Adam's Polishes
Old Aug 18th, 2006, 05:29 PM   #1
jez_MCSc
jez_MCSc's Avatar
Local Time: 02:07 AM
Aircon not working & noises
I have recently bought a MCS. Took it into the dealer today for a bit of warranty work, power steering pump fan bearing gone, handbrake adjust, etc. Anyway, the air con has been noticably warm as well as a gurguling sound whenever the aircon is on from under the passenger footwell. I have searched this problem on the forum but not really found any answers. I asked the dealer to look at it and have been told that it may be a leak or could just need a refill.
This is the problem, a regas from an independant specialist = about £40-60. BMW want £100 to do this, though will pay it if there is a leak but apparently can't check this without a regas. Does this sound fair? What are the general opinions, should I go for a private regas and hope it's not a problem with the system or a more expensive BMW regas and hope it is a problem, so I don't have to pay for it haha!
Still I guess if I go for BMW I get a courtesy car which today was a brand new 320d, not bad.
Thoughts please.
United Kingdom Male View jez_MCSc's Pure Silver & Black 1st Gen MINI Cooper S Profile   Reply With Quote
Old Aug 18th, 2006, 05:49 PM   #2 (permalink)
minimul
minimul's Avatar
my aircon, in my 4 year old mini, was gurgling for ages, then the aircon light flashed whenever I tried to put it on and it would not come on.
I took it to a garage, not BMW, can't afford their prices, they said it would be £50 for a standard refill or £100 for a refill with dye, so they can check for leaks. I presumed there was a leak, i always think the worst where my mini is concerned, so went for the most expensive dye check, the air con has been fine ever since, wished I hadn't bothered with the more expensive option.
If your car is getting on a bit I would just presume the gas has run out and get it filled for cheap.
United Kingdom Female View minimul's Liquid Yellow & Body Color 1st Gen MINI One Profile   Reply With Quote
Old Aug 18th, 2006, 06:18 PM   #3 (permalink)
jez_MCSc
jez_MCSc's Avatar
The car is only 2 years old and still under warranty which is why I think they should check it for leaks but this is obviously not the case. The £100 is for dye check from BMW, but your noises sound the same as mine so perhaps all it needs is a refill.
Old Aug 20th, 2006, 06:22 PM   #4 (permalink)
Malin Dixon
Malin Dixon's Avatar
Gurgling is usually a failed expansion valve. Needs a specialist to diagnose and / or change it.
If it is low on gas it won't make any unusual sounds.
United Kingdom View Malin Dixon's British Racing Green & Body Color 1st Gen MINI One Diesel Profile   Reply With Quote
Old Aug 21st, 2006, 11:09 AM   #5 (permalink)
jez_MCSc
jez_MCSc's Avatar
Thanks for that Malin, time to drop it back to the dealers and hope they don't charge me for the £100 as it should be a fault and therefore under warranty. I'll update and let you know what they say once its been in.
Aircon Stopped Working djtex 2nd Gen Faults & Fixes 0 Jul 29th, 2007 03:46 PM
Steering Noises, Accel Noises, and others tbonecopper Engine & Drivetrain Tuning 4 Mar 28th, 2006 11:26 PM
die cast remote control mini - with working lights, horn & alarm Hat General Discussion 9 Dec 9th, 2003 02:14 PM
