Think Mini
Old Apr 18th, 2006, 10:27 AM   #1
bards
Clio 197 R27
bards's Avatar
Local Time: 10:32 PM
Send a message via MSN to bards
Windscreen Washer Failure
Filled my washers on friday, then went to use them and they didnt work :O has anyone else had a problem with them? My first thoughts are that the bottle has a leak, as the pump still works when i go to press the washers.
Nick
Old Apr 18th, 2006, 12:58 PM   #2 (permalink)
frylock
frylock's Avatar
Local Time: 03:32 PM
I think the filler neck runs down the fender into a bag. While I've never had a problem with my MINI's bag, I've had some leaks in other cars--the bags are pretty delicate. It would have to be a pretty severe leak to break the washers, though. A couple of things to consider--just because you hear the pump doesn't mean it's not broken. It does mean that all the electrics are probably ok. Also, make sure the jets aren't somehow clogged.
None of this info really comes from specific experience with MINI's. I might be completely wrong about this bag business.
Old Apr 18th, 2006, 03:48 PM   #3 (permalink)
Gillian Hogarth
Local Time: 09:32 PM
I know this may sound stupid, but have you checked to see that there isnt a kink in any of the pipes that feed the water to the washers. Thats what was wrong with mine when they didnt work.
United Kingdom Female View Gillian Hogarth's Electric Blue & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Apr 18th, 2006, 04:30 PM   #4 (permalink)
Root Ginger
Amiga 500 to PS3 20 Years
Root Ginger's Avatar
If the motor is whirring and sounds like normal, chances are that's ok. Could be blocked, try front and rear washers and post what happens. Check hoses as already suggested.
It was acceptable in the 80's
Parklane Windscreen washer problem MiniMusey Faults & Fixes 3 Jul 1st, 2006 02:21 PM
Windscreen washer fluid in wrong place benjacobs25 Faults & Fixes 25 Dec 27th, 2005 04:09 PM
Washer Jets Failure!! Mr P Faults & Fixes 18 Nov 9th, 2005 07:38 AM
Windscreen Washer fluid level warning light Daniel Interior & Ice 21 May 31st, 2003 04:23 AM
Larger Windscreen Washer Fluid Reservoir??? GMINI Faults & Fixes 2 Jan 31st, 2003 08:37 PM
