| MINI2 Regular Join Date: Feb 2005 Location: nr oxford Local Time: 08:22 AM
Offline | brake fluid reset guys and gals my mini has just come up for a brake fluid change and as the car is out of tlc pack i'm not going to pay mini dealer price's when a good friend runs his own garage and can change the fluid for alot less. the problem i've got is how do i reset the clocks so its starts it count down again. i'm guessing it will be near the same as the service count down but not sure so can anyone one of you tell me how??? thanks |
| MINI Traitor | You can reset it... there are instructions on here somewhere (do the search). You could easily get it done by someone else (or even yourself). Only thing is I do remember something about a special procedure to flush the fluid from the abs unit. This might require special equipment? Clubman less.... ![]() |
| Flying Scotsman | ...I will be surprised if you can reset the clock ONLY using the normal Si reset procedure (non-tool) As for ABS unit, you are correct, that BMW/MINi reccomend that use of the special tool DIS etc is used. There is no problem however, about changing teh fluid DIY - I have done this on several BMW's with no problems. The point is that you MUST ensure that no air enters the system - which means you must ensure that the reservoir never gets empty when you are flushing... I have two tools - one uses an airline to such the fluid out and nother like a garden sprayer that pushes teh new fluid in... it works best. You just go round the nipples and let the old fluid out! DJ |
| brake fluid change countdown timer reset? | eddieboyII | General Discussion | 10 | Jun 11th, 2008 09:42 PM |
| Reset Sevice and Brake fluid counter. | racemier | Maintenance & MINI Care | 5 | Oct 1st, 2007 07:36 AM |
| Reset brake fluid service indicator? | ocoro02 | Wheels, Tyres & Brakes | 1 | Aug 22nd, 2007 03:13 PM |
| brake fluid countdown timer reset?? | eddieboyII | Faults & Fixes | 2 | Jul 1st, 2004 09:11 PM |
| Trip odo reset to read brake fluid change Q again | ezrally | Interior & Ice | 7 | Nov 20th, 2002 12:49 AM |
