GizzmoUSA
Old Jul 28th, 2005, 02:34 PM   #1
05MCSConvertible
Local Time: 10:41 PM
What would a 3% oversized (lightweight)oversized crank pulley do for factory boost?
I want to change pulleys on the 05 MCS and have heard that once you put a pulley on it is very hard to return stock. I would much rather convert the car back to stock when I sell it due to dimished value. If I put in a 3% Oversized crank pulley from ALTA would I still get a big boost increase similar to using a 15% pulley. Also crank pulleys can easily be replaced with stock, correct?
Canada   Reply With Quote
Old Jul 28th, 2005, 02:50 PM   #2 (permalink)
MINIAC
MINI Profiler
MINIAC's Avatar
Local Time: 03:41 PM
Online
NO ... it would be equivalent to having a 3% reduction pulley on the supercharger.
Old Jul 28th, 2005, 05:42 PM   #3 (permalink)
Mike Edwards
Mike Edwards's Avatar
Local Time: 11:41 PM
Surely the effect is more than that?
The crank pulley looks to be a different size to the charger pulley - so you should be looking at the change in ratio?
England View Mike Edwards's Hyper Blue & Body Color 1st Gen MINI Cooper S Profile   Reply With Quote
Old Jul 28th, 2005, 06:53 PM   #4 (permalink)
MINIAC
MINI Profiler
MINIAC's Avatar
Online
From the GT Tuning website:
The larger diameter version gives the equivalent 'gearing change' to the supercharger of 'minus 3%' .
Old Jul 28th, 2005, 07:54 PM   #5 (permalink)
willymcd
metal lord
willymcd's Avatar
Local Time: 02:41 PM
Send a message via AIM to willymcd
is it 3% reduction in circumference, diameter, or radius???
Old Jul 28th, 2005, 07:59 PM   #6 (permalink)
MINIAC
MINI Profiler
MINIAC's Avatar
Online
Door Number 2 ...
diameter
Oversized, Lightened Crank Pulley futureal33 Engine & Drivetrain Tuning 27 Feb 28th, 2007 12:46 PM
planning to put a lightweight crank pulley...any suggestions? mini_macky Engine & Drivetrain Tuning 1 Aug 26th, 2005 07:28 PM
alta lightweight crank pulley asinn Engine & Drivetrain Tuning 4 Apr 15th, 2005 10:12 AM
Question to Oversized Tire people kyriian Wheels, Tyres & Brakes 3 Jun 15th, 2004 03:33 AM
Four doors instead of two oversized ones Shep Future Variants 15 Nov 8th, 2002 09:18 AM
