| Tags: fault, recline, seat |
| MINI2 Newbie Join Date: Jun 2006 Local Time: 10:12 PM
Offline | Front seats will only fully recline!! Hello Please be nice, I'm quite new ![]() Both the front seats in my Mini Cooper seem to be broke They only fully recline now so its really uncomfortable to drive or even be a passenger. Can anyone help me!! Thank you |
| Track addict Join Date: Jan 2003 Location: Hants Local Time: 11:12 PM
Offline | Hello Leah, I'm guessing you have bought a second hand car....? Perhaps a couple of years old....? If so, the earlier cars had levers for adjusting the angle which were a little bit of a pain to use.... Basically, the lever has a different function whether you push it down or pull it back - you should be able to adjust the amount of angle by using the lever slightly differnetly than you are currently - give it a try - its not just a single function. I know this sounds confusing, but pretty sure its the cause of your problem - its unlikly that the seats are actually broken. Never adjust the seat whilst driving either - this can be dangerous in the Mini. If your car is brand new, then i'm not sure what the issue is...... Tony ps tell us a bit more about you and your car :-) |
| MINI2 Newbie | I have an early mini and the seats go into this "broken reclined" mode from time to time. As the previous post says, you just have to perservere with the lever, move it up, move it down, keep fiddling with the backrest position and the lever position and eventually it should settle back into normal operation. |
| Damned | The very early MINIs (2001) suffered from a design fault with the seat mechanisms. You dont say whether you`ve had the car for years, or just bought it. If there`s any warranty with it, then I`d get them to fix it. If not you may have to struggle a bit with the lever, & really think about ever using the recline mechanism again for all the trouble it gives. ![]() ![]() In da Wud |
| | #6 (permalink) |
| MINI2 Regular Join Date: Feb 2003 Local Time: 11:12 PM
Offline | Hey folks - I've had this problem with some second hand seats I bought for the MINI. There is an easy fix - but you have to be quite brave to go for it. Basically you have to force the seat back beyond the standard stop. (Push against the seat back very firmly and it will let out a resonably loud click/bang - you'll feel the seat back go back by about a half inch over it's regular stopping point - it all happens quickly and wil no doubt terrify you and make you think you've broken your seat.) After this the seat reclines as normal again - you'll feel the notches of the mechanism working again. I think the seat just pops out of alignment within the mechanism and by forcing the back you simply realign something. |
| | #7 (permalink) |
| MINI2 Newbie Join Date: Jun 2007 Local Time: 11:12 PM
Offline | Seat problems Had the same problem with 2001 cooper I have just acquired. If you lean against the seat and wait for the click/bang the mechanism aligns and the seat seems to be ok. Thanks, good piece of advice. |
| | #9 (permalink) |
Offline | £300 - I ownder if they would have just done the same thing?.....Presume that figure would have been for a new seat frame or something. Anyway glad you got it sorted (and saved some cash into the bargain).... ![]() |
| | #10 (permalink) |
| MINI2 Newbie Join Date: Dec 2007 Location: Melbourne Australia Local Time: 08:12 AM
Offline | I want to thank you guys for this fantastic repair method... I could not afford to get bmw to fix it (they were saying that its the frame mechanism and it was big $$$$) So I used the repair idea of slamming the seat back ... and yes it worked like a treat . |
| | #13 (permalink) |
| MINI2 Newbie Join Date: Feb 2008 Local Time: 10:12 PM
Offline | RIGHT THEN!!!!! I am also going to give this a try and see if it works! BMW quoted a HUGE amount of money to fix - like other users here! *Rob goes to put his brave hands on* lol. WIll let you know how i get on! ![]() P.S. Does it make a difference the fact that the reclining mechanism seems to be jammed in this car? The seat is in an upright position. You can tilt it forwards, just now recline it further back.....so in effect, its stuck in a mid-way position. |
| | #14 (permalink) |
Offline | P.S. Does it make a difference the fact that the reclining mechanism seems to be jammed in this car? The seat is in an upright position. You can tilt it forwards, just now recline it further back.....so in effect, its stuck in a mid-way position.[/quote] Hi - I'm not sure about in this position. with my seats they simply flapped forwards or backwards - they didn't seem to be catching on the mechanism at all. So spent all the time in the full recline position. I wouldn't like to recommend the same solution for your seats if they are sitting in the upright position as it doen't sound like quite the same problem and may damge the seat? I presume you have tried waggling both the levers either side several times in all directions to free them. (not very technical I know) |
| | #15 (permalink) |
| Mini Youngster Join Date: Oct 2007 Location: Northern Ireland Local Time: 11:12 PM
Offline | Yeah that is the same with my passenger seat. 2001 model also. Push it right back then use the adjuster on it to get it to sit right. I think i posted that in another thread on here how to do it as well. Hope it works for all of you instead of having to pay some nasty BMW bill |
| | #16 (permalink) |
| MINI2 Newbie Join Date: Apr 2008 Local Time: 04:12 PM
Offline | broken passenge seat Thanks all for the posting on the broken seat. As soon as I read you just need to push back the seat, I went outside and tried his. Of course it work and this make me so happy. Thanks guys... |
| | #17 (permalink) |
| THE SOAKED & DROWNED MINI Join Date: Jan 2007 Location: TAMPICO, TAMPS. MEX. Local Time: 05:12 PM
Offline | I´ll try suggested solution with the passenger seat in my Mini '02 model. I have the same problem & I'm worried about paying high bill to bmw fr getting it fixed. Actually I've spent good money in fixing my Mini which engine and other parts went broken due to flood August last year. Now after waiting fr 8 months to get it back & less than 2 weeks driving it, the clutch got broken & I'm expecting replacement parts fr fixing it. |
| | #18 (permalink) |
| MINI2 Regular | i've just tried this method but it didn't work for me is there a special knack to it? i tried pusing it back firmly, slamming it back and then pushing it back even more firmly. nothing happened i suppose i'm a bit worried about slamming it too hard but i've just given it a really good bashing! Should be covered by warranty, right? |
| | #19 (permalink) |
| MINI2 Regular | just tried it again and it worked straight away.. My seat would fold forward as it should but would only go from fully forward to fully reclined with nothing inbetween. (This is taken from a jammed passenger seat point of view) 1. Made sure seat was in it's fully reclined position and not close enough to rear seat to be resting on it. 2. Knelt on seat base, facing drivers seat. 3. grabbed lever nearest handbrake with my left hand & applied upward pressure (not much, just enough to feel some resistance) 4. put my right elbow/lower arm on seat back. 5. Rocked left to right a couple of times (left is towards front of car, right towards rear). Result : mechanism clicked and now works perfectly Rocking rather than slamming or heaving on it, seemed to be bit less extreme and didn't make it feel like i was going to end up with the seat in 2 parts! possibly looked a bit odd to the nosey neighbour but it worked! |
| | #20 (permalink) |
Offline | I worked it out a while ago because i got annoyed with it and punched it back into place and it worked so I tried to break it again and see how to fix it lol. ![]() Only happens when someone doesnt slide the seat forward enough but noone is ever in the back of my car anyway. ![]() |
| Broken front seat recline mechanism | Beppy the MOD | Faults & Fixes | 3 | Feb 19th, 2008 08:10 AM |
| front seat will not recline | mjvander | Faults & Fixes | 1 | Sep 13th, 2005 12:01 AM |
| *URGENT HELP NEEDED* Swopping Front Seats with Sports Seats... | Kirstykix | Interior & Ice | 4 | Jun 28th, 2004 02:01 AM |
| front seats | geonot | Faults & Fixes | 2 | Sep 6th, 2002 09:40 AM |
