exterior | 0 | Jul 7th, 2004 12:01 AM |
