Visit Mini Mania UK
Old Aug 9th, 2002, 03:42 AM   #1
Jnr_Seahorse
Jnr_Seahorse's Avatar
Local Time: 08:03 AM
Reverse
I was just wondering if I am the only person who has difficulty getting their Mini into reverse. Almost every morning I have about 4 or 5 attempts to wrestle the gear stick into reverse. I am also sure the problem is becoming worse.
JS
United Kingdom View Jnr_Seahorse's Indi Blue & White 1st Gen MINI Cooper Profile   Reply With Quote
Old Aug 9th, 2002, 04:24 AM   #2 (permalink)
dcfkan
In exile, down SOUTH!
dcfkan's Avatar
I believe there had been several reports about difficulty in engaging the reverse gear.
Personally, I occassionally have problem engaging it the first time, but no more than other manual cars that I have driven.
I normally put the gear back to neutral, de-clutch and try again with 100% success rate for second attempt so far.
Try performing a search - I am sure someone has written an essay about "double de-clutch" (or some other technical term) somewhere
DK
United Kingdom Female View dcfkan's Chili Red & Lime Green 1st Gen MINI Cooper Profile   Reply With Quote
Old Aug 9th, 2002, 08:48 AM   #3 (permalink)
somerset
somerset's Avatar
Local Time: 07:03 AM
I have the same problem - It just doesn't like going into reverse. De-clutching used to work, but now seems to take a couple of attempts. Slipping the clutch back gently usually get it in (oo-er). I mentioned it to my Dealers when they were doing the linkage, but they said they couldn't find a problem..
Old Aug 9th, 2002, 09:02 AM   #4 (permalink)
swil00
I can't say I've found this fault with my cooper. However on some occasions I have difficulties selecting 1st.
To add to the reverse problem though:
I had a drive in a cooper S earlier this week. One thing I didn't like was the force needed to select reverse It took three attempts to get it into reverse.
Is there anybody else who has driven an S found this or has a better technique ?
Scotland   Reply With Quote
Old Aug 9th, 2002, 09:13 AM   #5 (permalink)
Dom
Test thread infiltrator
Dom's Avatar
Send a message via MSN to Dom
Have you tried pressing the clutch pedal in
I didn't have the problem on my first gearbox (5 speed cooper), but it's on my second. Nowhere near as bad as my saxo was though!
Dom
England View Dom's British Racing Green & White 1st Gen MINI Cooper Profile   Reply With Quote
Old Aug 9th, 2002, 09:30 AM   #6 (permalink)
R1
Addicted to Speed!!
R1's Avatar
Try this (5 speed only)
Try depressing the clutch, into 3rd, let out clutch slightly, depress clutch fully again then into reverse.
You should be able to get reverse easier!
It was posted here somewhere something about 3rd and reverse being closer together as gears.
It may even work by just selecting 3rd and then straight into reverse without letting the clutch slightly out first.
My wifes Fiat Seicento does this as well, but, same as MINI, only sometimes.
United Kingdom Male View R1's Dark Silver & Body Color 1st Gen MINI Cooper S Profile   Reply With Quote
Old Aug 9th, 2002, 04:39 PM   #7 (permalink)
MCS1
MCS1's Avatar
First time I tried getting into reverse in the 'S' I was doing it slowly moving the lever over to the left until I hit the detent, then started pushing...and pushing....and it was almost impossible
However - I have been experimenting, and have discovered that if you sort of take a swinging swipe at the gear lever and batter it across the detent, it goes in quite easily....all seems a bit brutal, though
Goodness knows what was wrong with a push down/lift up detent...
Better that than dropping the clutch at 4,000 rpm thinking you're in first, when in fact you're in reverse
John
It's electric blue and it's really very speedy
http://www.mini2.com/gallery/persona...signature4.jpg
Old Aug 9th, 2002, 06:45 PM   #8 (permalink)
LMB
Toon Toon..
LMB's Avatar
<div><a href=
I know what you mean. The car doesn't seem to like going into reverse. I hope it loosens up.
Global Moderator
England Male View LMB's Thunder Blue & Silver 1st Gen MINI Cooper S Profile   Reply With Quote
Old Aug 10th, 2002, 09:59 AM   #9 (permalink)
HarryHBMCC
HarryHBMCC's Avatar
Local Time: 02:03 AM
Arrow
I've had trouble once or twice but my old Geo Metro had the same sort of thing. As others have stated, I sometimes find it helps to put it into 2nd or 3rd before trying reverse -- for some reason this helps.
Still haven't got my recall notice on the linkage... anyone in Canada get one yet I wonder?
Harry
Canada View HarryHBMCC's Hyper Blue & Dark Blue 1st Gen MINI Cooper Convertible Profile   Reply With Quote
Old Aug 10th, 2002, 11:57 AM   #10 (permalink)
bg MINI
Put it in neutral then
I've had the same problems on all manual transmissions.
Either put it in 1st gear and move forward slightly, then try reverse as normal.
or
Put in neutral, and "forcefully slam" the shift towards the side where 1st gear is, then back to the reverse side. Bring the gearshift easily into reverse.
Before anyone goes nuts with my "forcefully slam" - You aren't trying to break the stick, just wiggle the stick from one side to another. A little forceful slam from side to side is quicker.
Old Aug 11th, 2002, 01:46 AM   #11 (permalink)
Sealevel
...I have been experimenting, and have discovered that if you sort of take a swinging swipe at the gear lever and batter it across the detent, it goes in quite easily....all seems a bit brutal, though...
This difficulty is common to the S, not really considered a fault, and has been mentioned before. John has found the most common solution, just give the stick a little smack through the detent.
Steve
Cooper S: Pure silver/black, Premium, Sport, Black leatherette, 17" R90, 4/19 build, 5/24 delivery.
Old Sep 23rd, 2003, 07:00 PM   #12 (permalink)
AARX-mini
Local Time: 03:03 AM
Canada
Brand new Mini owner. Having a great time, except that over my 3 weeks of ownership it has gotten to the point where I don't want to park nose-in to anything unless I can roll back out!
Is anyone aware of whether the manufacturer has acknowledged any issues with refuse-nik reverse?
I guess I won't be buying that house on the dead-end, one way street.....
Old Sep 23rd, 2003, 09:32 PM   #13 (permalink)
StevePSB
StevePSB's Avatar
Send a message via ICQ to StevePSB Send a message via MSN to StevePSB
My old MINI was a bugger for being hard to get into reverse.
When I first bought it the car was fine with reverse, but it got gradually worse in the last few months of ownership (it was 11 months old when I got shot of it).
It got to the point where it crunched 50% of the time I tried to put it into reverse.
Touch wood, but the new MINI is fine so far on this subject.
England   Reply With Quote
Old Sep 23rd, 2003, 09:33 PM   #14 (permalink)
EBMCS03
M5 Extraordinare!
EBMCS03's Avatar
Local Time: 12:03 AM
Send a message via ICQ to EBMCS03 Send a message via AIM to EBMCS03 Send a message via MSN to EBMCS03 Send a message via Yahoo to EBMCS03
Its not that bad is it? Ya its a little hard but... ya why is it so hard? other BMWs that have 6 speed gear boxes arnt...
EB/W MCS Arrived (3/26/03) Premium & Sports Package, Lapis Blue Leather, Harmon Kardon, PDC, Tint, Aux Input, X-Pel Clearbra *SOLD* 4/25/06
United States Male View EBMCS03's Electric Blue & White 1st Gen MINI Cooper S Profile   Reply With Quote
Old Sep 24th, 2003, 10:01 PM   #15 (permalink)
MarkW19
Grinning
MarkW19's Avatar
The guy at BMW told me (at least on a Cooper) to let the clutch up, then press it down SLOWLY and gently, then go into reverse.
Works every time for me...
United Kingdom Male View MarkW19's Astro Black & Body Color 1st Gen MINI Cooper S Profile   Reply With Quote
Old Sep 25th, 2003, 10:54 PM   #16 (permalink)
Jen
Two MINI Family
Jen's Avatar
Blue Cooper
Glad to know I am not the only one with a MINI that hates to go backward. I have trouble nearly every day getting it into reverse - even despite trying just about all the tips here. I've had a manual transmission car my whole life and am quite used to the occasional hesitation, or needing to let the clutch in/out again but I feel like a big dork everytime I am trying to go backwards and the gears end up grinding!
Has anyone actually taken their MINI back to the dealer about this? I am just about ready to.
I love Isabelle - IB/W Cooper, racing stripes, 5400 miles -and maybe this will just be a quirk she has......
United States View Jen's Indi Blue & White 1st Gen MINI Cooper Profile   Reply With Quote
Old Sep 27th, 2003, 02:09 AM   #17 (permalink)
theminiv
MINI2 Veteran
theminiv's Avatar
United-Kingdom
Hmmmm, Same problem here,
problems in 1st and reverse, but my gearbox needs changing.
What i do is put the clutch in, then try reverse, then while holding it in the reverse position, raise the clutch slightly, then when it pops in put the clutch back down.
Focus > Mini One > Mini Cooper > Mini Cooper > BMW 316 > BMW 318 > MINI ONE > BMW 120i > MINI ONE PEPPER! - IM BACK!!
Old Sep 29th, 2003, 07:50 PM   #18 (permalink)
Tronboy
A sure fire cure for your reverse problem
Sell the car.
The resale is good, the cars are rubbish.
MINI... Another Unreliable Adventure......
United Kingdom View Tronboy's Solid Black & Body Color 1st Gen MINI One Profile   Reply With Quote
Old Jul 8th, 2004, 09:09 PM   #19 (permalink)
gchesaux
Switzerland
My MC grinds on occasion into reverse too. Someone at Mini just told me that reverse gear does not have a syncro. and sometimes the gears are not lined up giving the grind. So, you should put it in 1st gear first , then into reverse to line the gears up. Double cluching does the same I guess. I'm going to try it now.
Old Jul 8th, 2004, 09:15 PM   #20 (permalink)
Tronboy
I don't think very many cars DO have a reverse synchro. there's no real need for it, since the car is generally stationary when reverse is selected. The last car I needed to select first before the lever would slip into reverse was a 1939 Citroen Traction Avant. That car at least had the excuse of antiquity.
A 21st century car should be better than this.
Reverse Cornwallgame Maintenance & MINI Care 5 Jan 21st, 2006 03:54 PM
Need help with reverse for S Mister General Discussion 20 Feb 9th, 2005 11:11 PM
Going in Reverse howardpm CVT & Automatic 19 Dec 21st, 2004 09:13 PM
Reverse spanky2k Faults & Fixes 6 Jun 2nd, 2002 02:19 PM
Just don't go into reverse.... Paul MINI Cooper S 1 Mar 25th, 2002 09:27 PM
