Visit Derek Woodman MINI
Old Aug 17th, 2006, 06:10 PM   #1
CooperS230
Local Time: 11:52 PM
Power Steering Problems ....help!!!!!
Hi guys!
I'm new to this forum and was wondering if anyone could help me. For the past 3 days when I have started my car there has been no power steering for a few seconds os so. Today was the worst day as I also lost power steering momentarily about a 1/4 mile along the road after starting the car. Has anyone any suggestions as to what could be causing this? Is there a power steering resevoir to check the fluid level?
Many Thanks,
Steve..
Old Aug 17th, 2006, 09:26 PM   #2 (permalink)
johnnyforeigner
johnnyforeigner's Avatar
sorry, i can't help you, but i've also had a power steering failure today. on my mcs it's completely gone. also got a horrible burning plasticy sort of smell as well. i'm guessing i have a major leak and/or the pump failing. i don't get any high pitch whining sound of the pump working at all.
i only picked it from the dealer this morning as well.
England View johnnyforeigner's Indi Blue & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Aug 18th, 2006, 12:22 PM   #3 (permalink)
Lizard King
Local Time: 06:52 PM
Send a message via MSN to Lizard King
CooperS230 depending on your model it might be the fan underneat that is stuck or worse the pump might have burn out. I would get it check ASAP because the lost of power steering in a mini can cause the steering to lock and having your steering lock at 100km might not be so fun.
Canada Male   Reply With Quote
Old Aug 21st, 2006, 05:25 AM   #4 (permalink)
Countrygent
Addicted to fun!
Countrygent's Avatar
Local Time: 03:52 PM
My 2004 Cooper S had a grinding noise when making slow turns - called my dealer service and they suspected on the phone it was the seals on the steering rack leaking - the resevoir was empty (the black bottle next to the white coolant res at the firewall - no leaks ever show because the fluid gets caught in the bellows/boots on the rack. Must be very common because the tech rep diagnosed on the phone immediately. Some folks have power steering fan failure - the fan is very vulnerable hanging near the pan under the car - if the fluid gets too hot it can boil out I'm told.
Gent
Canada   Reply With Quote
Newbie - problems with power steering Brooking Faults & Fixes 3 Aug 29th, 2007 08:00 PM
HELP HELP!! power steering Problems kee1983 MINI Cooper S 5 Apr 3rd, 2007 09:14 PM
Problems with the power steering pump cooling fan Jtharp52 Faults & Fixes 119 Jan 23rd, 2004 12:01 PM
Power Steering problems BennyB Faults & Fixes 11 Jun 24th, 2003 03:05 AM
left + power steering problems indi boy Faults & Fixes 4 Feb 16th, 2002 09:28 AM
