Mighty Stripes
Old Nov 27th, 2006, 06:06 PM   #1
phil_c
phil_c's Avatar
Local Time: 03:09 AM
Brake problem
I was wondering if anyone knew how to fool the brake pad wear indicator light on the dash it is doing my head in. I have fitted new pads but they didnt come with a new sensor so i am waiting on one being posted, but cant put up with the light. Can anyone help. Cheers!!!
Northern Ireland Male   Reply With Quote
Old Nov 27th, 2006, 06:23 PM   #2 (permalink)
MINIMANIAUK
MINI2 Sponsor
you can fool the system by cutting the 2 wires at the connector(make sure you get the right one) and joining them together the light will go out , do make sure its the right connector,and the cut is wheel side of the connector. oh do make sure its the right connector, ps the right connector must be cut . I suspect doing this might invalidate your insurance so I would not reccommend it,but you did ask
Old Nov 27th, 2006, 06:56 PM   #3 (permalink)
phil_c
phil_c's Avatar
I tried this and the light did not go out. It was definately the right one because i had to cut the worn down sensor off. Do you have to reset the light???
Old Nov 27th, 2006, 08:29 PM   #4 (permalink)
S33BBY
You must be able to live with it for a few days. It seems like an awful lot of trouble when you've got new sensors on the way!
JCW Sound Kit | H/K | Sat Nav | SS+ | Xenons | 17" Anthracite R90s | Goodyear Eagle F1 GS-D3s | ...
United Kingdom Male View S33BBY's Hyper Blue & Black 1st Gen MINI Cooper Profile   Reply With Quote
Old Nov 27th, 2006, 09:17 PM   #5 (permalink)
stealth haggis
pesky gizmos i wish cars didnt have as its easy to tell a wron pad on a mini the last 3mm are the heat soak and thats when it should be changed
Brake pedal problem Journeyman Faults & Fixes 4 Sep 28th, 2007 11:47 AM
Problem with brake pedal yoni99 Wheels, Tyres & Brakes 6 Apr 27th, 2006 02:14 PM
MCS Brake problem bangBANG!!! Faults & Fixes 3 Aug 29th, 2005 12:56 PM
i have a brake problem, what could it be guru220 Wheels, Tyres & Brakes 0 Aug 29th, 2005 01:50 AM
Brake Dust Problem SteveGuntrip MINI Cooper S 18 May 13th, 2004 03:19 AM
