Mighty Stripes
Old Jul 8th, 2006, 01:16 AM   #1
Mr G
Its not me - Its you
Mr G's Avatar
Local Time: 08:49 AM
Australia Vibration
EDIT: this is fixed now. see below
my car has develoled a vibration which is apparrent at speeds over 60kmh, but most obvious over 80.
it is almost undetectable in 2nd gear, but shakes like a flaggon with a blowfly in it the minute you put it in 3rd. It only does it while accellerating. Coasting, cruising at constant speed or braking its fine.
I took it and had the wheels rotated and balanced this morning and it made no difference at all.
this started sudenly last weekend. one minute it was fine, the next it was doing this.
any thoughts?
I love Warsaw. Where else can you hug a pole?
If you have any information, any information at all, please contact me as I'm writing an encyclopaedia.
Australia   Reply With Quote
Old Jul 8th, 2006, 05:29 AM   #2 (permalink)
meinamini
Livin' the country life
meinamini's Avatar
Local Time: 09:49 AM
Send a message via MSN to meinamini
Oh no Mr G!
Sounds dodgy, hope you get it sorted.
Australia Male View meinamini's Dark Silver & Black 1st Gen MINI Cooper S Convertible Profile   Reply With Quote
Old Jul 9th, 2006, 12:50 AM   #3 (permalink)
herbie hind
Local Time: 06:49 PM
wouldn't hurt to check the torque on your engine mounts . it's a long shot but won't cost you .
Old Jul 15th, 2006, 01:37 AM   #4 (permalink)
Mr G
Mr G's Avatar
its going in today and they're keeping it for a week. I'm going to be in Melbourne so I figured the timign was nice. so i'll hopefully get an answer when i get back.
Old Jul 15th, 2006, 05:08 AM   #5 (permalink)
ScottyB
Take me down to Paradise
ScottyB's Avatar
Good luck with this Matt..
- Global Moderator - MY BLOG - Global Procrastinator -
... Buying the 8C for its dynamic abilities is like buying a porn film for its plot ...
Australia Visit my Blog at the Motorcade Male View ScottyB's Pure Silver & Black 1st Gen MINI Cooper S Profile View ScottyB's MINI Profile Images   Reply With Quote
Old Jul 21st, 2006, 11:03 AM   #6 (permalink)
Mr G
Mr G's Avatar
The dealer can't find the problem! they spent 5 hours looking for it, but don't know what's causing it. they think it must be an internal gearbox problem. they've logged the problem onto the bmw PUMA system. So if someone else finds the same fault and what's causing it, then they log it, and the knowledge flows through to mine. Fat lot of help that is though when i'm driving Fat-Blaster 2000 everyday.
The amount of problems this car has - if it wasn't so annoying it'd be downright commical.
Old Jul 21st, 2006, 11:09 AM   #7 (permalink)
St00ge
8/10 on the Stoogometer
St00ge's Avatar
Send a message via MSN to St00ge
i was about to say something with perhaps the clutch, pressure plate, flywheel. If it is occuring under load, that's all i can really think of. Hit the throttle in neutral, while moving at 60+, and see if it vibrates....
Black MCS Alta CAI, MTH, OBX + One-ball, Alta Diverter w/ Sprayer, Recalibrated BPV, Alta 17% Pulley, Denso IK22s, Goodyear Eagle F1 GSD3s 215/40/17, Whiteline 20mm Adjustable Rear Swaybar, Ferodo DS2500s, Motul RB600, TCE SS braided brake lines
Old Jul 21st, 2006, 11:21 AM   #8 (permalink)
Mr G
Mr G's Avatar
no it doesn't. it only does it underload. although its hard to tell, if i was pressed i'd say its a road speed vibration rather than an engine-revs vibration. . its hard to tell because it only does it while the clutch is engaged, and therefore engine and roadspeed increase at the same rate. So anything's possible, i guess.
Old Jul 21st, 2006, 11:58 AM   #9 (permalink)
Capsaisin
cave capsicum
Capsaisin's Avatar
Local Time: 11:49 PM
Sounds more like gearbox. Does it also vibrate under load in 4/5 and 6th gear?
Sounds like a gear shaft flexing under load. Vibration might depend on how close the engaged gear cog is to the end of the shaft.
United Kingdom Male View Capsaisin's Chili Red & Black 1st Gen MINI Cooper S Profile   Reply With Quote
Old Jul 21st, 2006, 04:47 PM   #10 (permalink)
St00ge
St00ge's Avatar
can you feel the vibration through the clutch pedal? This is a weird problem, and what's really weird is that BMW can't find the problem....hope they're not BSing you
Old Jul 21st, 2006, 10:01 PM   #11 (permalink)
Mr G
Mr G's Avatar
you're thinking along exactly the same lines as me. yes, its there in 4th, 5th and 6th. its evident in 2nd, but barely noticable. I tried it in 1st at 4k with the brake on to load it up, and nothing. so it seems to me its related to the speed of the output shaft
the other explination could be a crown wheel. or pinion maybe.
Old Jul 21st, 2006, 10:09 PM   #12 (permalink)
PmP
GP 0380
PmP's Avatar
Funny Im getting a similar vibration but under acceleration in 3rd and above at speeds above about 50mph. The door pockets seem to vibrate and a strong vibration can sometimes be felt through the steering wheel at times under acceleration. Ive had wheels balanced and still problem occurs. Ive got eibach coilovers on that my be a factor. Help us somebody!
Northern Ireland Male View PmP's Dark Silver & Black 1st Gen MINI Cooper S Profile   Reply With Quote
Old Jul 22nd, 2006, 02:38 AM   #13 (permalink)
St00ge
St00ge's Avatar
good luck fellas
Old Jul 22nd, 2006, 05:47 AM   #14 (permalink)
Mr G
Mr G's Avatar
yep that's it. Now there's two of us it's characteristic of the model I guess. I feel better now
Mine was fine one minute, and then all of a sudden - whooshka. (technical term) was yours the same?
Old Jul 29th, 2006, 08:38 PM   #15 (permalink)
teddie
Local Time: 10:49 PM
mini vibration when accelerating especially over 45 mph
I borrowed an 01 plate Cooper with 38 k on the clock last weekend and it had the same problem. No vibration at steady speed but on acceleration it had a terrible vibration coming from the front end but it did not seem like wheel balance. I thought it was likely to be a front suspension problem, worn bushes or movement in the front struts if they have them. That and the fact it was a Yellow one stopped me from buying it as a run around until the new model comes out.
Old Jul 31st, 2006, 09:39 PM   #16 (permalink)
caschumann
Local Time: 05:49 PM
Send a message via AIM to caschumann Send a message via Yahoo to caschumann
Similar Vibration Problem
I too have a vibration problem. Everything is smooth sailing until I get above 70 MPH. By about 80 MPH I at times get scared the thing is going to vibrate apart! It feels like I'm driving on an extremely bumpy road (which I'm not...) When I slow down to 70 MPH, it again is smooth driving.
I've got an appointment with the dealer next week to have a look - but, in researching this forum, it doesn't look promising. Any helpful hints would be great. MINI USA seems to like to follow their "protocols" for trouble shooting which often leaves you coming back in time after time to finally get the problems resolved - I recal 3 trips to finally get my Nav System screen replaced!
Old Jul 31st, 2006, 10:11 PM   #17 (permalink)
herbie hind
you've got a wheel balance or alignment problem dude .
Old Jul 31st, 2006, 10:14 PM   #18 (permalink)
herbie hind
make that three of us .mine comes and goes . i believe it's either the harmonic balance or engine damper or mounts or both . i will be checking the torque on these this weekend .
Old Aug 1st, 2006, 08:29 AM   #19 (permalink)
Mr G
Mr G's Avatar
but why only in higher gears?
Old Aug 1st, 2006, 10:28 PM   #20 (permalink)
herbie hind
higher gears make load more apparent . it's a good way to check a clutch too . just get in high gear and head up a gradual incline on the highway ...then nail it if the rpms run up and no movement it's the clutch time . so with load same thing. top gear roll ons are asking alot from the motor .especially up hill .the motor has to work hard so any vibes (like starting off in 2nd gear) will become apparent.
Steering vibration ???? mendel williams Faults & Fixes 2 Aug 22nd, 2006 04:55 PM
Vibration problem HObzy Faults & Fixes 20 May 3rd, 2006 09:32 PM
Vibration leon1982 Faults & Fixes 1 May 3rd, 2005 04:18 AM
wheel vibration webber Wheels, Tyres & Brakes 7 Mar 10th, 2005 04:35 PM
Vibration while accelerating Rwatts4mini Faults & Fixes 5 Aug 5th, 2003 03:56 PM
