Old Jun 30th, 2005, 02:55 AM   #1
gary Parker
Local Time: 01:54 PM
JCW panel filter change to K&N
Good evening, I just spent about an hour searching the site to try and find out how to get my JCW air box open without breaking anything in order to put in a K&N filter. I worked out the two screws in the front of the box and tried to move the box forward, but I'm afraid of breaking something. It's so tight in there and looks like there is more to remove from the box before it comes off. Just looking for a few suggestions.
Old Jun 30th, 2005, 03:14 AM   #2 (permalink)
Rakey
Four Candles?
Rakey's Avatar
Local Time: 02:54 PM
I know the standard MCS box has 4 screws, one at each corner of the cover, is it not the same for the JCW air fitler box?
Is it the 210bhp air filter box that you are looking to put the K&N in? Interesting idea if it is, and look forward to hearing if there is any improvement to the JCW filter
Old Jun 30th, 2005, 03:47 AM   #3 (permalink)
gary Parker
Hi Rakey, the JCW air box is different from the standard one. I can see the front two screws. but the rear ones are not accessable from what I can see. It's also electronicly controled to open to fresh are over 4500 rpm. and all that stuff is connected to the top of the airbox. I'm sure it's easier than it looks, but I'll wait for someone with the same JCW box to key in, Thanks for getting back to me..Gary
Old Jun 30th, 2005, 04:10 AM   #4 (permalink)
Rakey
Four Candles?
Rakey's Avatar
no worries Gary, never really looked at my JCW air box to figure out how to open it, just thought it would be the same
I would have a look at mine for you, but its in the UK, and I am not at the moment
Do you think there will a large gain by changing the actual filter in there? As I would have thought that the filter supplied would be a higher spec to a standard MCS?
Old Jun 30th, 2005, 04:34 AM   #5 (permalink)
Pamlico
Dead Man's Curve? Feh.
Pamlico's Avatar
Local Time: 09:54 AM
Send a message via AIM to Pamlico
The filter in the JCW airbox isn't a panel, rather it's a cone similar to some of the aftermarket intakes.
United States Male View Pamlico's British Racing Green & Black 1st Gen MINI Cooper S Profile   Reply With Quote
Old Jul 1st, 2005, 04:37 AM   #6 (permalink)
gary Parker
Filter
Thanks Pamlico, Guess the panel filter wouldn't fit anyway. Maybe someday I'll figure out how to get the top of the box off. Never thought it would be a cone type. Nice idea though...Gary
Old Jul 1st, 2005, 01:25 PM   #7 (permalink)
Pamlico
Pamlico's Avatar
Glad to help. Here are a few pictures and descriptions posted by Greatbear on NAM that you may find interesting (click thumbnails to enlarge):
The first shows the filter element box after it's been opened. The filter attaches to a bracket seen on the left of the image,
Next is the conical JCW filter compared to the stock flat panel filter:
Finally, this is what's inside the box. The canister is a vacuum reservoir which allows the air door to be opened using a vacuum diaphragm despite operation at wide open throttle (and therefore no available vacuum from the engine). The canister holds enough vacuum to keep the door open regardless of how long the engine is held wide open. The collar where the element attaches can be seen on the right side of the image.:
The replacement cost of the JCW element is on the order of $90. There have been mentions that some of the available aftermarket elements may fit, but I don't know if that's been determined yet.
Old Jul 2nd, 2005, 01:21 AM   #8 (permalink)
gary Parker
Filter exposed
Thanks once again pamlico, the pictures are great and very helpful. Catch you later...Gary
Old Jul 2nd, 2005, 02:58 AM   #9 (permalink)
gtshnzr
gtshnzr's Avatar
Local Time: 08:54 AM
Send a message via AIM to gtshnzr
I'd certainly be interested in a K&N replacement for the JCW filter. I had a K&N before the upgrade and I really liked it. The part number for the JCW filter is 13-72-0-395-826
So if anyone can figure out a match, please post, and BTW here's a related thread:
http://www.mini2.com/forum/engine-drivetrain-tuning/85930-mini-cooper-s-works-airfilter.html
P.S. I still have the K&N for a 2003 MCS with about 8-10K miles on it (cleaned and retreated 2x), so if anyone thinks it deserves a good home in their MINI, send me a PM. I just couldn't handle having the dealer just throw it out after the '05 210 upgrade, and its sitting in the basement just begging to be abused.
Early is on time; On time is late.
United States View gtshnzr's Solid Black & Body Color 1st Gen MINI Cooper S Profile   Reply With Quote
Old Jul 3rd, 2005, 04:34 AM   #10 (permalink)
BFG9000
Local Time: 03:54 AM
Just replaced my stock box with the JCW box. Both the stock MCS and the JCW box have two screws each, and after taking those out they are undone by pushing the upper lid towards the firewall and then up to unlatch the hooks.
I am hoping a reusable filter will be available by the time my element needs changing. On NAM it would appear there are vendors already working on it.
Old Jul 3rd, 2005, 03:24 PM   #11 (permalink)
gary Parker
Filter ox
Thanks everyone, the last post got the box top off....thanks again
Old Jul 5th, 2005, 01:16 PM   #12 (permalink)
jwardell
jwardell's Avatar
Send a message via AIM to jwardell Send a message via Skype™ to jwardell
Sorry I hadn't seen this thread earlier, I took apart my JCW intake this weekend and posted pictures and photos here:
http://www.jwardell.com/mini/jcwintake.html
Yes, to remove the airbox, it must be slid backwards and then pull the rear up.
I hope alta or someone steps in and makes an alternative filter if MINI is going to charge that much for theirs.
United States Male View jwardell's Solid Black & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Jul 6th, 2005, 01:29 AM   #13 (permalink)
gary Parker
Filter exposed
Jwardell, great pictures and instructions. Again, great job...Thanks Gary
K&N Panel Filter tom2005 Engine & Drivetrain Tuning 10 Jul 7th, 2006 08:06 AM
K&N Panel Filter or JCW? Gr1zzLy Engine & Drivetrain Tuning 9 Jan 16th, 2006 04:56 AM
K & N panel filter for mini one/one d/ cooper & 2 spoke steering wheel st not leather Pepper'D For Sale 1 May 6th, 2004 12:14 PM
How do I change my air filter panel? Zeede Engine & Drivetrain Tuning 12 Nov 5th, 2003 01:35 PM
K&N Panel Filter *****SOLD***** ScottyHP For Sale 3 Aug 19th, 2003 10:07 AM
