| fr34king n00b! | Oil catch can Any of u folks bothered with this in australia? how much did it cost u to get one? link pls? -pete |
| my second passion, a tin! Join Date: Nov 2003 Location: Cronulla, NSW Local Time: 05:55 AM
Offline | I wouldnt worry about it. One of the more useless add-ons in opinion 2002 BRG MCS with more mods than can remember The thieves choice in race cars ![]() 2005 BEP MCS stock standard and staying that way |
| | #7 (permalink) |
Offline | No but fellow MINI owners have and after looking at their results and lengthy discussion with my mechanic on what it is supposed to achieve and what the problem it is trying to solve, it wasnt really worth worrying about. The catch can is just attempting to deal with oil 'blow-over'. This can only be an issue if you are overfull or have really pushed the car hard and some of the synthetic oils can foam up a bit due to the detergents in them. We solved that by using Mobil 1 Racing 4T which is bascially the same as the normal Mobil 1 oil but designed for motorbikes. No detergents due to wet clutches. Setup properly catch cans can do something, but there are plenty of other issues and things to spend your money on first! Stu 2002 BRG MCS with more mods than can remember The thieves choice in race cars ![]() 2005 BEP MCS stock standard and staying that way |
| | #11 (permalink) |
| The Mini Family Sponsers Join Date: Aug 2001 Location: Harlow Local Time: 08:55 PM
Offline | Something to do with a loss of crankcase vacuum preesure usually caused by the way the pipework hase been re-routed, a small leek would not make hardly any difference to a standard car but to a tuned car as you increase boost so the vacuum leek increases, now add around 100bhp to these cars and you could end up with a high vacuum problem like I did, so the Alta OCC had to come off..Other tuners have had this same problem and have held there sale of OCC's back and only recently a few have put them on the market. I will see if I can get a more technical explanation... |
| | #12 (permalink) |
| Mini Mod Join Date: Sep 2002 Local Time: 03:55 PM
Offline | Crankcase pressure should always be positive. Test. Remove you oil filler cap while the car is running. You can feel the air blowing out of the crankcase. ( Hold a rag over the opening as it could be a bit messy) A PCV valve opens under vacuum, generally supplied by intake manifold vacuum. Some of the installations I've seen add several feet of hose and the volume of the can to the line involved in this. A small leak, too large a diameter hose or hose with too weak a wall can all cause a drop in effective vacuum at the PCV valve.. Boost in and of itself cannot cause a vacuum leak but an engine in a higher state of tune may deal with a vacuum leak less well than a stock motor..Very high performance motors usually pull less vacuum at idle due to valve overlap and so are more sensitive to any loss. In short, don't make the runs too long and don't allow any leaks. I do fail to see how you could have a high vacuum problem. I have actually never heard of that. |
| Oil Catch Can | MNIMGK | Engine & Drivetrain Tuning | 10 | Oct 13th, 2006 06:37 AM |
| Oil catch can HELP!!! | JohnCopS | Engine & Drivetrain Tuning | 8 | Aug 4th, 2006 07:15 AM |
| Oil Catch | MiniBimmer | Engine & Drivetrain Tuning | 12 | Jul 24th, 2006 11:04 PM |
| fitted my oil catch can | M444SSY | Engine & Drivetrain Tuning | 7 | Oct 6th, 2005 02:52 PM |
| please some 1 help alta oil catch can | M444SSY | Engine & Drivetrain Tuning | 2 | Sep 25th, 2005 09:35 AM |
