Mini Pirate
Old Jul 11th, 2002, 12:13 AM   #1
batman
Local Time: 05:24 PM
Unhappy How to remove the rear plastic trim ?
Does anyone know how to remove the rear plastic trim that has the side-marker ? I accidentally damage the trim and need to replace it. It is very cheap, but I am not sure how to remove it. It looks like I have remove my rear tire first. The rear side-markers are only on US models (I think). Do I have to remove the side-marker before I can remove the plastic trim ? Anyone know ? Thanks for the help !
Silver/Black Mini Cooper
5-Speed, Sports Pkg, Chrome bumpers, Leather Steering Wheel, Black Leatherette
Old Jul 11th, 2002, 06:08 PM   #2 (permalink)
Johnboy
Local Time: 01:24 AM
You got a picture of that?
If you're talking about the wheel-arch extenders, space-cadet posted an excellent response to my RFI on that exact subject...
If the side markers are simply built in to the wheel-arch extenders, then you could follow the info in that post.
If it's totally different - apologies
If you can't find the post, let me know and i'll tell you how it's done!
(Basically, with the removal of a couple of screws, everything can be pulled off!).
John.
Old Jul 12th, 2002, 02:20 AM   #3 (permalink)
batman
Lightbulb I found the post !
Thank you for the reply. I found the post. I think we are talking about the same pieces. I actually only need to replace the corner piece. Do I have to remove the wheel arch before I remove the corner piece ? In US model, there is also a side-marker clip onto the corner piece, but I already order a new one, so I dont have to worry about taking the old side-marker and putting on to the new piece (It is very cheap no need to waste time to take it out and put it back. I probably will damage it the the process anyway). Big question: did you guys remove your tire before you undo the screw at the top of the corner piece ?
Thanks !
Rear quarter window plastic trim Matt LHA Faults & Fixes 1 Jun 27th, 2006 01:08 AM
Scratches to interior plastic trim/how to remove ? johnlondonw3 Maintenance & MINI Care 16 Aug 22nd, 2005 01:42 PM
Plastic trim between doors and rear window bradley_m Faults & Fixes 1 Aug 6th, 2004 10:15 AM
How do you remove the plastic dashboard? Gar Faults & Fixes 22 Sep 5th, 2003 08:11 PM
Help ! How do you remove the rear plastic trims/fenders batman Exterior 0 Jul 10th, 2002 11:17 PM
