Visit Mini Mania UK
Old Jul 25th, 2005, 09:54 AM   #1
whokilledkaji
whokilledkaji's Avatar
Local Time: 08:13 PM
Air Intake / Induction?
Need reccomendations on Air Intake / Induction systems... I'm looking for a little extra power and good sound. Any reccomendations?
Japan   Reply With Quote
Old Jul 25th, 2005, 10:06 AM   #2 (permalink)
ianw12345
Cooper boy!
Local Time: 11:13 AM
Send a message via MSN to ianw12345
well a panel gives you improves smoothness through out the rev range similar to a standard induction kit,but if its noise your after go for the induction kit over the filter, say a 57i from k&n, whereas if you go to the next level and get a k&n typhoon or pipercross viper you get much larger gains in power and the noise is again better, these are both direct cold air feeds comapred to a standard induction kit which will suck in hot air from the engine bay unless its enclosed. hope that helps a little bit,
Ian
Roll on R56 JCW COOPER S!!!!! ETA 2weeks.....and counting!!!!
Wales View ianw12345's Solid Black & Body Color 1st Gen MINI Cooper Profile   Reply With Quote
Old Jul 25th, 2005, 09:20 PM   #3 (permalink)
whokilledkaji
I'm looking at the K&H Typhoon and ALTA intake system... Which is better I wonder... Any experience?
Old Jul 26th, 2005, 07:35 AM   #4 (permalink)
ianw12345
Cooper boy!
id say the alta, but each to their own...think performance is move proven with the alta over the typhoon, but dont quote me on it!
Old Jul 26th, 2005, 12:37 PM   #5 (permalink)
whokilledkaji
Yeah, I'm thinking alta too... They seem to have good customer support...
Old Jul 26th, 2005, 08:08 PM   #6 (permalink)
paul wheadon
We'll be back.........
paul wheadon's Avatar
Just throwing in my thrupenny bits worth............I've just fitted an Alta and the improvement over the stock filter is fantastic, excellent throttle response, the awesome sound you get from it is also worth the admission fee alone, not to overpowering when driving normally, but hairs on the back of your neck job when you hit the floor.......
Yep..........get the Alta, by the way I dont work for them either!!!!!!!!!!!!!!!!!!!!!!!!!
Dark Silver/Black MCS (Carlisle) - Now Stopped Drooling..............Now sitting in Lloyds MINI very cherished dept!!
Minnie Mouse is all that is left.......
England View paul wheadon's Dark Silver & Black 1st Gen MINI Cooper S Profile   Reply With Quote
Old Jul 27th, 2005, 07:41 AM   #7 (permalink)
whokilledkaji
Cool... I'm definetly going to go with Alta now...
I'm not sure if my usual shop in Japan can get the Alta though... I may have to order it myself and do the install too... Is it hard to install I wonder???
Old Jul 27th, 2005, 10:25 AM   #8 (permalink)
minigolf
Blue is the colour!
minigolf's Avatar
Local Time: 09:13 PM
I'm expecting an ALTA CAI in the next couple of weeks, bought directly from the States. I'll be trying to fit it myself also (well, with some help from a few friends who are a bit wiser than I).
Here's some extra reading for you, and a nice pic too.
http://store.webbmotorsports.com/ind...1ee00ca7891b51
Hmm, there used to be a How To on the webbmotorsports site, but that doesn't appear to be the case. No matter I'm sure there'll be instructions flowting around on the net somewhere.
Australia Male View minigolf's Indi Blue & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Jul 27th, 2005, 04:16 PM   #9 (permalink)
paul wheadon
The fitting is pretty straight forward, simply removing the stock filter, although leaving the bottom section, removing a panel and genearlly just taking your time following the instructions and being careful when unplugging and plugging together the ECU.
Took me just over an hour. Good luck........
Old Jul 29th, 2005, 11:33 PM   #10 (permalink)
chaincooperS
MINI Jedi Knight
chaincooperS's Avatar
Local Time: 06:13 AM
Thumbs up
Do yourself a favor and get the Webb Motorsports instructions with photos. You'll have to hunt for it on NAM, the photos on Webb's site have vanished... I just completed the install about an hour ago, and it was relatively easy. If you have large hands, the torx bolts on the left side of the heat shield (facing the rear of the car) are a little tough to get in while working around the battery cable, and the factory hose clamps are tricky to get back on. Other than that, its a breeze. You're going to love the increased supercharger whine!
United States View chaincooperS's Dark Silver & Black 1st Gen MINI Cooper S Profile   Reply With Quote
difference cold air intake and normal air intake filter falconetti Engine & Drivetrain Tuning 17 Apr 13th, 2006 09:53 AM
Wich intake/induction kit? PuijkeN Engine & Drivetrain Tuning 0 Feb 9th, 2006 09:11 AM
ProMini Cold Air Intake VS Alta Cold Air Intake??? SS Mini Engine & Drivetrain Tuning 5 Dec 13th, 2005 12:48 AM
Removing air intake hose in order to fit cold air intake system Spoony Engine & Drivetrain Tuning 7 Jul 29th, 2005 02:41 PM
Best Placement for air intake , to avoid water into engine ( viper induction Kit) minionefun General Discussion 0 Apr 26th, 2005 09:02 PM
