Visit Out Motoring!
Old Oct 27th, 2005, 12:57 PM   #1
Chilipeppa03
Cp Kartin
Local Time: 05:50 PM
Wobbly MINI at high speeds (help is wanted)
Hi guys, I have a 2003 Mini Cooper with 48,000 on her. WOW!! Anyway the problem that I am having is sometimes the car fills a little jiggly and wobby at high speeds on the interstate. Its like the wheel is not moving, but more from the motions of the car. Also it seems to do it worse on certain road surfaces. The car was lowered on Alta springs in April 2005, new falken 512 and rota wheels (all good tire pressure), new strutmounts, and 4 wheel alignment done. With all the powersteering issues going on, I was wordering if that is the problem. I don't know!
Help is wanted!!
Old Oct 28th, 2005, 04:12 PM   #2 (permalink)
Chilipeppa03
Cp Kartin
Can someone please help me
Post has been up for like 2 days!!
Old Oct 28th, 2005, 10:28 PM   #3 (permalink)
bimini
bimini's Avatar
Local Time: 11:50 PM
have you checked the suspension and steering for excessive play?
United Kingdom View bimini's Solid Black & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Oct 28th, 2005, 11:41 PM   #4 (permalink)
faster,Tobias!
Fanatically Enthiusiastic
faster,Tobias!'s Avatar
Local Time: 04:50 PM
Or your wheels may need balancing. Those little bits of lead they attach to the inside of the rim do on occasion fall off, and an unbalanced wheel is not readily noticeable until you are moving at speed and the inbalance becomes accentuated by the number of rotations the wheel is making. Do you notice anything at low speed?
Old Oct 29th, 2005, 12:06 AM   #5 (permalink)
xtremepsionic
Vroom!
xtremepsionic's Avatar
Yep, check balance on wheels, do an alignment if it hasn't been done for over 12 months, check tire pressure, check the tires to see if there are any damage.
If that doesn't work out, have a mechanic check the suspension/drivetrian components for damage.
Canada Male View xtremepsionic's Chili Red & White 1st Gen MINI Cooper Profile   Reply With Quote
Old Oct 29th, 2005, 04:03 AM   #6 (permalink)
pocketrocketowner
Best Personal Regards
Help is wanted!!
You describe a car that has had all suspension checked and has good tires on it as well as proper wheel alignment. I would suggest that a) your lowering it has changed the suspension geometry so that it feels unstable to due increase ride harshness on certain road surfaces, b) Highways do wear out and (particularly heavy truck routes) can get so damaged they are evil to drive on, c) Your mechanic left a few parts loose when changing strut mounts (whatever those are)
Hope this helps
United States Male View pocketrocketowner's British Racing Green & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Oct 29th, 2005, 08:57 AM   #7 (permalink)
DIOJCW
JCW ON SONG
DIOJCW's Avatar
Local Time: 10:50 PM
Send a message via ICQ to DIOJCW
another thing it might be by what you are describing
having lowered the car and if you have put on wider wheels/tyres
it is possible the car could also be tramlining following any bumps and ruts in the road
if that is whats causing it there is nothing you can really do unless you change things back to normal
also having lowered it have you got shorter shocks/struts front and rear to suit the lowering as that could cause a problem aswell.
id love to help personally but being in oz its a bit hard to
hope you get it all sorted
Australia Male View DIOJCW's Electric Blue & Black 1st Gen MINI Cooper S Profile   Reply With Quote
Old Oct 31st, 2005, 02:37 PM   #8 (permalink)
Chilipeppa03
Cp Kartin
Thanks you guys, I really like all the help you have given me. Im thinking it has something to do with the tires. I checked the inside of all the wheels and none of the weights had fallen off. I don't hear any strange wobbly noisies or anything. Could it also be my shock i guess. These are my original shocks too.
High Pressure Fuel Pump Leak, Advice Wanted R.B. 2nd Gen Faults & Fixes 8 Aug 22nd, 2007 12:49 PM
Wobbly gearstick phil_wkl Faults & Fixes 3 Mar 1st, 2006 01:06 PM
High pitched electronic hum at high speeds fms Faults & Fixes 13 Dec 26th, 2005 03:57 PM
WANTED! White / Clear High Level Brake Light matt1584 Exterior 17 May 9th, 2005 07:07 PM
mach 3 speeds in a mini! amzchhabra General Discussion 3 Mar 23rd, 2005 04:59 PM
