Wipac
Old Apr 21st, 2006, 04:14 PM   #1
Capsaisin
cave capsicum
Capsaisin's Avatar
Local Time: 12:07 AM
Official BMW warranty issues
If you have a fault with your Mini and you think you are getting the run around from your dealer, try taking a look here:
http://www.alldata.com/tsb/BMW/index-issue.html
You might find your fault is actually well known to BMW!
ps Mini bulletins start with an M before the number.
NEW EDIT
I found the root directory with a lot more TSBs take a look at;
http://web.archive.org/web/200410251...dex-issue.html
http://web.archive.org/web/200502092...dex-issue.html
As before, the Mini TSBs have to be sorted out from the other BMW.
I will also paste in a direct link further down the page.
United Kingdom Male View Capsaisin's Chili Red & Black 1st Gen MINI Cooper S Profile   Reply With Quote
Old Apr 21st, 2006, 04:35 PM   #2 (permalink)
JDinho
JCWaiting!
JDinho's Avatar
A list of all the faults listed prefixed with M (for Mini):
M840403
Navigation System - Software Updating
M710105
Recall - Tire Information Label Non-Compliance
M640104
Air Conditioning - Whistling Noise From Dash Above 50 MPH
M620105
Instruments - Clock is Inaccurate
M610302
Electrical - Correct Battery Vent Tube Routing
M610105
Keyless Entry - Convenience Opening Feature Inoperative
M610102
Electrical - Battery Maintenance Requirement
M540705
Campaign - Convertible Top Wiring Harness Inspection
M540605
Campaign - Convertible Top Adjustment
M540105
Body - White Marks on Convertible Top
M510705
Body - Door and or Window Squeaks and or Rattles
M510506
Body - Cannot Open Door From Inside
M510206
Audio System - Door Speaker Rattles
M320405
Steering - Steering Gear Replacement After A Collision
M240105
Auto Trans - Failsafe Mode and or DTC P0571 Set
M230106
Manual Trans - Limited Slip Differential Noise
M230105
Manual Trans - Getrag 5 Speed, Rattling Noise at Idle
M210205
Manual Trans - Clutch Bleeding Requirements
M120805
Engine Controls - Various Driveability Concerns
M120505
Electrical - Numerous System Complaints
M120205
Engine Controls - MIL ON and or FC 0136 (O2 Sensor) Set
M120106
Engine Controls - MIL ON and or DME Fault Code 2096 Set
M110106
Engine - Oil Seepage From Filter Housing Area
M090102
Computers and or Controls - Feature Customization
M040206
Auto Trans - Gear Position Switch Adjustment Gauge
JD
United Kingdom View JDinho's Hyper Blue & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Apr 21st, 2006, 04:52 PM   #3 (permalink)
Capsaisin
cave capsicum
Capsaisin's Avatar
Phew, I was too lazy to do that What a long list, and they're only recent. I think you have to subscribe to get the full list back to 2002.
Old Apr 21st, 2006, 06:40 PM   #4 (permalink)
JDinho
JCWaiting!
JDinho's Avatar
no bother really... copy the page into exel- it sorts the columns out, the sort the data and copy into this dialogue box
Old Apr 21st, 2006, 09:10 PM   #5 (permalink)
awj
Capsaisin, you are a GENIUS!!!
When I took my mini convertible for its 30k mile service to Stratstone Derby, I mentioned a gearbox noise at idle which disappears when you press the clutch. I got no response whatsoever, and now following your link, it seems it is a known fault and the dealer should replace the clutch if a customer complains!
Suffice to say, I will be making a visit tomorrow morning and complaining...
Thanks again!
United Kingdom View awj's Solid Black & Black 1st Gen MINI One Convertible Profile   Reply With Quote
Old Apr 21st, 2006, 09:37 PM   #6 (permalink)
Capsaisin
cave capsicum
Capsaisin's Avatar
I also found this which is quite interesting and covers many of the faults I have seen discussed on mini2
http://motoringfile.com/2006/03/02/a...visor-answers/
Hope it helps someone to combat the dastardly dealers.
Old Apr 22nd, 2006, 11:17 AM   #7 (permalink)
Capsaisin
cave capsicum
Capsaisin's Avatar
Tsb Update
Just found this which seems to be the archive for all the BMW TSBs. Seems to cover quite a lot!!!!!!!!!!!
As the previous link, the Mini TSBs have to be sorted out from all the others.
Hi, JDinho, can you do anything with this? A list like the last one would be a great help I think.
Old Apr 23rd, 2006, 11:05 PM   #8 (permalink)
Carlos.
Merry Prankster
Carlos.'s Avatar
Send a message via AIM to Carlos. Send a message via MSN to Carlos.
nice work
I'd rather be a lightning rod than a seismograph
Ken Kesey 1935-2001
United Kingdom Male View Carlos.'s Solid Black & White 1st Gen MINI Cooper Profile   Reply With Quote
Old Apr 25th, 2006, 09:54 AM   #9 (permalink)
:: Jon ::
:: Jon ::'s Avatar
what a find... so much info...
EMPTY SPACE NEEDS FILLING....
but it has to be something that wont get me banned
Old Apr 25th, 2006, 10:05 AM   #10 (permalink)
:: Jon ::
:: Jon ::'s Avatar
love this one...
from this site click here
the acoustic feedback is a standard feature of the 2005 model year cooper S vehicle produced as of 7/2004. this feature cannot be retrofitted to the previous model year vehicles.
How do you retrofit a pop pop pop.....
Old Apr 25th, 2006, 11:07 AM   #11 (permalink)
JDinho
JCWaiting!
JDinho's Avatar
M000202 Maintenance - Operating Fluids
M040104 Body - Sunroof Cassette Tool and or Service Procedure
M090102 Accessories and or Computers - Customizing Memory Feature
M110104 Recall - Crankcase Breather Line Replacement
M1120004 Emissions - Moaning and or Groaning Engine Compartment Noise
M1120104 Engine - Rough Idle and or MIL ON and or DTC P1498 Set
M120104 Recall - DME Reprogramming for EVAP Leak Diagnostics
M120204 Emissions - OBDII Readiness Code Prior to Inspection
M1220004 Engine - Lack of Power and or SES Lamp ON and or DTC P1688
M1820004 Exhaust System - Popping Noise
M230104 Campaign - Manual Trans Fluid Level
M2320004 Manual Trans - New Type of Oil
M240104 Auto Trans - CVT Radial Seal (Input Shaft Seal) Replacement
M250104 Manual Trans - Shift Cable Rattling Noise
M250204 Campaign - Monte Carlo Shift Knob Missing
M252004 Transmission - Shift Cable Freezing
M320104 Steering - Power Steering Pump Cooling Fan Inoperative
M3220004 Steering - Knocking Noise From Power Steering Pump Bracket
M360204 Recall - Tire Monitor System Defect
M360304 Campaign - Owners Manual Correction and or Tire Monitor
M410102 Body - Rear Hatch Rattling
M510204 Body - Outside Door Handles Inoperative and or Frozen
M5120004 Interior - Glove Door Won't Latch and or Pops Open
M5120104 Interior - Glove Box Door Won't Open
M5120204 Body - 'A'-Pillar Trim Comes Off at Highway Speeds
M540304 Campaign - Convertible Top Warning Label
M610104 Interior - Seat Heater Hot and or Cold
M610302 Battery - Vent Tubing Routing Precaution
M6120204 Electrical - Air Conditioning Fan Speed Unstable and or Interior Light Inop.
M6120404 Keyless Entry - Remote Key Initialization
M6220101 Instruments - Instrument Intermittently Cluster Cuts-Out
M640204 Air Conditioning - Does Not Blow Cold Air
M6420204 Air Conditioning - IHKA Intermittently Inoperative
M6520004 Instruments - Board Monitor Display Start-Up Delay
M840403 Navigation - Software Update
M840403 Navigation System - Delayed Vehicle Position Locating
M8420004 Navigation System - Display Black in Extreme Cold
as requested
Old Apr 29th, 2008, 04:26 AM   #12 (permalink)
Motor On
Local Time: 07:07 PM
As the alldata links have gone dead, does anyone have a link or copy of the PDF of the "M510506-Body - Cannot Open Door From Inside" TSB?
BMW clarification on warranty after modification (Official) Jonesy Engine & Drivetrain Tuning 4 Oct 20th, 2005 08:38 PM
Bmw/minis' Official Stance On How Your Warranty Can Be Affected By Mods To Your Car. Spoony General Discussion 30 Apr 5th, 2005 04:21 PM
'Official' Word on 'un-official' Engine Mod's from BMW UK regarding Warranty Adventure_Man Engine & Drivetrain Tuning 5 Apr 8th, 2003 08:58 PM
Warranty Issues.... gorditoautoxr Engine & Drivetrain Tuning 5 Dec 12th, 2002 08:07 PM
ICE Installation - Warranty issues GTT 280 Interior & Ice 5 Jan 17th, 2002 07:41 AM
