| MINI2 Regular Join Date: May 2005 Local Time: 11:12 PM
Offline | Replacing reverse light, HELP It appears that I need to replace the reverse light on my 2002 Mini One. I bought the correct bulbs but the problem is, I can't find out how to remove the old bulb and fit the new one. I don't seem to be able to locate the back of the socket. Can anyone help? Cheers |
![]() cave capsicum Join Date: Mar 2006 Location: Crewe Local Time: 11:12 PM
Offline | Well in theory, if you feel behind the rear bumper you should feel the reversing light. You need to push in the retaining clips at either end of the light assembly and the whole assembly should then push out. The bulb can then be changed. ![]() |
| YipsAwaaay! Join Date: May 2006 Location: Manchester Local Time: 11:12 PM
Offline | yoni99 i had the same problem with my mini one (2002) and rang the dealer for help. I originally thought it may be just the bulb that needed changing - but couldnt find where to get to the bulbs also ... however after ringing the dealer i took mine in because they said the switch might have gone. After taking it in they had said it was the switch that was faulty and replaced it. Hopefully yours will be a straight swap .. capsaisin seems to have the right idea. |
| Previously Grizzly05 Join Date: Dec 2007 Location: Sittingbourne Local Time: 11:12 PM
Offline | I also have this problem, however i cannot access the bulb as i have a rather large plastic box/casing thing in the way and i was just wondering if anyone had the same problem?thanks |
| | #6 (permalink) |
| BLIKSEM (my brg/brg mc) Join Date: Mar 2003 Location: york, pennsylvania Local Time: 06:12 PM
Offline | This theory worked in practice for me. Takes a little effort but not too difficult. I put in a halogen 35W 796 ba15s bulb that's about twice as bright as the stock P21W bulb, but not powerful enough to melt the housing or wiring or BC1. You can't use these for the brake or fog or turn signal light, however, because they light up a little slower than a standard bulb |
| No Reverse Light?!?! | mini-coop | Faults & Fixes | 6 | Feb 19th, 2008 10:14 AM |
| Reverse light and brake light | Lorenzo7 | General Discussion | 0 | Sep 30th, 2007 06:08 PM |
| reverse light | SeXiTuPJoEy | Faults & Fixes | 0 | Sep 19th, 2005 06:56 PM |
| White stobe light where reverse light used to be? | CYNMINI | Exterior | 8 | Sep 28th, 2004 10:42 AM |
| Reverse light is not working.. | leon1982 | Faults & Fixes | 3 | Jun 18th, 2004 10:30 PM |
