Visit Derek Woodman MINI
Old Mar 23rd, 2006, 02:09 AM   #1
SPClark
Local Time: 04:32 PM
Yellow Cooper Steering Pump WON'T SHUT OFF?
102,600+ miles on my early '03 S.
Original steering pump replaced at 64K miles, 18 months back.
This morning, steering pump quit after an hour's normal commute. Later today I had some errands to run, pump was working again.
Got home (44 mile drive), shut off the ignition, STEERING PUMP STILL RUNNING.
Checked under hood fusebox, pulled every relay & fuse but pump runs on.
Pull cover off inside fusebox, pull every fuse & relay, pump still runs.
Got desperate (I have an appointment at the dealer in the morning - called earlier thinking pump was going bad) so pulled a wrench out & disconnected (-) terminal of battery from ground strap.
Pump stops.
QUESTION: In the morning, if I reconnect the (-) strap to the battery, will my MINI start & run or will the software be wiped by then?
Old Mar 25th, 2006, 12:14 AM   #2 (permalink)
stevesace
mini tech
Local Time: 09:32 PM
Send a message via MSN to stevesace
it will run fine no matter how long its been disconnected. the pump sounds like it has failled again, it may require the pump harness aswell, as the connector can corrode quite badly from water ingress.
England   Reply With Quote
Old Mar 25th, 2006, 09:32 PM   #3 (permalink)
SPClark
Thanks!
Nice to know there are techs watching here ....
Yes, dealer replaced pump, again & as it was less than two years since it went the first time the new one was free.
Thanks for the tip on the harness as well. As I don't do my own mechanics-work, I can only hope either BMW engineered a rubber boot-protected connection there, or that the dealer wrench's have figured out a bit of silicone sealer at the interface does a world of good keeping the connection alive.
We're in a Midwest U.S. climate and the pols like to heap TONS of salt on the roads when there's even a hint of snow or ice forming, so stuff like this can be worrisome.
Old May 5th, 2006, 10:56 PM   #4 (permalink)
marcelogarcia
Local Time: 03:32 PM
Same problem
I had the same problem this morning, did exactly the same things (fuses, etc) had to disconect terminal. Was your problem fixed, I´m worried because any tech evan at BMW may asure me that the PS pump is failing, they say it´s is probably the problem but not 100% sure. Could it be something electrical? or the fan? becuase it only fails when weather is hot.
Mexico   Reply With Quote
Old May 7th, 2006, 04:47 AM   #5 (permalink)
SalemMINIDriver
SalemMINIDriver's Avatar
Local Time: 05:32 PM
You probably saved your car by disconnecting the battery. My '04 MCS caught fire two weeks ago when the ABS/DSC actuator continued running following a short drive. I would assume that a similar failure of any electrohydraulic component would result in the same outcome. If yours got to a point where white smoke was beginning to appear, then you were VERY close to seeing flames.
United States Male View SalemMINIDriver's Pepper White & Black 1st Gen MINI Cooper S Profile   Reply With Quote
Old May 7th, 2006, 07:00 PM   #6 (permalink)
MiniService
Its a common problem, they just run until they kill the battery
Old May 8th, 2006, 03:14 PM   #7 (permalink)
SPClark
Quote: Originally Posted by marcelogarcia
Was your problem fixed? <snip> Could it be something electrical? or the fan? becuase it only fails when weather is hot.
Yes, it's electrical at root; the pump relay(s) I think are inside the pump housing somehow and end up failing the older they are and the warmer the conditions under which any given MINI is living. In your case I'd say replace the pump as the relay, once it begins to show signs of failure, won't last long.
I've had my '03 S now for 3-1/2 years, racked up over US 106,000 miles - so far - and have had the pump fail twice in the exact same manner. The first time I was still under the 50K warranty limit, the second time it was replaced no charge as the 1st replacement (not a MINI factory part) was warranteed by the dealer for 2 years.
Power Steering Pump stargate Faults & Fixes 6 Jul 17th, 2008 06:22 PM
Power steering Pump replaced-Steering slightly off centre Rooster Faults & Fixes 2 Sep 3rd, 2007 06:12 PM
Signal into Steering pump? Spipp Faults & Fixes 1 Sep 15th, 2006 02:18 PM
Steering Pump frails Faults & Fixes 5 Jan 23rd, 2004 07:44 PM
Steering Pump Paul Simonds Faults & Fixes 9 Apr 6th, 2002 12:22 AM
