Old Jul 28th, 2005, 07:50 PM   #1
05MCSConvertible
Local Time: 10:37 PM
Weight Versus Horsepower..... My experience and my take on it! Car pics included
On my last car which was a 99 C2 Cabriolet, I put on the brembo frt/rear big brake conversion. It saved me 8 or 10 lbs a corner. That made a big difference. I was in a bad car accident and had to replace my 19"s, insurance wouldn't cover them as they exceeded the cost of the factory wheels by a large margin. They were 335/35/19 in rear and 245/40/19 front. When I went from the 19's to a set pf Techart 3 piece 18's that I picked up used with tires for 2400$ That also made a BIG difference in acceleration as hey were roughly 20lbs lighter per rim/tire combo. Last but not least I removed the factory rollover system (45lbs) removed the rear seats to fit the cab rollbar and (+15lbs) and replaced the factory power seats with carbon fiber sparcos (75lbs) So in total I removed 105lbs of weight from the vehicle and another 104lbs of unsprung weight. Believe me when I tell you that after doing Techart header/exaust and high flow cats, and Gemballa ECU remap. Although I noticed a fair power increase, I never dynoed so I can't back the 35hp claim. I will say that the weight savings made a much bigger impact on the acceleration and handling of the vehicle.
Something to think about for you hardcore modders and racers. Did I mention that not only did I lose 100% of the value of the aftermarket parts, but I also had a difficult time selling it because it was too tricked out. The S is a very fun car. Very tossable, but the speed is a problem at this point so I am opting to fix that problem. Although in a different league as the 996 was, the Mini is very fun and is very good at drawing looks. I am such a big guy I feel like a clown in a clown car... I love my new mini just as much as I loved my Porsche
Attached some pictures
ID:	95047  Click image for larger version
ID:	95048  Click image for larger version
Canada   Reply With Quote
Old Jul 29th, 2005, 07:22 PM   #2 (permalink)
speedynz
Local Time: 10:37 AM
Thumbs up
Great post, you'd better look out for the proposed lightweight Mini that Paul has been talking about (New Variants forum).
New Zealand   Reply With Quote
Old Jul 31st, 2005, 10:02 PM   #3 (permalink)
RedUn
MUGEN POWER
RedUn's Avatar
Local Time: 11:37 PM
sweet car
Japan Male   Reply With Quote
Old Aug 1st, 2005, 08:23 PM   #4 (permalink)
BFG9000
Local Time: 12:37 PM
SCC magazine took nearly 1100 pounds/500kg off a Sentra (originally weighed only slightly more than a MCS) and dropped 1/4 mile by just 2 seconds. So the lightweight MCS will mostly be for improved handling: http://forums.vwvortex.com/zerothread?id=776885
A similar experiment on a Cadillac 20 years ago got it into the 12s.
Old Aug 1st, 2005, 08:50 PM   #5 (permalink)
05MCSConvertible
The Sentra lost 1100 lbs. Good for 2 seconds. That is a big drop in 0-60. 1100 lbs is the equivalent of 110RWHP. For every 10lbs it is 1HP. So if I was the sentra owner I would be happy a piggy in a mudbath to shave that much time off my car.
Old Aug 1st, 2005, 09:09 PM   #6 (permalink)
rkw
Local Time: 03:37 PM
The thread referenced above is hilarious.
Before
Curb Weight: 2,762 lbs
1/4 Mile:16.3 @ 84.0 mph
60-foot:2.9 sec.
0-60 mph:8.6 sec.
After
Curb Weight:1,674 lbs
1/4 Mile:14.3 @ 93.2 mph
60-foot:2.6 sec.
0-60 mph:5.8 sec.
United States View rkw's Pepper White & Black 1st Gen MINI Cooper Convertible Profile   Reply With Quote
Old Aug 2nd, 2005, 09:57 AM   #7 (permalink)
robbo mcs
Track Addict
robbo mcs's Avatar
Local Time: 08:37 AM
Hi,
"Just 2 seconds"
I ran on a drag strip against a modded 996 porsche turbo, which was running sticky tyres It beat me by "just 3 seconds". I swear it was finished when I was around half way down the circuit. The difference in acceleration was enormous A 2 second difference on a quarter mile is a massive improvement in performance
Robbo
Mods: Hartge kit, CAI, oil cooler, headers, cat & exhaust, bilstein coilovers, adjustable bars & camber plates, quaife diff, roll cage, seats, harnesses
GO MADDIE and SPARKY!
Australia View robbo mcs's British Racing Green & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Aug 2nd, 2005, 11:24 AM   #8 (permalink)
Charger_Pete
Mini 2 Slap Head
Charger_Pete's Avatar
Send a message via ICQ to Charger_Pete Send a message via AIM to Charger_Pete Send a message via MSN to Charger_Pete
You should expect to see 0.3sec improvement in 0-60mph for every 100kg of weight removed. This is a fairly robust engineering rule of thumb.
United Kingdom View Charger_Pete's Electric Blue & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Aug 2nd, 2005, 12:29 PM   #9 (permalink)
obehave
Mini Mod
obehave's Avatar
Local Time: 06:37 PM
Quote: Originally Posted by robbo mcs
Hi,
"Just 2 seconds"
Robbo
Yep.
2 seconds is huge
Old Aug 2nd, 2005, 08:58 PM   #10 (permalink)
BFG9000
Quote: Originally Posted by obehave
Yep.
2 seconds is huge
My point was that there is no way a "lightweight" MCS is going to weigh 1100lbs less, otherwise it would resemble the extreme Sentra above . Perhaps it will be ~200lbs less, and as Charger_Pete pointed out, you can expect about 0.3 sec from that. Not so huge.
Old Aug 2nd, 2005, 11:50 PM   #11 (permalink)
obehave
Mini Mod
obehave's Avatar
You're probably right.
I was agreeing with robbo that the statement "dropped 1/4 mile by just 2 seconds" is a bit of an understatement.
And charger_pete stated .3 sec 0-60. So that would be maybe .4 sec or a bit more in the 1/4.
I can assure you that losing by 4/10ths in the 1/4 is a mild spanking. Been there had that done to me.
Old Aug 3rd, 2005, 12:44 AM   #12 (permalink)
crazyaboutmini
Motorer
crazyaboutmini's Avatar
Send a message via AIM to crazyaboutmini
BayBridgeMotors has an enduro MCS thats around 1700 pounds... based on what they said at MMW they are pushing 250hp now.... thats a very good power to weight ratio
http://honda-tech.com/zerothread?id=1056610&page=1
i dunno if that linked worked but you can see it at baybridgemotors.com
United States Male View crazyaboutmini's Dark Silver & Black 1st Gen MINI Cooper S Profile   Reply With Quote
Old Aug 3rd, 2005, 09:54 PM   #13 (permalink)
BFG9000
The Sentra showed a much larger drop in 0-60 than the 1/4, so we'd expect the difference in the 1/4 to be less, not more. Traditionally in drag racing (at least with heavier cars), 100 lbs is only considered to be worth ~0.1 sec in the 1/4, so the Sentra's performance was actually already better than expected.
Any car that BMW is going to sell to the general public will not resemble a race car. But I expect that the weight loss will greatly improve handling even though it will not nearly be down to the same weight as the Elise, CRX or 1st gen Miata. Perhaps ~2400lb like the base MC,1st gen Integra,or 1st gen MR2.
The weight of my loaded MCS (~2720lb) borders on the obscene because it is 1000lbs more than the similarly sized Festiva/Mazda 121. 1984 Chrysler Minivans and Jeep Cherokees only weighed ~2900lbs just like the C2 Cabriolet! To 05MCSConvertible, my MCS (and probably your new Mini too) weighs more than your C2 after the mods!
Old Aug 3rd, 2005, 11:02 PM   #14 (permalink)
obehave
Mini Mod
obehave's Avatar
Did a bad conversion. He said per 100Kg I was thiinking pounds. Ooops.
But yeah, I'm well aware of the 100lbs = .1 sec rule of thumb.
I used to drag race some as a kid. That's why I know if you lose by 2/10ths you're looking at the back of the other guys head. As short as the MINI is you might just be looking at the back of the other car
I'd like a lightweight version.
But NOT if they're going to bill us $1K or more like the MC40. Not for a 200 pound weight loss.
I agree with you it'll probably be as much ornament as it will be function.
Old Aug 4th, 2005, 07:01 PM   #15 (permalink)
rica_roel
Local Time: 05:37 PM
Send a message via MSN to rica_roel Send a message via Yahoo to rica_roel
My MINI S 2003 with some modifications, feels much more faster when I have half a gas tank than full.
Ricardo
Mexico   Reply With Quote
Old Aug 4th, 2005, 09:15 PM   #16 (permalink)
05MCSConvertible
I know guys that like to keep there tanks at 1/4 full because they also swear it makes a difference, although I think that is a bit extreme! But I guess if you are going for EVERY ounce of performance.
Old Aug 5th, 2005, 12:24 AM   #17 (permalink)
obehave
Mini Mod
obehave's Avatar
At 6.2 lbs per gallon every bit helps.
I hate it when I forget and fill my tank the weekend of an auto-x event.
Old Aug 6th, 2005, 08:23 PM   #18 (permalink)
05MCSConvertible
The words of a true autocrosser! LOL
Old Aug 8th, 2005, 09:04 PM   #19 (permalink)
05MCSConvertible
Do you think this figure would be the same if you remove 100kg of weight off of the general vehicle or if you removed 100kg of UNSPRUNG weight by means of lighter rims,tires, breaks and suspension components.
I remember reading something on either this board or NAM that stated removing unsprung weight is SIGNIFICANTLY better than...... lighter seats, no heater or AC or sound deadening. This was because of the less amount of rotating mass.
Old Aug 9th, 2005, 04:42 AM   #20 (permalink)
robbo mcs
Track Addict
robbo mcs's Avatar
Hi,
There was a long thread on about the physics of this (I think it was on NAM??).
As a rough rule of thumb losing 1kg of unsprung weight is roughly equivalent to losing somewhere between 2-4kg of sprung weight in terms of improved performance.
Robbo
Reduce Unsprung weight = Increased Horsepower? lwlam Engine & Drivetrain Tuning 9 Jan 24th, 2005 09:34 PM
just got s...... PICS NOW INCLUDED Phrozen MINI Cooper S 24 Jan 24th, 2005 12:15 PM
I Got Her Yesterday :D :) :D PICS NOW INCLUDED Phrozen General Discussion 15 Jan 22nd, 2004 01:25 PM
Horsepower measurement: BHP versus PS MINIAC Engine & Drivetrain Tuning 13 Jan 24th, 2002 10:53 AM
