Performance Torque
Old Aug 12th, 2006, 04:59 PM   #1
alexandra57
Local Time: 12:56 AM
United-Kingdom odd vibration through 70mph
I have recently privately purchased a Dec '01 Mini Cooper with 35K on the clock. The car drives fine until I accelerate through 70mph when it developes a vibration which I feel through the steering. As soon as I get to 75mph +/-, the vibration disappears and I am able to continue to accerate to higher speeds with no problems at all. It doesn't matter what gear I'm in, the vibration comes each time, right on cue! I have taken my mini to BMW who have had a look and stated that the wheels aren't buckled but stated that it pulled quite badly to the left, and told me to book in for a KDS alignment at a different BMW garage. I booked it in and they took the car but then called me to say that KDS wasn't neccessary unless it had been in an accident which it hasn't. With no KDS done, they too had a look and told me that I had a slightly uneven worn tyre on the front near side which they switched to the back. They gave me the Mini back and were happy that they had solved the problem. On driving home - Lo and behold - the vibration was still there! I have today had my wheels balanced and aligned and the pull to the left has gone, but the vibration is still there but slightly less vigarous. I have also driven without the AC on and its still the same, sadly. PLEASE PLEASE can someone shed some light...........
England   Reply With Quote
Old Aug 12th, 2006, 05:15 PM   #2 (permalink)
Root Ginger
Amiga 500 to PS3 20 Years
Root Ginger's Avatar
It's there to let you know when you're about to break the speed limit.
It was acceptable in the 80's
Old Aug 12th, 2006, 05:52 PM   #3 (permalink)
SiBradbury
"I'm kind of a big deal"
SiBradbury's Avatar
99% of the time if the vibration occurs at a certain speed and you can speed up past the vibration, it's wheel balancing.
Swap your front wheels for your back ones and see if the vibration goes. If there's a slight balance problem on rear wheels it's much less noticable and sometimes disappears completely.
It's not uncommon for the wheel to be seated incorrectly on the balancing machine and the wheel to not balance properly. It happens occasionally.
Old Aug 13th, 2006, 08:58 AM   #4 (permalink)
tenderidol
tenderidol's Avatar
Local Time: 04:56 PM
Most likely it is a balancing issue, since it shows up at a certain speed... Sometimes it takes few tries to get it right. In case it may help you, I cut this out from another forum, where the original poster was suffering from vibration around 65 mph: "If you still have a vibration take your car to a shop with a Hunter 9000 machine. Have a road force balance done. Not just a balance. The only way I can get a smooth ride is with a road force balance. Well worth the money."
If your MINI has aftermarket wheels, then you'd need hubcentric rings to be able to balance them right.
Good luck!
Old Aug 14th, 2006, 06:16 PM   #5 (permalink)
alexandra57
the front wheels have already been swapped with the back and the vibration continues!
Is it getting slower?? 30-50mph and 50-70mph times wanted! SiBradbury Engine & Drivetrain Tuning 7 Mar 20th, 2007 10:06 AM
60-70mph weird handling problem TallAndy Wheels, Tyres & Brakes 13 Jan 12th, 2007 07:43 AM
Lots of wind noise in cabin >70MPH? ga_zx3 General Discussion 0 Jan 3rd, 2005 06:29 PM
Indicator housing fell out at 70mph mollyruss Faults & Fixes 0 May 16th, 2003 01:44 AM
Thats odd or is it? Shaun General Discussion 7 Feb 19th, 2003 08:18 PM
