| Tags: fixes |
| MINI2 Newbie | Heating Problem hi, ive got a problem with the heating in the car. ive got 52 plate cooper S n the heating wont work its just cold air and never heats up.. Can anybody help me with this coz its starting 2 get freezing ![]() Last edited by b_1981 : Oct 8th, 2006 at 12:58 AM. Reason: none |
| MINI2 Newbie Join Date: Sep 2007 Local Time: 10:51 AM
Offline | I am having the same problem, I never get any heat just cold are. Ive checked over the fuses, coolant levels and so forth but yet nothing but cold air. Does help as winter is starting!!! Does anyone know what may cause this to happen? |
| Lovin' every MINI of it! | Could be a thermostat. I would advise a trip to the dealer. Global Moderator ![]() |
http://www.mini2.com/forum/ | |
| MINI2 Senior Join Date: Apr 2004 Local Time: 10:51 AM
Offline | There are realy only two things that can stop a heater working. As DaFlake said, the thermostat could be stuck. If you have a temperature guage, and that is not getting to normal, the thermostat is probably stuck. To check it properly, wait for the car to be cold, and start the engine. Open the bonnet and feel the radiator. Wait for the radiator to heat up. The radiator should stay completely cold until the engine is at the right temperature, then get hot very qucikly as the thermostat opens. If the radiator gets warm slowly, the thermostat is stuck. Other than that, the heater controls aren't moving the air flaps in the ventilation system. Then what you have to do depends on how mechanically minded you are and if the car has climate control. |
| MINI2 Regular | Check the cable is operating the arm -select hot/cold and look under the drivers side dash (by your left knee) at the centre console and see if the clip is adrift !! This infomation was passed on to by minimaniauk and it worked 4 me! I feel so bad drivin so hard! |
| heating seats, how? | edcalvo | Interior & Ice | 1 | Apr 19th, 2005 06:38 PM |
| Engine over heating!!!! HELP!!!! | Kaanarig | Engine & Drivetrain Tuning | 13 | Apr 15th, 2005 04:31 PM |
| Help....she's over heating. | bishtelli | Maintenance & MINI Care | 1 | Apr 17th, 2003 11:57 PM |
| Over Heating Mini S! | PhoenixMiniS | Faults & Fixes | 5 | Apr 1st, 2003 10:23 PM |
| heating system | mia | General Discussion | 1 | May 14th, 2002 08:46 PM |
