Old Apr 6th, 2006, 04:28 PM   #1
mini_macky
JL Mini Boombox
mini_macky's Avatar
Local Time: 03:21 PM
Send a message via Yahoo to mini_macky
driver's door doesn't unlock...
...using the key remote and when i press the lock-doors switch on the console, the driver's door doesn't lock/unlock.
i have to use they key in the keyhole to open the driver's door from the outside, but it locks just fine when i press the lock key on the remote.
any ideas?
Philippines   Reply With Quote
Old Apr 6th, 2006, 04:52 PM   #2 (permalink)
Paul
Trained Monkey
Paul's Avatar
Local Time: 08:21 AM
Online
I was going to suggest that selective central locking has been activated (which means one click for the drivers door, two for the passenger), but that doesn't apply to the interior switch. I would suggest a trip to the dealers if there's no easy fix posted here.
Old Apr 7th, 2006, 04:35 AM   #3 (permalink)
mini_macky
JL Mini Boombox
mini_macky's Avatar
i would...but there's no dealer here in the philippines hehehe!
what do you mean with "selective central locking has been activated" ? because before both doors unlock with a single click on the remote
Old Apr 7th, 2006, 06:31 AM   #4 (permalink)
Rakey
Four Candles?
Rakey's Avatar
has it always been like this or has this just happened?
Old Apr 8th, 2006, 01:33 PM   #5 (permalink)
Capsaisin
cave capsicum
Capsaisin's Avatar
Question
As you have no dealer, all I can suggest is that you disconnect the car battery, leave it for half an hour, reconnect the battery and hope the circuit resets itself!
United Kingdom Male View Capsaisin's Chili Red & Black 1st Gen MINI Cooper S Profile   Reply With Quote
Old Apr 21st, 2007, 03:13 AM   #6 (permalink)
roni
Local Time: 03:21 AM
macky your problem maybe the driver side door lock
Old Jul 3rd, 2007, 01:35 PM   #7 (permalink)
andre_le_roux@bat.co
Local Time: 09:21 AM
Hi
On my Cooper the left door unlocked fine but would not lock electrically. The problem was that the unlock motor was fouled with a glue like substance, that fouled the motor armature.
I removed the door lock mechanism from the door.
I then opened the unit by grinding away one rivet head.
Made about 12 plates cut to the size 6mm x 25mm (plate thickness about 0.2mm).
I pushed the plates under the plastic retaining clips that keep the unit sides together.
This prevents the clips from breaking during the opening action.
Then I took the motors apart by preying open the motor retaining clips.
Cleaned out the motors and re-assemble the mechanism.
The rivet was replaced with a screw and locknut of appropriate size.
South Africa   Reply With Quote
Drivers door central locking - won't unlock - will lock quigger Faults & Fixes 4 Oct 10th, 2007 05:43 AM
Driver's side door won't lock/unlock properly MightyBoognish Faults & Fixes 1 Sep 20th, 2007 03:41 PM
Question on Auto door unlock with ignition off RedMCS Faults & Fixes 4 Oct 14th, 2005 02:26 AM
Door Unlock issues Kiwiracer Faults & Fixes 3 Nov 10th, 2003 11:14 AM
Door won't unlock from the inside nullspace Faults & Fixes 7 Nov 11th, 2002 01:45 PM
