Wipac
Old Aug 30th, 2005, 09:43 AM   #1
venox22
only the brave!
venox22's Avatar
Local Time: 03:34 AM
Send a message via AIM to venox22 Send a message via MSN to venox22
Catback Question
Right then im probably in for a telling off here!
When ppl refer to a 'catback' exhaust what does this mean?
Have a MCS and thinking of getting the JCW exhaust from John Cooper(i know i cant get from BMW), but which one of the below is the one that is supplied on a JCW MCS, basically i wnt the same exhaust set-up as a JCW MCS.
Also, exhuast being the same as a JCW apart from a chrome bit on the end, would this cause any warranty problems? in theory you wouldnt think so, but would like some opinions
Thanks in advance
ID:	98942  Click image for larger version
United Kingdom Male View venox22's Indi Blue & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Aug 30th, 2005, 09:58 AM   #2 (permalink)
ButtonIt
The Disorganiser
ButtonIt's Avatar
Local Time: 02:34 AM
Send a message via MSN to ButtonIt
"Catback" basically means from the Catalytic Convertor backwards. So you're leaving the original manifold and Cat in place and just changing out the rear sections.
Companies like Miltek and Janspeed do full systems including Manifold, Sports Cat and rear sections. The JCW I believe is just a Cat-back. No doubt someone will correct me on this....
England Male View ButtonIt's Hyper Blue & Body Color 1st Gen MINI Cooper S Profile   Reply With Quote
Old Aug 30th, 2005, 09:58 AM   #3 (permalink)
ButtonIt
The Disorganiser
ButtonIt's Avatar
BTW I have the Miltek cat-back on my MCS and it's great
Old Aug 30th, 2005, 12:09 PM   #4 (permalink)
uncle albert
uncle albert's Avatar
I believe the difference between the two exhausts you show is that the one on the left has a resonator built in (which would go right after the cat) whereas the one on the right doesn't - this might be what is referred to as a straight-through exhaust (therefore, louder).
England Male View uncle albert's Hyper Blue & White 1st Gen MINI Cooper S Profile   Reply With Quote
rattle from catback Mini4000 Faults & Fixes 1 Oct 20th, 2006 04:31 PM
SKUNK2 CatBack tl915 Engine & Drivetrain Tuning 6 Nov 9th, 2004 05:03 PM
FS: Milltek Catback + Header element Canada 5 May 30th, 2004 07:27 AM
Borla street catback MiniCoopS Engine & Drivetrain Tuning 0 Nov 21st, 2003 01:57 AM
