| MINI2 Newbie Join Date: May 2005 Location: Cape Town Local Time: 04:50 AM
Offline | Another electrical problem I have a problem with my 2003 MINI Cooper, it is an electrical fault and although it has occurred many times in the past I’m now able to replicate it. The problem is and can be replicated as follows: Driving lights on Rear mist light on As the front spot lights are switched on the windscreen wipers activate Switching the spot lights off does not stop the wipers from working but only slows their movement. Even after I turn the ignition off and remove the key the wipers keep on going. Anyone experienced a similar problem? |
| MINI2 Regular Join Date: Mar 2006 Location: Scotland Local Time: 02:50 AM
Offline | My boot unlocks sometimes when I turn my headlights on and off. Its seems to do it after a heavy rainfall but never does it when I take it to the dealer to get checked. funny that. ![]() |
| Being normal is not fun! Join Date: Jul 2004 Location: Newcastle, Australia Local Time: 12:50 PM
Offline | Check under the carpet in the front seat.. you may find that you've got a rain channel blocked, and that water is getting in through the dash. If this is the case you might find your BCM is getting sorted in water! |
| MINI2 Newbie Join Date: Aug 2006 Local Time: 07:50 PM
Offline | Electrical Problems Check the fuses under the hood. Also look at the wires to see if any of them are burned. Our oil light suddenly came on Back on June 24th. The power steering suddenly went out, also. Then the car wouldn't start back up. We saw smoke, and had it towed in to a local repair shop. Found all of the wires burned, went up, and fried the computer. BMW has ordered the wrong replacement comuter. It is August 12th and I still don't have my car. This has been very expensive for a rental car and all the repairs. I recommend taking it in and fixing the problem before it causes greater damage. |
| | #7 (permalink) |
Offline | Fixed Will be collecting the car later today, apparently a wire going to the front spots was chaffing and caused a short (fire hazard, rather scary). anyway I'll check later. |
| strange electrical problem, HELP!! | venox22 | Faults & Fixes | 23 | Oct 31st, 2006 07:55 PM |
| Strange electrical problem??? | DropTopCoop | Faults & Fixes | 2 | Aug 8th, 2006 09:48 PM |
| Strange electrical problem | Geo99M6Z | Faults & Fixes | 4 | Jan 6th, 2006 12:32 PM |
