Visit Lohen!
Old Mar 13th, 2006, 03:23 PM   #1
nigelmercier
Gimmie an "S"
nigelmercier's Avatar
Local Time: 03:37 AM
Remove rear (tail) light cluster?
I want to remove a rear (tail) light cluster - I've got condensation in there, must be a leak. All the FAQs say is "remove taillight" but it doesn't say how.
Any tips?
Nigel
Old Mar 13th, 2006, 04:16 PM   #2 (permalink)
Paul
Trained Monkey
Paul's Avatar
There's a 10mm nut that you need to remove, and then it's a case of pressing it out, you may need to push in tabs that are also at the back of the lights, but sometimes these can be overcome just by pushing/pulling the light unit.
Old Mar 13th, 2006, 04:46 PM   #3 (permalink)
Root Ginger
Amiga 500 to PS3 20 Years
Root Ginger's Avatar
Online
They can be extremely ackward to remove. Just depends on how well the lights are made. I swapped my clear lights from my Cooper Works to my Hartge S and they were a nightmare to remove the clear lights (actually it was a nightmare installing them). However the original lights on the S virtually fell out!
Hope you are lucky
It was acceptable in the 80's
Old Mar 13th, 2006, 06:08 PM   #4 (permalink)
nigelmercier
Gimmie an "S"
I can't even see the whole of the cluster, is there something to remove first?
Nigel
Old Mar 13th, 2006, 06:27 PM   #5 (permalink)
Rakey
I am not a number!!
Rakey's Avatar
inside the boot of the MINI there is a hatch in the trim on either side, you open this and then gain access to the light cluster.
This is held in place by a nut which is a right pain to get to and it may take some time and a bit of patience to undo it. Make sure you swear lot at you remove the skin from your knuckles, and when you finally have the nut off swear again as you probably drop it into the body shell of the MINI
Just take your time, be careful, and when tightening them back up don't over tighten as the bolt you thread the nut onto can snap off and this means a complete new unit
I didn't mean it
Tail light cluster loop jcsinnh Exterior 10 Jul 19th, 2005 08:27 PM
Rear light cluster problem. RICO UK Faults & Fixes 1 Sep 19th, 2004 05:42 PM
Bulb Replacement (brake lights in white tail light cluster) snarl General Discussion 3 Dec 26th, 2003 03:05 PM
Rear Light Projector Cluster ScottishMini Exterior 0 Apr 7th, 2003 03:16 AM
Another Prob ! - Condensation in Rear Light Cluster Paul Billington Faults & Fixes 9 Jan 12th, 2003 07:38 PM
